Question about Philips MC-70 CD Shelf System
Mc-70 micro system. CD jams & keeps on trying to read. I would like to have some manual way of opening the tray to remove excess CDs, which I believe are causing the jam. Unplugging power and restarting does not stop jam or attempted read.
5 Suggested Answers
SOURCE: FW-R7 displays "Locked" when attempting to open CD Trays
You were close, but didn't explain it very well. If you push on the 'DISPLAY' button (left side of machine as you are facing it, about half way down) when the unit is off, it will say something like "DEALER MODE", push it again to return it to regular mode. You may have to press and hold the button to get it to display 'DEALER MODE', then when everything is normal, "DEALER MODE" just goes off and isn't replaced by anything. Hope I explained it well. nyati585@aol.com
Posted on Jul 12, 2007
  • 238 Answers
SOURCE: TRAYS ARE JAMMED
hi, there must be a disk previously inserted which has stuck in the tray or something, open the cover and check if anything is preventing the tray from ejecting.. let me knoiw
Posted on Dec 30, 2007
SOURCE: CD player fails to read CDs
Hi Everyone !
We got the same problem two month ago and we fix it. The problem is drying lubricate oil from elector motor which spin the cd disk. You need to open top cover its 5 screw , 4 an sides and 1 on back. Then you see black cd changer in side. You need to open top cover of cd changer by unlock plastic clips and slide cover. Under cd holder you can fined elector motor that spin cd. You just need two drops of lubricate oil on top bearing at electromotor. My works fine right now .
Good luck.
Posted on May 23, 2008
johncaman
  • 201 Answers
SOURCE: I was putting CDs in my Philips 3-CD Player and
The best solution is to open the case and manually remove/realign the jammed cd.
Posted on Mar 13, 2009
Tray will not open
It sounds like the CD is not in the correct location. Tap it gently in several directions, try this several times it may solve the problem. I think you will have to open it up and align the tray assembly and remove the offending CD.
Oct 30, 2015 | Sony 5 Disc Cd Player Carousel Cdp-c615
When I push the cd open-close buttons on the player, the disc tray does not come out. When I select a CD# it says reading, but nothing happens. The player indicates that there are discs in all 3 spaces,...
It is likely worn drive belts. There are 2 within this hi-fi. I replaced my belts with elastic bands. No issues so far.
1) Remove power and unplug unit
2) Remove 4 x lid screws and lid
3) Remove both side panels.
4) Remove silver plate from shielding cd drive
5) Replace belts with 25mm diameter bands
6) Reverse the strip down.
New belts are $6 each on e-bay
Jul 29, 2011 | Philips MC-70 CD Shelf System
I have a Phillips MC/50. The CD changer keeps changing and won't play, just keeps flipping. If you use the tuner, you still hear the clicks of the CD changer. You have to unplug it.
There is a switch inside the changer that will not release. Most likely the plastic stop it rides on has broken off . This is common when the changer keeps shuffling the disc all the time
Dec 18, 2010 | Philips MC-70 CD Shelf System
It doesnt open and cant read the cds inside.
Remove the cover lid and look inside for anything jamming disk tray, problem may be very simple once you look at this. change out some of the cds.
Apr 09, 2010 | JVC XL-F254BK 5-Disc CD Changer
Jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Feb 05, 2010 | OEM Systems Car Audio & Video
CD is jammed in drawer of Philips MC-70 Mini Shelf System. Cannot open or play. How can I open drawer and extract CD?
look at the drawer is there a small hole on it? if so use a paper clip on that hole to eject the tray.
try unpluging it for few minutes and try again.
Mar 15, 2009 | Televison & Video
Mar 13, 2009 | Philips Audio Players & Recorders
CD tay won't open
If you had any cds inside, you can open the case and see whether there's any cd jammed, with the power switch off! If you didn't have any cds inside, open the case anyway and check if the tray opens or not!!!
Hope it goes well!!
Apr 04, 2008 | RCA RS2653 Shelf System
Cd tray stuck closed
open the cabinet and remove the magnetic lock placed on the top of the mechanism then u can remove the cd
Jan 02, 2008 | Yamaha GX-505 CD Shelf System
CD malfunction
It sounds like you have put a disc in the tray that the system can not read, so it will just keep trying to read the disc over and over again. If you turn everything off by the plug and wait a few mins the whole system should stop. Put the plug back in and as soon as you turn your system on, try and press the disc open key before the lens gets a chance to start reading it again. If this does not work you may just have a disc jammed. So you will have to get someone to check it out for you if you do not understand what you will be doing, because you may do more harm than good to your system. Good luck.
Aug 29, 2006 | Sharp CDES600 5 CD, 240W, Silver, Mini...
Philips MC-70 CD Shelf System Logo
469 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
