Question about Electrolux Kitchen Ranges
Westinghouse ceramic hotplates thermostats not working. when turned on goes to maximum temp. no temp range between off and on . how do i fix this?
  • 794 Answers
Hi tomp707,
The first thing to do is to check the temperature knob to make sure it is not broken or loose, if loose you will have to tighten it but if it's broken a replacement is needed.
Another thing to check is the heating element. Here's how:
1. First, unplug the appliance from the electrical outlet. Locate the screws holding the hot plate together on the bottom of the unit. Remove the screws carefully. Make sure to remember where to replace the screws back again.
2. Then, remove the casing.
3. After that, inspect the burner. If the heating element is the problem, the break will be visible. If the break is near the end of the burner, just remove the damaged part and reconnect the remaining element to the terminal. If the break is in the middle of the element, the entire element needs to be replaced.
Hope this helps.
Thank you for using FixYa.
Posted on May 24, 2011
How to switch on oven westinghouse kimberly 509
If the oven does not work on bake or broil settings then there has to be a problem with the circuit, either on the control board or the thermostat. If only the bake element does not work then the element itself most likely needs to be replaced. There are ways to isolate further but takes some basic electrical knowledge and tools. Note that I am not recommending that you do the following linked procedure - merely pointing out an information source. https://www.youtube.com/watch?v=uZNyEqXCNOA
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Mar 08, 2016 | Westinghouse Kimberley 509 Ceramic Oven
EO2 error -what does it mean, can it be fixed? How do you fix it?
It depends on the cause which can be a short circuit or faulty thermocouple, element failure or the opto/triac driver faulty.
You can check the error codes in the attached link http://www.torontomicrofluidics.ca/cms/manuals/hotplate.pdf
Apr 23, 2015 | Fisher Scientific Isotemp Basic Ceramic...
Hotplate and oven temp
There are several possibilities. Make certain your fuse at the main electrical box is correct for a 220VAC line. You do not want to OVER POWER the range. If that is normal, check all cords for insulation and flexibility. Check thermostat controls on the burners and/or oven.
If parts are normal, the only thing you can do is manually set temps lower when using the oven. Glass tops generally stay hot for several minutes after they are turned off. That is Normal, for example, to avoid Glass from fracturing; temperature slowly declines. Lastly; if all is lost, call for a serviceman to check it out, as you do not want a house fire.
Jan 11, 2018 | Ovens
A hotplate on old Westinghouse Silhouette electric cooktop won't turn off. Is this easy to fix? Any help appreciated we have young kids.
one of your thermostats has stopped working. no easy fix. you can just disconnect the plate and work without it.
Sep 14, 2012 | Cooktops
Yes i have a westinghouse ppl776 ceramic cooktop and can not regulate temperature on any control knobs ,plates run flatout, is the problem with the control knobs or hotplates
When this occurs the problem is always with the hotplate controllers. Has this happened to all hotplates at the same time or has it occurred over a certain time period?
Mar 06, 2011 | Ovens
The left front burner will turn on for a few seconds then turn off then back on and off. It would not heat the pan on it. This is a glass top range. Are there any tests that I can do to find the problem?...
If the rest of the hotplate elements are working correctly and you are performing the same tests with all of them then you have a problem. We know that the hotplate works. When hotplates are faulty they don't turn on and off, they just don't work. This would generally be a hotplate controller problem. It sounds as if the controller is faulty and requires replacing. If you are handy you can switch the suspect hotplate controller with a good one and see what happens. This will confirm our suspicions.
Mar 04, 2011 | Kenmore 96412 / 96414 / 96419 Electric...
Hotplate on ceramic cooktop not working, another won't turn down.
If 1 of the plates is not working at all, then it is going to be the plate itself, or a faulty regulator, you will have to take it apart to check the plate.
The other plate that you cannot control, needs the regulator replacing.
Mar 25, 2010 | Ovens
Deep-fryer thermostat
It is possible that the heater is shortened and it burns thermostat. Thermostat's are usually bimetal type mounted on ceramic so voltage does not matter a much.
Jan 13, 2009 | Kitchen Appliances - Others
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
Kitchen Ranges Logo
83 people viewed this question
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Robert Plante
Andrew Taylor
Andrew Taylor
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
