Canont connect to the internet using my router
    Problem Solver:
  • 40 Answers
Good Day,
First thing to check on way you can't connect to the internet with your Router.
1) make sure that the Ethernet cable from the Modem is connected to the internet port or to the WAN port at the back of the Router.
2) check if the Router is the using using the PPPoE settings. if not make sure that your Modem is switch to bridge mode so that you can put in your PPPoE settings in the Router's GUI. or if your ISP don't want the PPPoE to be put in in your Router GUI then you have to bridge your Router.
3) make sure that your firewall settings is set to minimal so that it will not block your Router's program.
Good luck.
Posted on May 24, 2011
Connected wireless to router, excellent signal, but unable to connect to internet.
connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
good luck!!
Oct 07, 2011 | Linksys Wireless-G WRT54G Router
My broblem is, i have a signal from in my broadband roater,but my computer canont get it the signal from my roater. please help me about this broblem.
Kindly check the configuration of your router and to your computer..probably it has a problema to their ip address, if not check the cables to the router and test your utp if you have cable tester so that we can check if the connection is okey to get a signal to your router to computer.
Sep 16, 2011 | Computers & Internet
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Everytime i put the internet on it says internet explore canont display the website
you need to manage your internet connection properly.
check the settings properly.
Nov 12, 2010 | Computers & Internet
I had 1 modem and router with 4 pc and shared the internet connection. but now i need to add another broadband router so that i can use the internet. how can use another router and share the internet...
  • 1Unplug one of the network connections from your old router.
    Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+5860073694+9911500640+7416705818+8388126455+8941458308+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //-->
  • 2Use this open port to connect the old router to the new routers WAN(wide area network) port. If your old router has an uplink port, use this instead of the last LAN(local area network) port and keep the last LAN port open.
  • 3Connect the computers to the ports on the new router.
  • 4Configure the new router settings to match the old router settings.
  • 5Use IPConfig to check you current IP address
  • 6Use this information to create a static IP on the computers connected to your network.
  • 7Set the Default Gateway to the IP address of the router in which the computer connects.
  • 8Check that all computers can access the internet and "see" each other on the network.
  • Oct 24, 2010 | Computers & Internet
    I cant get internet on my ipod touch when i am conected to wi-fy
    This error means you're not connected to an internet-enabled network. If you want to surf the internet, you'll need to connect to a wireless network; you do that by going into Settings, then Wi-Fi.
    If the WiFi option is off, press it to turn it on and it'll scan for near by networks. Once you find one that is unprotected, or one to which you know the password, you can connect to it by pressing its name. Once you connect, if that network allows for internet access, you can surf.
    If you don't have any wireless networks within range, you can always set one up yourself. You can do it either with a wireless router, which will give you a permanent access point you can use whenever you feel like, or using a laptop - but that's difficult, not permanent, and has a very short signal range (Though it's free if you already have a laptop with a wi-fi card).
    Aug 07, 2009 | Apple iPod touch
    Belkin Router not allowing an Internet connection
    It's not unheard of for a router to fail. When you connected the computer to the Modem, did you use the same cable that was connected to the router? Does your internet connection require a username and password? If so, is that configured in your modem, or the router? If not in the modem it must be the router.
    Jan 05, 2009 | Belkin (F5D7230-4) Router (587009)
    Lost internet connection?toasted router?
    You will need to create your PPPOE internet connection on the router using your ISP username and password, access the router by opening internet explorer and type in the ip address of the router (example) > http://192.168.2.1 the router logon window will appear, use the username " leave blank" and the password "admin" -or- username "admin" with password 1234. Go into internet connections Select PPPOE connection enter your ISP username and password. restart the router and computer this should establish your internet connection. BPCS
    Dec 28, 2007 | D-Link DI 514 Wireless Router (DI-514)
    D Link DIR 635 router conection internet
    Normally, all ruters are hubs as well. if you want to connect it as a hub only; try connecting only the ports minus the WAN port that goes to the DSL modem. In this case the router will behave just like a hub.
    Nov 11, 2007 | D-Link / RangeBooster N 650 / DIR-635 /...
    Computers & Internet Logo
    48 people viewed this question
    David Payne
    David Payne
