The CD tray was left open on my Anders Nocholson model E-6906 which is a self-contained unit for copying cassettes and LPs to CDs. I accidently bumped the tray and broke it off. Can this be fixed. Does it make economic sense to do so. And, if so, who can do the work, where would I have to send it, and what would the cost be. Thanks, Fred
    Guru:
  • 610 Answers
There are no existing service centers specifically for the Anders Nicholson players but you can always take this to a local electronics shop where they would disassemble it and replace the cd player tray itself with a generic one. I think it would cost you more (or at least at par) than the actual price of the item if you had this repaired.
If you are looking for a cheap work around. Try to check where the tray broke off and see if there will be enough surface to just use a good adhesive to patch it up. Make sure though that it is properly aligned though as it might cause skip problems while playing.
Hope this helps.
Posted on May 24, 2011
How to get a copy of instructions foe anders nicholson E-6906
Request instructions directly from Anders Nicholson.
Dec 01, 2014 | Audio Players & Recorders
I need phongraph needle
If you look at the cartridge it should have a make and model number on it. If you put that into Google the stylus should show up.
May 22, 2014 | ANDERS NICHOLSON USB Turntable With CD...
RCA RS2612 Digital CD system malfunction will not play CDs
The changer is fubar and repair is not cost effective.
Sep 16, 2017 | RCA RS2656 Shelf System
JBL 6 CD AM/FM Cassette Audio has CDs stuck inside and won't play or eject them. How can I get them out?
I've had this happen before with car stereo's uh i just normally unscrew the screws out of the top of the player to where you can get to the tray or slot for the cds and force the cd tray or the cd itself out but be careful and not break the cd this might work it usually does for me
Aug 17, 2009 | JBL MCDC100 6-Disc CD Changer
JVC12 DISC CHANGER CH-X550 jammed
I would pull off cover, unscrew and remove top carriage of tray and remove your disc. While your at it you should take cotton swab and dip it in rubbing alcohol and clean the laser lens. Then reinstall carriage and top cover and try using it again.
Jun 22, 2009 | JVC AM FM CD DET FACE CAR STEREO
Only records Lps and CDs, but not other cassettes
there are programs on the net that will copy from tape to cd via the computer if you have a cd writer on the pc hope this helps regards Jim
May 02, 2009 | Audio Players & Recorders
Cd tray stays open
There could be damage to the tray contact switches
(these tell to the control unit the position of the tray - open/closed), so that the control unit can start/stop and reverse the direction of the tray ejector motor.
These contacts are located somewhere underneath the tray (usually near the front unit cover), and since you mentioned that the tray was bumped while it was open, it is possible they were damaged. Also, the behaviour of the tray suggests that the control unit can no longer tell whether the tray is open or closed so it operates the tray motor in a wrong manner, which, again, points to these same contacts as the possible cause.
Repairing the contacts may be a somewhat delicate procedure, first you need to locate them (it may require partial disassemby of the tray mechanism), if they are bent a pair of tweezers might do the job, if there's hard damage, it's probably better to replace them (scrapped CD ROM units or a dead CD unit might be a good source, they just need to be of the same dimensions).
There may also be other causes for this malfunction, i just mentioned the first thing that i would check.
Hope this helps somehow.
regards
3rq8 (Triarcuate)
Mar 31, 2009 | Sony CDP-C265 CD Player
Need user manual
I have the CDR-200 and did not have the manual either. However, I did discover the same problem and found the solution. There is a "confirm" button on the front of the unit under the display area. After you press the record button "Record" will begin to flash in the display area and then you press "Confirm". It should start recording. Note however the following:
BURNING FROM EXTERNAL CASSETTE OR PHONO
Before starting this procedure make sure you have an AUDIO recording CD in the RECORDER tray of the CDR-200. A regular CD-R type of disc for computers is not going to work and may cause an annoying message on the display which does not go away until you put the right type of recording CD in the unit. It must be either an AUDIO CD-R or an AUDIO CD/RW.
1. When copying from an external cassette deck, you should set the source (press source button) until the setting is "Analog".
2. The "Dual" button should not be in effect. In the lower right portion of the screen you should only see a small number "1" with a circle around it. This indicates the CDs currently being used by the burner. In "dual" mode you can copy from the Playback CD of the CDR-200 to the Recorder CD. In dual mode you see "1" and "2" with circles around them. The active CD tray will flash on the display.
3. When copying from an external cassette unit, you use the "Record" button to start the recording. At the end of the cassette track you MUST press the STOP button by the CD Recorder tray. After you press STOP the unit will say "Update" which indicates it is closing out the track on the CD-R. You can continue to write tracks by pressing RECORD again, then CONFIRM when the tape is positioned at the right PLAYBACK track. It is usually helpful to have a few seconds of blank tape at the start of the PLAYBACK track before pressing RECORD. Press play on the cassette deck, then RECORD followed by CONFIRM on the CD burner.
4. When the track has finished burning you must press STOP to close the track on the CD-R. After you press STOP, the unit will display "Update" to indicate it is updating or closing the track. When the process completes, the unit will display the tracks it has written to the CD-R and will be ready for you to copy another track or FINALIZE the CD-R. When the unit is waiting after the STOP, you can change the cassette tape, reposition to a playback track and ready the playback tape for more recording. When the PLAYBACK tape is ready repeat STEP 3. Repeat steps 3 and 4 until you have about 14 or 15 tracks on the CD-R.
5. When you have finished recording about 14 or 15 tracks onto the CD-R, you will want to finalize the CD-R. Press the FINALIZE button, and then press the CONFIRM button. You will see the the unit start to display the progress of the finalize by advancing the level meters of the left and right channels in the display. When the unit is finished finalizing it will return to the number of tracks display for the CD-R. After finalizing the CD-R you can play it back to make sure the burn was successful. Be sure to wait for the tracks display before removing or playing the CD-R after the finalize is done. Removing before the finalize is done may damage the unit and may render the CD-R bad.
BURNING FROM THE PLAYBACK CD
1. Set the unit to "Dual" mode. As described above, you will see "1" and "2" with small circles in the lower right portion of the display.
2. Make sure the "Source" mode is set to "Analog" by repeatedly pressing the SOURCE button until it shows "Analog".
3. When copying from the PLAYBACK CD tray you will not use the RECORD button by the CD Burner tray. You will use the 'DUB" button just to the right of the display.
4. Put an audio CD in the PLAYBACK CD tray and press the skip track button ">>" until you arrive at the track you wish to record from. If the track you want to start at is track 1, then you don't need to skip tracks.
5. When positioned at the correct playback track, press the DUB button. The unit will show "CDR" and then "DUB" on the display. When it says "DUB" press the CONFIRM button. The unit will start recording. You can adjust the record level during the first few seconds to make sure you don't have the recording volume level set too high.
6. When the track is finished, you should see the unit indicate on the display "Update". This indicates it is closing the track and it should do this automatically. If it does not do this you may have to press STOP near the RECORDER Tray to force closing of the track. Usually the unit indicates "AUTO" in the display area and I believe that is what controls the automatic track numbering feature. I am not sure how the AUTO feature is turned on. I noticed on the CDR-200 it is on by default.
7. After the UPDATE is complete, the unit will display the number of tracks it has written to the CD-R. You can at this point change the PLAYBACK CD to another one or advance to another track for continued recording. When at the correct track simply go back to step 5 and continue.
8. When you are all done copying tracks from one or more CDs, and you wish to finalize the CD press FINALIZE and then press CONFIRM to start the finalize process. I noticed on the CDR-200 if you wait too long after recording a track the unit may start the finalize process automatically. This happened after at least 5 minutes. It is best to try and stay with the copy process to monitor what is happening. The finalize can also start if you have written to many tracks to the CD-R and it runs out of space. Typically, your safe if you burn about 14 to 15 tracks to a CD-R at a time. You might be able to fit more if the tracks are very short (2-3 minutes each).
One last note about the connections on the back of the unit. Read the labels of the connections on the back very carefully. The CDR-200 and probably the 201 have separate outputs for the PLAYBACK CD (CD) and BURNER CD (CDR). You will want to connect these to seperate inputs on your audio amplifier. Or you might also wish to merge them using adapters into one input on your audio amplifier. If you keep them separate you will need to change sources on the audio amplifier to hear each tray. For example, you might need to switch to "CD/TAPE" for the CD, and "AUX" for the CDR. It is probably easier to merge the two using audio adapters which can be readily obtained from RadioShack.
I hope this helps!
May 08, 2008 | Classic Electronics CDR201 CD Recorder
How to rip musc to my harddrive
Play Recordable CDs Containing MP3/WMA Audio Files
To play recordable CDs containing MP3 and/or WMA audio files:
Press the eject button on the Xbox 360 console (or select Open Tray from any area of the Xbox Dashboard) to open the disc tray.
Place a data CD-R or CD-RW containing MP3 and/or WMA media on the disc tray with the label facing up (to the right if the console is vertical).
Press the eject button (or select Close Tray from any area of the Xbox Dashboard) to close the disc tray.
Go to the Media area of the Xbox Dashboard. Select Music, Current Disc.
To play all tracks on the CD, select either Play All or Add to Current Playlist.
If you have an existing playlist open, Add to Current Playlist will append all tracks on your current CD to that playlist. Selecting Play All will clear a current playlist and create a new one consisting of all the files on the current CD. (Be sure to save your playlist, if desired, prior to selecting the Play All option.) Files are added to a playlist in alphabetical order by file name. Playlists start again from the beginning once the final track has played.
riz.
Nov 18, 2007 | X-Gaming X-Arcade PC Joystick (XGMPC)
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
