Question about Cisco SG 200-50P 50-port Gigabit PoE - SLM2048PT-NA
Hi do you know how to find the IP address of a cisco sg200-50p or to reset to factory IP address? The power light is solid so it must have a static IP but nobody knows what it is. Thanks
  • 93 Answers
To find the IP address of your router follow this:
1. Open up the Command Line. This can be opened by going to start > run... (This is the search bar if in Vista or Windows 7) and typing "cmd" then press OK.
2. In the black command line box, type "ipconfig" into it and press enter. This should post a return of a fair amount of information in the box.
3. Among the outputted response, there should be a line labled "Default Gateway" Now look directly to the right of this and there should be a number similar to this format: 192.168.1.1 (it may not be the same)
To get to the router, simply open up an internet browser and type the number into the address bar. You should be prompted for a password.
(source: How to Find your Routers IP address ' eHow.com http://www.ehow.com/how_5322432_routers-ip-address.html#ixzz1NE5G68jg)
Posted on May 24, 2011
Failed to verify router settings
Factory reset your router by holding the reset button for 10 seconds. Then hardline directly to the router and log in. If it is a linksys or cisco router you can log in by typing 192.168.1.1 into the address bar. Most ISP's use dynamic addresses but if you have a static one make sure that the subnet and the gateway are correct and that your static IP is on the network. Exp. if gateway is 192.187.20.1, any legitimate static IP would be 192.187.20.2/254 depending on the IP block that your ISP has. they would be able to tell you the settings. But like I said, most ISP's like Mediacom and Comcast use dynamic addresses. Maybe a bit more datail on your issue could help find a solution.
Aug 28, 2013 | Computers & Internet
My Cisco IP Phone 7945G keeps rebooting after I did a factory reset. Is there a way to fix this?
According to Cisco, when initiating a factory reset procedure certain information from the IP phone is erased while other information is reset to the factory default value, as shown in the list below:
Information Erased:
  • CTL File (Certificate Trust List)
  • LSC File (Locally Significant Certificate)
  • IP Phone Call History (Calls Received, Placed, Missed etc)
  • Phone application
Information Reset to Default:
  • User configuration settings (ring tone, screen brightness, sound levels etc)
  • Network configuration settings
t is highly advisable to follow the firmware upgrade procedure in a non-working environment to ensure other phones are not affected (in case of an accidental reboot), and to avoid the freshly factory reset ip phones obtaining the working environment's settings.
Please use the link below and follow the instruction http://www.firewall.cx/downloads/cisco-tools-a-applications/cisco-ip-phone-a-ata-firmware-downloads.html
Aug 28, 2012 | Cisco 7945G IP Phone
I need a static ip address how do i get one
Static IP address should come from them, some of our service providers give paid static P addresses to customer, you can check it from them for they are the one who have control providing ip address either static or dynamic.
Dec 26, 2011 | Cisco Linksys E1000 WirelessN Broadband...
My wrt54g router keeps on blinking it all started when i pressed on the cisco systems logo because the light was orange so i pressed it and it turned off and the power led started blinking and the wlan led...
The first step that we need to do here is to hard reset the router. At the back panel near the power, you can see the reset button... we need to press and hold it for about a minute..
(If the power light continuously blinking, we need to follow this step):
Step1: On the computer connected wired via the router, let's force card and set static IP on the computer.
(for windows XP)
> Go to control panel -- network connections -- right click local area connection and we can see properties. Click properties and let's go to configure. On that configure button, we now see advanced tab. Click advanced tab and choose link speed or duplex and value will be 10 MBPS half and click Ok.
> Right click again local area connection and click properties
> Highlight internet protocol tcp ip and go to properties. Once properties is open choose use the following IP address...
Please set IP to 192.168.1.5 / Subnet : 255.255.255.0 / Default gateway: 192.168.1.1
> After assigning the static IP please go to start - run - type cmd. On the blinking cursor type there ping(space)192.168.1.1 and press enter. If we are getting Request Timed Out, sad thing router is already defective. But if we are getting "Reply from...' then we need to update the firmware.
(After hard reset and router power light stays solid then we needs to reset up the router)
Dec 20, 2010 | Linksys Wireless-G WRT54G Router
Do not know know password for wireless internet
Hi
Go here and download the manual http://static.highspeedbackbone.net/pdf/Netgear-WNR2000-manual.pdf
You will need to reset the router or change the password in the router 1. To change the password, goto Internet Explorer 2. In the address bar type 192.168.1.1 3. Press enter key 4. YOu should see a box with username and password fields. 5. username is admin 6.password is password 7. These are not the wireless passwords but the access password to get in the router. 8. Once in the router interface on Internet Explorer; goto the wireless sections and change the password there.
To reset the router WARNING: This will reset all the settings to what it was like when it came fresh out of the box. You may need to know some other settings. Restoring the Default Password and Configuration Settings You can restore the factory default configuration settings that reset the router's user name to admin, the password to password, and the IP address to 192.168.1.1. To restore the factory default configuration settings: 1. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button, located on the rear panel of the router, for about 5 seconds, until the Power light begins to blink (see "Back Panel" on page 5). 2. Release the restore factory settings button, and wait for the router to restart, and for the Power light to stop blinking and become solid green. The factory default settings will be restored so that you can access the router from your Web browser using the factory defaults.
Failing this, please refer to the manual, page 29 onwards
All the best now
Phil
Dec 17, 2010 | NetGear WNR2000 Wireless Router
How can I clear / reset a Cisco IP Phone 7910
How to set a Cisco IP phone to factory default Reset configuration of Cisco IP Phone (7910, 1911, 7940, 7941, 7960, 7961)
To set the Cisco IP phone to factory default completes the following steps: should be completed:
For 7940, 7941, 7960, 7961 phones:
1. Power up the phone (unplug power cable and plug in again and hold the # key.
2. Release # when lights start flashing.
3. Press 123456789*0#.
4. Press 1 to keep network configuration or 2 to lose the network configuration.
For 7906G and 7911G phones:
2. Release # when MWI starts flashing.
3. Press 3491672850*#.
Oct 28, 2010 | Cisco 7910 IP Phone
Reset cisco airnet 1130ag
There are 2 ways to reset the access point.
Using the MODE Button
Follow these steps to delete the current configuration and return all access point settings to the factory defaults by using the MODE button:
1. blank.gifOpen the access point cover
2. blank.gifDisconnect power from the access point (the power jack for external power or the Ethernet cable for in-line power).
3. blank.gifPress and hold the MODE button while you reconnect power to the access point.
4. blank.gifContinue pressing the MODE button until the Ethernet LED turns amber. (approximately 2 to 3 seconds). Then release the button.
5. blank.gifAfter the access point reboots, you must reconfigure it using the web browser interface, the Telnet interface, or the access point console port.
Using the Web Browser Interface
Follow these steps to delete the current configuration and return all access point settings to factory defaults using the web browser interface:
1. blank.gifOpen your Internet browser. You must use Microsoft Explorer (version 5.x or later) or Netscape Navigator (version 4.x or later).
2. blank.gifEnter the access point IP address in the browser address line, and press Enter. An Enter Network Password screen appears.
3. blank.gifEnter the username Cisco in the User Name field.
4. blank.gifEnter the password Cisco in the Password field and press Enter. The Summary Status page appears.
5. blank.gifClick System Software. The System Software screen appears.
6. blank.gifClick System Configuration. The System Configuration screen appears.
7. blank.gifClick the Reset to Defaults button.
Note blank.gifIf the access point is configured with a static IP address, the IP address does not change.
8. blank.gifAfter the access point reboots, you must reconfigure it.
Aug 13, 2010 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
CONFIGURE ip pHONE 7912G
Here is the manual on how to Configure CCME, and this will apply to your 7912G. :)
Apr 24, 2009 | Cisco 7912G IP Phone
Cisco SG 200-50P 50-port Gigabit PoE - SLM2048PT-NA Logo
430 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
