Question about Brinkmann 810-8530-S Stainless Steel Propane Grill
Not enought gas power, cooks too slow...even with new tank.
  • 43,501 Answers
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on May 24, 2011
The fan oven gets hot but food cooks more on one side than the other. Food needs to be turned for even cooking. Food also takes much longer to cook than stated on packaging.
packaging cooking times is only a guide... not exact
must be an electric range if it slow cooking
thats why professional cooks prefer gas
May 31, 2016 | Kitchen Ranges
Bought this grill in june/july. first tank worked perfect. tank went out while cooking. changed to new tank and lit her up. low flame and went out. looked at tank and found the valve and hose covered...
turn off gas at tank remove hose let it deforst , open all burners on bbq run out gas in line , turn off burners, reconnect tank turn on slow , check hose for leaks with washing up liqued and water mix make bubbles with this mix and brush over joints this will prove if you have a gas leak (hence the frosting ) if this is good no leak then you should be able to light burners , if this leaks then it could be a new hose.
Sep 24, 2011 | Weber Spirit SP-310 Propane Grill
I have just purchased a little portable gas grill. Do I unscrew the Coleman Propane Fuel cannister when I am finished cooking or leave it attache? It seemed that my first tank didn't go very far.
To be safe, Yes. Be sure to turn the canister tank is turned OFF before removing it. Also, be sure that when you reattach it, that you open the gas tank valve Very, Very Slowly (Slow Motion, slow). This will prevent the regulator from getting locked up.
Hope this helped and Happy Grilling!!
Jul 19, 2011 | Coleman Grilling
We just used the grill the other night went out to cook tonight will not ignite ....I can hear the gas so that is not it ...any suggestions? I am newby at all this but have been doing fine .....
Are you saying the ignitor won't light the burner(s), but you can hear gas going thru the burners?
If that's the case, try match lighting the burners. That's a good way to find out if you are really getting enough gas for combustion.
If after match lighting it, you find that burner flames remain low, even when they're turned to High. Here's what you need to do:
1. Turn the gas tank valve OFF.
2. Disconnect the hose from the tank and wait 5 minutes.
3. Reconnect the hose to the tank and open the tank valve VERY, VERY SLOWLY (Slow Motion,
slow).
4. Once the tank valve is fully open, try lighting the burner farthest away from the tank first and turn
it to High. Did the burner light and the flame height looks normal? If so, light the remaining
burner(s) the same way. Do all the flame heights look normal? If so, you solved the problem.
Remember to always turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Pleas let me know and Happy Grilling, Newby!!
Jun 15, 2011 | Char-Broil 7000 Quick Set Gas Grill
My7 Baby q doesnt get hot enought to sear steaks
Their are several things that can cause this problem:
1. The burner(s) need to be removed and thoroughly cleaned.
2, Low amount of gas in the tank.
3. The grill's gas regulator is partially seized.
The first two are easy for you to solve, The third one is to if you do the following:
Turn the gas tank valve OFF. If you're using a 20lb LP Gas grill tank, disconnect the hose from the tank and wait 5 minutes, If you're using a small 1 lb cylinder, turn it OFF and remove it from the grill. after 5 minutes, reconnect the hose to the tank or reinsert the small cylinder and turn the tank valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open light the burner(s) and turn it to the highest setting. Did the burner light and does the flame height look correct? If so, you solved the problem. Just remember to always turn the tank valve ON very, very slowly.
If the above didn't solve the problem, you will need to replace the grill's hose/regulator assembly (if you're using a 20Lb LP Grill Tank). Which you can find at any home center or hardware store that sells gas grills and accessories. If you're using the smaller insert-able tank, you will need to replace the tank's hookup and regulator mechanism.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!!
Jun 03, 2011 | Weber Baby Q Grill
We bought a house with an old wood combustion oven everhot deluxe 204. Unfortunately all the controls details have been erased with time. So we do not know where the highs and lows stands for the knobs. We...
Hi Jacqui and Sven,
Check these guys out...you'll have to call or write, but they should be able to answer any (and all) questions about the Everhot Deluxe 204. They even carry spare parts! Hope this helped.
http://www.woodstoves.com.au/html/everhot_parts.html#Everhot
May 06, 2011 | Ovens
How do i replace the fuel line on the rancher #55. is there any connection in the gas tank or just at the carburator?
The fuel hose is just pulled into the tank ( interference fit ) take a new hose, cut one end into a point, push this into the top of the tank as far as you can, now grab the end through the the fuel filler holr and pull the hose on through, pull enought through to allow the filter to move in the tak.
Apr 14, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Gas line seems to have air trapped inside. How does one clear it?
First disconnect tank. Hook back up and open very slowly. These new valves on tanks have a shut down if you open valve to fast, causing tank valve to think it is leaking, it slows down flow of propane. Always open tank valve slow when turning on grill. If this does not solve problem then regulator is going bad and need to be replaced.
Feb 07, 2010 | Kenmore 437 sq. in. Cooking Area Gas Grill...
Does'nt get hot enought ...then other times no problem..i've cleaned burner tubes and even changed the regulator...cleaned out all spider &webs...whats up..............jim
try this trick....open the gas tank very slowly. inside the tank there is an overfill protection devise OPD which means that when you take it to get refilled, it cannot be overfilled. if you open the tank too quickly, this devise will kick in and restrict the gas flow. hope this helps.
Oct 14, 2009 | Weber Genesis Silver A Grill
Brinkmann 810-8530-S Stainless Steel Propane Grill Logo
76 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
