Question about Whirlpool LSB6300PW Top Load Washer
I have a Whirlpool lsb6300pw1. It does not spin fast enough to wring the clothes of the water. I took the cover off the washer and watched it go through the cycles. Agitation looked normal, however when it got to the spin cycles, this seem to be where the problems are. First the low spin, the RPM varied somwhere between 150-200 rpms. When I turned it to the high spin cycle it was only spinning at 80 rpms. These were visual counting. Then I repeated and found that the next time, i heard the motor spinning without the drum catching. I grabbed the drum and started spinning and it started to catch. So what do you think the problem might be, the possible clutch and/or clutch assembly? If i
  • mattg9979 May 28, 2011
    Well I replace the tub drive shaft since the two fingers on top were well worn down and had little pieces. I also replaced the clutch. I am still having problems with the spin. When it starts it takes a moment to get the tub to spin. I hear the motor running but not spinning. Then it finally catches and starts spinning. I can actually stop it by putting pressure against the tub.
    Could the motor be dying or could it be something wrong with the transmission?
    President:
  • 3,113 Answers
Clutch
Posted on May 24, 2011
  • honeymokey
    honeymokey May 29, 2011
    Check the drive block. This is what the drum rests on and the spanner nut goes on to. http://www.youtube.com/watch?v=w4O3n3r91...
Clothes are not wringing out
Washing Machine Won't Wring Out Clothes Properly - DIY ...
www.diychatroom.com/.../washing-machine-wont-wring-out-clothes-pro...
Apr 16, 2013 - 6 posts - ‎4 authors ... thing - the spin cycle doesn't really seem to do an effective job of wringing out theclothes once. ... Sounds like it's not spinning fast enough.
Washer does not wring out the clothes. Clothes are dripping ...
Nov 23, 2015 | Washing Machines
Clothes wont wring out all the way sometimes
Need to replace the clutch to make it spin. If they are worn it will not spin fast enough.
May 27, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Spin is not going fast enough to dry out clothes
spin is not suppose to dry the clothes, simply wring the most water it can from them.
are you sure you are not set on a gentle cycle? might your washer offer a extra spin cycle?
Dec 14, 2009 | Computers & Internet
When in spin cycle does not drain all the water we have to hand wring all clothes
if all of the water does not drain could be the water pump or if the washer does not spin fast enough to wring the clothes could be a worn out motor or tansmission
Nov 17, 2009 | Office Equipment & Supplies
My washer doesn't wring the clothes fully.
It's not spinning fast enough because of a loose or worn belt on the motor. Post back with your model number and I may can find a diagram of your washer to help you.
Sep 04, 2009 | Maytag Performa PAV2200
On delicate cycle clothes wringing wet when done
check drain hose kink or belt adjustment...worn clutch...basket drive
Aug 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Spinning fast and furious, just doesn't wring clothes dry
It sounds like you need a water pump!
See if it's pumping water next time you do load by looking at the discharge hose going to the drainage pipe and get back to me!
jack
Feb 21, 2009 | Maytag Performa PAV2200
Whirlpool washer lxr9245eq1 doesn't spin dry completely
Try this... while in in spin turn your spin selector switch and listen if motor spins slower or faster.. at fast spin open your lid quick to see how fast its spinning.. check and make sure your drain line is cleared and the water flow out fast...and if its spinning too slow problem is in the gearbox area..
Jan 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
135 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
