Question about Dryers
My dryer seal is off my door. it drys but just wont shut off. can i just buy a new seal for it?
  • Dryers Master
  • 7,482 Answers
Hi iiboge...
Yes you can buy a new seal for your drum and many other parts on the web.
Here is one place you can check for your belt. http://www.partselect.com/
I will include instructions to replace a belt, it will get you to where you will need to be.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please take time to rate me
Posted on May 24, 2011
Changed timer/whirlpool model leq9508kq1/dryer runs in accudry mode, wont shut off,what is wrong?
if it wont shut off this is a timer problem contacts fused closed,are you sure this is a new timer?(some are remanufactured)
Feb 12, 2013 | Whirlpool GEW9250 Electric Dryer
Kenmore Elite Gas Dryer starts/runs/drys only w PTS held on?
push to start button needs replacing,sometimes you can jump that out if you have another switch that starts the dryer when you close the door
Jan 15, 2013 | Kenmore 73952 Gas Dryer
Dryer drys great. is leaving black marks on clothes
Are the black marks a result of an ink stain in the drum or is the black marks coming for the dryer seal?
If they are coming from an ink stain then alcohol or hair spray with paper towels will normally get them off the drum.
If the black marks are coming from the seal, that means that the seal is not positioned correctly and would require that the dryer be disassebled and a new seal be installed.
Jun 18, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Hi, I have a Maytag gas dryer MDL# LDG8200AAW and its great my wife would not trade it for one of the new ones at all. The problem that I'm having with the dryer is that it drys the clothes but it does not...
Correct, Your belief is wrong! Your wife's belief is correct, the best dryer ever made!
If this happens only when you are using it on an auto setting then it is probably an air-flow problem,a dirty exhaust system. Clean it out!
Jul 12, 2017 | Maytag Dryers
Hello Maytag dryer runs,drys clothes, but does not shut off. Exhaust is clear and open. Thermostat is new.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Usually that is a bad timer...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Aug 17, 2010 | Dryers
Dryer makes a grinding type noise as it drys. i
Depending on the kind of grinding noise your hearing, it could be a number of things.If your dryer has been doing this for quite a while it could be that the front and/or rear felt have become worn or broken. if these are gone the drum will make contact with the inner rim of the door and the back portion of the dryer part number for both front and back tumbler seals is 33001807. If however the noise you are hearing has just recently and suddenly happened, this could indicate that possibly something has got caught inside the these same felts or seals. If the noise you are hearing is more of a loud buzzing this could indicate that something has obstructed the blower wheel inside the dryer, and is now rubbing against the fan blades of the fan. part number for the blower fan can vary depending on your SERIAL number. If you want to take a look insaide your dryer. FIRST UNPLUG IT. then with the door removed there should be two screws at the bottom of your unit. once removed you can now remove the "U" shaped bracket around the base and door. now you will be able to see inside. if you need to lift the top there are two screws at the left and right sides that hol brackets to the top. remove these and you now have access to the whole dryers drum, heater etc. Hope this helps
Thanks
Nov 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
The dryer runs and drys clothes but there are times when it won't shut off -- timer seems to hang up--sometimes and works others
your timer sound like it stalling and replacement would be in order if if its in good shape buy one
Sep 04, 2009 | Whirlpool Dryers
Dryer wont stop running
Check the door switch, it is probably loose or not adjusted right.
Jul 04, 2009 | Dryers
Dryers Logo
26 people viewed this question
Top Dryers Experts
