Question about Vacuums
The electric blanket controller model kzc100 has stopped working. Where can we buy a replacement or get it repaired?
4 Suggested Answers
EwingElect
  • 276 Answers
SOURCE: We have an sunbeam electric
Hi. If you have a double or queen size blanket, switch the controls from one side to the other. If the fault follows the control, then the control is faulty. If the fault stays on the same side of the bed, then the blanket may be faulty. Most recent Sunbeam models have 3 years warranty. Once you've checked the controls, if it's under warranty call Sunbeam Customer Service on 1800025059 option 1 to report a warranty issue.
Otherwise: if the control is at fault, a new BL0750 has a recommended retail of $75.20. Get in contact with your local Sunbeam Service Centre via http://www.sunbeam.com.au/Pages/Support/Repairers.aspx
but if all else fails email me as I'm happy to help!
Posted on May 25, 2010
  • 377 Answers
SOURCE: I received this electric blanket
Appears to be that the power is not getting to the temperature controllers. Suspect a problem in the wiring between the wall outlet (if not the wall outlet) to the temperature controllers. Look for broken plug at end of cord or a break in the cord between the plug and the controller. Last, you may have to look at the connections inside the temperature controller the power cord goes to in order to see if there is something loose inside. But do this with the blanket unplugged.
Posted on Sep 19, 2010
wentlanv
  • 710 Answers
SOURCE: When connecting the dual controllers
Generally, when you're putting electrical things together, you assemble first, then plug in.
Handie Andie
Posted on Mar 27, 2011
Dual control sunbeam electric blanket, one side is blinking 'E' have disconnected it several times, but still nothing. It was wotking fine the night before. The other control is working fine.
An error has occurred in your unit. Near the power or elsewhere find the reset button and press it. If you done it still error is blinking, check if you can the heater and thermostat of the blanket has a problem. Either a short or open circuit occur.
Thanks for asking.
Jun 25, 2011 | Vacuums
The one of the controllers for the electric blanket keeps flashing an "e". The other controller is fine. We switched controllers and the same thing happened. We have unplugged the blanket for...
I did some searching-- and I came up with this Linkedin page-- seems to have some information-- Let me know if it helped-
http://www.linkedin.com/companies/jla-home
Mack B
Jan 20, 2011 | Vacuums
I need a contoller model C98A1 for a duel control king size Dreamland (Imetec) underblanket. I cannot find a supplier online can you help.
Hi - if you still need a controller we have one we were going to throw away as the blanket was disposed of by accident. It has never been used and works fine as far as I'm aware. Thought you might still be interested, as winter is on the way again!
Jan 01, 2011 | Vacuums
Our westpoint home electric blanket, model 950, flashes 8 on one unit & can't be turned off. ELECTRIC BLANKET!!
Try pressing the power button and boost button at the same time. Then a C will flash and the setting you had it on before will show up. I think that was caused by pressing the boost button.
Dec 28, 2010 | Vacuums
I received this electric blanket as a gift and it will not heat up on either side. There is no light on the controls when I turn the blanket on. I need my blanket to work - it's like brand new!
Sep 18, 2010 | Sunbeam Vacuums
We have an sunbeam electric blanket model BL 0750 We dont seem to be able to programme it to heat up. Control lights are flashing
May 25, 2010 | Vacuums
Roller won't go around after part of a blanket stopped it. the belt is ok. power is ok
Remove the roller by pulling down on one side, note how the belt is attatched so you can re install. you will find, I suspect, that part of the blanket is jamming the roller, hence remove obstruction, and put back together.
If the belt is a type with teeth, ckech that these are not warn down. If so you will have to replace
Dec 04, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuums Logo
270 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
