Question about Nintendo DS Lite Console
Ds light charge light comes on for a few seconds and then turns off also the ds will not turn on i have tried different chargers and batterys i have checked both fuses on the mother board and they both have continuity thru them also the l2 inductor is in place ????
    Guru:
  • 868 Answers
Hi sappingtond,
From what you just mentioned regarding your issue I believe that the bord needs to be replaced on you concern, you mentioned there is continuity on the fuses but still the device will not power ON at all.
You have eliminated everything that can be possibly causing the no power on your DS light, and the motherboard is the only thing that you have not tried replacing.
I hope this clears things.
Have a nice day,
mvincentc
Posted on May 24, 2011
I got my DS in 2009 april, then on september i lost my charger then on march 2010 i found my charger then i found out i could'nt find my DS anymore a few months later i found my DS i charged then it...
The red LED indicates low power. When the DS is charging an orange LED should be on and the DS can be switched on, giving a second green light. If you tried charging it but the orange LED did not come on or only came on for a few seconds then the battery has not charged. The charger may be faulty or the power connector on the DS may be faulty. You need to try another charger. If another charger does not work then the DS is faulty and needs repair. It could be the power connector or the battery or some other fault inside.
If the amber LED comes on to indicate that the battery is charging then the battery should be fully charged within 3 hours. If the DS does not switch on after charging then the battery may be faulty. It can be removed by opening the cover on the bottom of the DS.
You should try and find a friend with a DS who will let you try their charger and battery in your DS.
If the DS itself is faulty it will probably be uneconomical to repair. If this is the case then try selling it on ebay as a faulty DS.
Oct 30, 2010 | Nintendo DS Lite Console
Unable to charge battery
Well, yes there is a solution to this, but it still will cost you some bucks.
This sounds like you have a bad battery.
Usually when you have a bad charger, the same things happen that you describe. Only difference is your system won't come back on if the battery has fully died.
In your situation the battery does come on, but not for long. Which leads me to believe your charger is still working, however your defective battery is only being charged to a certain level.
I would recommend you use another battery with the same charger and see if you get the same results.
IF YOU DO..
Try a different charger.
If you're still experiencing the same results with a new charger and battery, then I'm afraid the problem is your charging port. If so, you would have to have this system repaired.
I wish you luck and hope I helped!
- Great
Apr 13, 2010 | Nintendo DS Lite Console
Everytime I wanted to charge my ds lite, the power turns red then it turned off in a second. I don't know where the problem comes, if it's the charger or the ds itself
Possibly both, or it could be your battery. Have you tried another battery? or tried the same charger on another DS lite?
I suggest you get another battery or another charger, whichever is cheaper , or try it on a friends.
If your charger and your battery works, then it is your charging port, it will have to be replaced.
Apr 05, 2010 | Nintendo DS Lite
My ds lite won't charge.. the orange light appeared blinked
We had this problem with a brand new DS Lite...turns out it was a bad charger. If you have access to another charger, try that first. Good luck!
Apr 03, 2010 | Nintendo DS Lite Console
I plug in my DS lite to charge, the light comes on for half a second, then turns off. I take out the battery, and the same thing happens
Try a different known working battery to see if the ds will charge. If it doesn't then try a different known working charger and if it still doesn't charge then that means the main board inside of the DS is bad and the DS would have to be replaced.
Aug 23, 2009 | Nintendo DS Lite Console
My ds wont turn on all i do is plug in the charger then flick the switch really fast then the light turns on for half a second then stops wat do i do I came home one day from a trip, I decided to use my DS...
Do any screens flash?
I would say its a fuse / grounding out / or battery is destroyed.
If you can, try a different battery.. Has your battery and/or DS had any previous water damage?
May 30, 2009 | Nintendo DS Console
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
Power problems with DS Lite
Really sounds like a dead battery. The DS will not work if the battery is bad even when it's plugged in. You get the quick flash of the power light and that's it.
Mar 29, 2008 | Nintendo DS Console
Ds lite ac wall charger
When you first get the DS it will have a bit if charge on it but only a few hours worth. When the DS charges it usally comes up with a orange/red ish light then that goes out about a few hours later when its charged. ad if you want to chek if it is charging correcly turn the DS on whilst it is charging and the little battery simble in the top right corner should show the battery carging.
Nov 30, 2007 | Nintendo DS Lite Console
Ds light not coming on and charger not working
When I hooked up my DS with the charger the orange light would flicker for only a few seconds then turn off.
I found out that if you KEEP THE DS ON WHILE HOOKED UP the DS will charge. Although, because you are playing/DS is on the charging will go extremely slowly.
Best option, and what I did, was was just return/exchange it. I just did that today.
Nov 28, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
20 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
