***STOP:0x0000005(0x0001000A,0x0000000,0x00000000,0x00000000)
  • 921 Answers
That looks like a bad driver or failed hardware. Update drivers and/or replace hardware.
Posted on May 24, 2011
2004 chevy impala brake light isses switch has been replaced and so have fuses and bulbs still no lights
Do you know how to test using a DVOM - digital volt ohm meter ? Is there B+ voltage going into the brake light switch ? An coming out when the brake pedal is pressed ? What fuse's ? There is only one fuse for the brake lights !
The BRAKE SW fuse in the RH I/P fuse block supplies battery positive voltage to the normally-open stop lamp switch. When you press the brake pedal the switch contacts close and battery positive voltage is supplied to the left and right stop lamp assemblies and to the center high mounted stop lamp (CHMSL). The left and right stop lamp along with the CHMSL are grounded at G302.
Do you know about the right insturment panel fuse box ?
Stop Lamps Inoperative
Step
Action
Yes
No
Schematic Reference: Exterior Lights Schematics
Did you perform the Lighting System Diagnostic System Check?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Lighting Systems
Press the brake pedal.
Do all of the stop lamps illuminate?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO - Go to Step 3
Are all the stop lamps inoperative?
YES - Go to Step 4
NO - Go to Step 7
Inspect the BRK SW fuse.
Is the fuse open?
YES - Go to Step 14
NO - Go to Step 5
5
Disconnect the stop lamp switch.
Using a test lamp connected to ground, probe the battery supply voltage circuit of the stop lamp switch connector.
Does the test lamp illuminate?
YES - Go to Step 6
NO - Go to Step 13
6
Install a fused jumper between the battery supply voltage circuit and the stop lamp switch signal circuit of the stop lamp switch connector.
Do the stop lamps illuminate?
YES - Go to Step 12
NO - Go to Step 17
7
Determine if the center high mounted stop lamp is inoperative or the stop/turn lamps are inoperative.
Are the stop/turn lamps inoperative?
YES - Go to Step 8
NO - Go to Step 9
8
Do the turn lamps operate normally?
YES - Go to Step 17
NO - Go to Turn Signal Lamps and/or Indicators Inoperative
9
Disconnect the center high mounted stop lamp.
Using a test lamp connected to ground, probe the stop lamp switch signal circuit of the center high mounted stop lamp at the harness connector.
YES - Go to Step 10
NO - Go to Step 15
10
Using a test lamp, probe between the stop lamp switch signal circuit and the ground circuit of the center high mounted stop lamp with a test lamp.
Go to Step 11
Go to Step 16
11
Inspect for poor connections at the harness connector of the center high mounted stop lamp. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 20
Go to Step 19
12
Inspect for poor connections at the harness connector of the stop lamp switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 20
Go to Step 18
13
Repair a open or high resistance in the battery supply voltage circuit of the stop lamp switch. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 20
14
Repair a short to ground in one of the following circuits:
• The battery supply voltage circuit of the stop lamp switch
• The stop lamp switch signal circuit of the stop lamp switch
Go to Step 20
15
Repair a open or high resistance in the stop lamp switch signal circuit of the center high mounted stop lamp. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 20
16
Repair an open or high resistance in the ground circuit of the center high mounted stop lamp. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 20
17
Repair an open or high resistance in the stop lamp switch signal circuit of the stop lamp switch. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 20
18
Verify the stop lamp switch adjustment. Refer to Stop Lamp Switch Adjustment . If OK, replace the stop lamp switch. Refer to Stop Lamp Switch Replacement .
Go to Step 20
19
Replace the center high mounted stop lamps. Refer to High Mount Stop Lamp Replacement .
Go to Step 20
20
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
Jun 23, 2017 | Cars & Trucks
How do i find wiring diagram for stop lights
The STOP LP 25 A fuse in the underhood fuse block supplies battery positive voltage to the normally open stop lamp switch. When the driver presses the brake pedal, the switch contacts close and battery positive voltage is supplied to both the STOP 15 A fuse and the CHMSL 10 A fuse in the I/P fuse block, and to the turn signal/hazard module. The turn signal/hazard module then supplies voltage to both of the trailer rear turn/stop lamp supply voltage circuits. The voltage from the CHMSL 10 A fuse is to the center high mounted stop lamp (CHMSL) and the trailer jumper harness. The voltage from the STOP 15 A fuse is to the stop lamps, throttle actuator control (TAC) module, and the cruise control.
Do you know what a stop lamp switch is ? If so I would check it with a DVOM digital volt ohm meter , after you check fuse .
Did
Nov 05, 2015 | 2005 Chevrolet Chevrolet Avalanche 1500 LS
How do i go to no stop mode on bizhub c450/
Utility-Meter count-Check details-Stop 00-Stop 01- Stop 0 C select IU life stop setting-NO STOP
Jul 12, 2014 | Konica Minolta bizhub C450P Laser Printer
Skytec Astra alarm system just quit working unexpectedly
STOP STOP STOP STOP STOP STOP OK OK OK OK OK OK OK OK OK OK OK OK
Oct 01, 2013 | Scytek Electronics ASTRA200 Car Alarm 1...
How to reset the counters of the dev unit of konica minolta c360
The developer unit has been reset automattically,after change the old unit another new.You can change the developer unit life STOP after 45000 copies or NOT STOP more 400000 copies.To change the unit life press:
Utility - Meter count - Check details - Stop - 0 - 0 - Stop - 0 - 1 -Stop - 0 - C - select IU life stop setting touch NO STOP.
Aug 06, 2013 | Office Equipment & Supplies
My pc`s screen is blue and it sais stop:c000021a ,is there? anything I can do to fix it
hello there
here is some information that should be able to explain this error and how to fix it ok?
best regards michael
  1. How to troubleshoot a "STOP 0xC000021A" error ... presents advanced troubleshooting steps for the STOP 0xC000021A error. ... STOP: c000021a {Fatal ... Note Most STOP 0xC000021A errors occur because Winlogon. ...support.microsoft.com/kb/156669
  2. "STOP: c000021a (Fatal System Error)" Error! RE: "STOP: c000021a (Fatal System Error)" Error! Ya, thats what I thought I might have to do ... RE: "STOP: c000021a (Fatal System Error)" Error! just input the ...www.msghelp.net/showthread.php?tid=66202 - 52k - Cached
  3. How I fixed my Windows XP Stop c000021a {Fatal System Error} with ... How I fixed my Windows XP Stop c000021a {Fatal System Error} with Knoppix Linux. 2008 March 14 ... Message: Stop c000021a {Fatal System Error} The Session ...healyourchurchwebsite.com/2008/03/14/how-i-fixed-my-stop-c000021a-f... - 53k - Cached
Sep 16, 2009 | Microsoft Windows XP Professional With...
Unmountable boot volume
Also you can do the steps to get to the recovery console and type CHKDSK /R and it will run the disk checker program to fix what files it can. This has helped me fix numerous disks. It does not work 100% all the time, but hey 90% isn't too shabby. While it runs it will start counting up % completed, however it may jump backwards a few times. Do not get alarmed this is the computers way of trying to go back and fix corrupted files.
If you get it back running, make a backup of your files. What happened is the worst thing that can happen for hard drives and that is power interuption during a write operation. When that happens files get corrupted. Sometimes hard drives will prematurely fail because of this.
Jan 08, 2009 | Dell Dimension 2400 PC Desktop
Hi
It looks you have a bad hard drive. Have you tried changing it? If not, try it. Regards.
Nov 28, 2008 | Sony VAIO VGN-FJ270/B Notebook
Progressive Scan
SOLUTION #1
you'll need to reset. press stop to stop any playing disc, and press stop again holding it for 5 seconds to reset the system.
SOLUTION #2
works with remote only
SOULTION #3
While Disc is Running,
By using remote control,
Press Stop Button once to stop the disc (Stop in Memory Mode)
Press Stop Button once again to go into Full Stop
Then, Press & Hold Stop Button for 5 Second or So.
GOOD LUCK!
koreanainusa
Jan 21, 2006 | Zenith XBS444 System
Computers & Internet Logo
199 people viewed this question
David Payne
David Payne
