Printer goes offline after each print job - Computers & Internet
  • 922 Answers
Go to manufacturer's website and download latest driver. Try Postscript (PS) and PCL 5e/6 versions.
Posted on May 24, 2011
Minolta Magicolor 3100 ... Printer sayes its online and ready to print. When i send a print job it spools it ok but when it goes to print it goes offline. I delete the print job and the printer is back...
Does the printer show any message on it's display ?
Most common problem with these printers is the driver setting (mostly media type/weight) conflicting with the settings made via the front panel menu's.
Jan 04, 2011 | Minolta magicolor 3100 Laser Printer
My HP Officejet 6210 All-in-One printer goes offline whenever I don't use it for about 15-20 minutes, and when I put it back online, nothing happens. Looking at the printer from the control panel, I see...
HP Printers have common behavior of going into sleep mode if not used for a while. If this happens every-time the printer goes to sleep mode and you find printing issue, try this simple step below
Disconnect the power cable from back of printer
While holding the # and 3 button, connect the power cord to printer.
*Note this is partial reset and doing so you may loose fax logs and other fax related setting you have setup on printer.
Click the link below to know how to resolve the print job stuck in queue issue.
Link
Oct 23, 2010 | HP OfficeJet 6210 All-In-One InkJet...
My HP Deskjet D1341 printer won't print. Says it is offline. I go in and right-click to put it on-line, but it still won't print,,,goes back off-line. I posed this problem last Thursday and paid $$ to...
Goto the below mentioned link and select your operating system now click on the next button.
Expand the Utility - Diagnostic Utility and download the print diagnostic utility and this will show you what the problem is with the printer or with the computer
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=1839855#N672
Oct 05, 2010 | HP Deskjet Printer
Printer is offline and will not print. Restarting does not help.
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Aug 10, 2010 | Office Equipment & Supplies
Printer goes offline but is pingable on Network
I would see what kind of data is being sent to the printer. If the spooler is trying to send some data to the printer that is outside of its limits, even a page break missing, it will do this. Also see how much data it is trying to send to the printer. If it overwhelms the printer, it will just give up until the spooler stops sending requests.
Jun 28, 2010 | SATO CT400 Thermal Label Printer
Printer is offline how do I get it online?
Try to print. Once an error appear on your computer, right click the printer icon on the taskbar and click open printer connection.
Printer window will appear.
Highlight the pending print job. Click the File menu and uncheck the Print Offline.
Right click on the pending print job and select Restart printing documents.
Jun 23, 2010 | Canon PIXMA MX340 Wireless Office...
It suddenly went offline after printing a document. When I turn it off & on again, it manages to print the current job but then goes offline.
Turn off the SNMP option in the TCP/IP printer port Properties
Right-click the printer, select properties
Select port tab, highlight port, click Configure Port
UnCheck SNMP status Enabled.
This fix was given to me from Xerox Tech support.
Jun 22, 2010 | Xerox Phaser 3200MFP/N Laser Printer
Hp 5400 printer continuously shows as offline
If you are one a Mac, I may be able to help, as this happens to me. Sometimes when I send a print job, the printer shows as offline. HP recommends turning the printer off and then back on, but this did not always correct the problem. Go the the Printer Queue, click on the print job and then click on Pause Printer. Count to 10, then click on Resume. This fixes the problem for me and the printer then prints the job. I am running OS X 10.5.7. This same problem occurred using OSX 10.4.x
May 29, 2009 | HP Officejet Pro K5400n - - colour -...
Status on print job says offline dell m5200
a few questions:
-Do you know this printer IP?
-Can you ping this printer?
-How many printers do you have on your network?
-Did all the printers on your network offline or just this printer?
-Did you check the network cable that connected to your printer?
solution:
-you might try to restart printer spooling service on your print server
or
-If your server is still functional, you might try to reinstall/set up this printer on network
Mar 24, 2009 | Dell M5200n Laser Printer
Goes offline and if on line doesnot print document
RIGHT CLICK ON PRINTER ICON -- SELECT USE OFFLINE MODE -- HOPE A SOLUTION BRO
Jan 10, 2008 | HP Deskjet D2360 InkJet Printer
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
