Question about Kenmore Dryers
I am looking for the drum size for a kenmore dryer model number 66702692
  • Kenmore Master
  • 3,740 Answers
29 inch dryer... Drum PN 695587
If you need parts here is the link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11066702692/0582/0151200?searchedModel=66702692&blt=06
Belt is 5 ribs and 94 inches long. PN 660996
Substitution: PN 341241
Thanks for choosing FixYa,
Kelly
Posted on May 24, 2011
Not start model 66702692
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 06, 2011 | Kenmore Dryers
I have a kenmore 70 series electric dryer that squeals or squeaks when you start it and will squeak periodically during the drying cycle. From what I can tell the actual model number is 66702692 or 110...
hello there and welcome to fixya
There is several areas that you will want to check and listen to it carefully
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Oct 01, 2011 | Kenmore Dryers
Sometime (but lately more often) a squeaky dryer drum - we've tried various sizes of loads - doesn't help.
The usual thing that will make a noise such as what yoou hear is the drum support rollers,i suspect that what me wrong with your dryer BUT kenmore is made for a couple different manufactures so depending on your model# it may use different parts...when writing in for advice in the future ALWAYS include your model number
this video shows how to replace the drum rollers if it is teh model i suspect it is
http://www.youtube.com/watch?v=wBf_vwvlFGM&feature=player_embedded
GENE
Aug 27, 2011 | Kenmore Dryers
Kenmore model# 66702692, making a thumping noise. I replaced drum belt..
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 14, 2010 | Kenmore Dryers
I get black streaks like the rest of you.. I
it's not the drum,it's the felt pieces that the drum rides on, there is felt on the back of drum and theres a felt piece on the front bulkhead, they could be worn leaving a space letting the clothing slip through hitting the black rollers or something is falling through the space hitting the clothes next time send the model number so i can look up your dryer,the model number is around the opening where you put the clothes into the dryer,open the door and look around the opening and you'll see a tag with model and serial number
Jan 22, 2010 | Kenmore 73952 Gas Dryer
Kenmore 70 series dryer Model 66702692
Air flow may be blocked or restricted.  Make sure the lint filter is clean and exhaust duct and outlet are not clogged.
May 30, 2009 | Kenmore 62602 Electric Dryer
The dryer makes a strange buzzing sound when u try to start it
1) First thing to check, can you move the drum by hand? if not the motor or drum bearings may have seized or collapsed.
2)Have you looked to see if te drive belts still on?
3) If you can turn the drum by hand- start the dryer, open the door then turn the drum as fast as you can by hand and quickly colse the door if it now tumbles you need a new motor start capacitor.
if you have no lucjk get back to me ASAP cheers
Mar 24, 2009 | Kenmore 64992 Electric Dryer
Makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Kenmore dryer
The belt you will need for that unit is part # 341241. These belts will fit almost all Whirlpool and Kenmore models except for the DOTT (Dryer Of Tomorrow, Today) dryers. A DOTT dryer is a Kenmore model only, and has a front kick plate and the lint filter in the door.
Jan 27, 2008 | Dryers
Signal
Kenmore 70 series. Model/Stock 66702692 Serial MG2402832
Cycle Signal works but then won't shut off until I open up the dryer door - it just keeps buzzing for hours. Also the dryer will turn on if I close the door ( and arrow is within a number and not on off) without pressing the start button. So if door is closed - the dryer will run or buzz (depending on arrow). How do I fix this?
Thank you
Jan 04, 2008 | Kenmore 64892 Electric Dryer
Dryers Logo
130 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
