Question about Oasis P1AQ
Water comes out of the back when i place the bottle on top of the unit. i have an oasi-425dx... why is this happening?
Why dose water keeps filling wash when off oasis he 27082 top load
The timer turns the water on to fill, the pressure switch turns it off. If the water contacts are welded together (can happen over time) then the water solenoid will be on all the time. Easy way to check. Unplug the unit, then remove the electrical plug from the water valve (hot or cold depending which one is causing the issue) plug unit back in. If water stops filling the timer is bad. If the water does not fill then the timer is fine, but the water valve solenoid is bad.
Jul 29, 2014 | Kenmore Oasis HE 27082 Top Load Washer
I have a kenmore elite oasis top loader washing machine. We accidently dropped and entire bottle of detergent into the machine while washing. Now the machine will not cycle, drain or spin, it just makes...
If you can get the unit to run by unplugging it and plugging it back in again.....add liquid fabric softner to the water as it will break down the suds....and prevent suds lock in the pump and ease excessive drag on the basket during spin.
Nov 18, 2010 | Kenmore Washing Machines
Unit does not fill with water
Need to gain access to water valves by removing back cover. place a tester on the cold water valve and see if there is power present once program is selected to run.. If there is, your valve is faulty. Replace
May 21, 2010 | Kenmore Oasis HE 27082 Top Load Washer
My Smart car is using a lot for water. Refill at least once a day. Don't see any water leaks. Overheat in slow moving traffic.
OK , even though it is hard to know without physically checking the car , but my guess is that possibly you have air in the radiator as first option. So what you need to do is open the temp gauge sensor (located in the back , top of the engine) and please make sure to open the lock and not to lose it as you will need it to tighten the sensor in its place. Open the water bottle and pour water in it and let the water come out from the back (the sensor) , you will see air bubbles coming out with the water , but keep on pouring water till you see no bubbles what so ever. put sensor back in its place while water bottle is full and while water is still coming out from the back to make sure that no air escapes inside with the water.You might need another person to help you pouring water while you are in the back. Start the car and let it warm up and let it run till it gets to 100 temp and watch how fast it comes back to 80 for couple of times , and while car running check the water bottle cap if its loosing any water. Let me know if you need more help Good luck
Oct 08, 2009 | 2008 Smart fortwo
How to take out air from the engine for smart car
Open the temp gauge sensor (located in the back , top of the engine) and please make sure to open the lock and not to lose it as you will need it to tighten the sensor in its place. Open the water bottle and pour water in it and let the water come out from the back (the sensor) , you will see air bubbles coming out with the water , but keep on pouring water till you see no bubbles what so ever. put sensor back in its place while water bottle is full and while water is still coming out from the back to make sure that no air escapes inside with the water.You might need another person to help you pouring water while you are in the back.
Sep 30, 2009 | 2008 Smart fortwo
In the last 2-3 months I have purchased 2 of the Sunbeam Combo Water Dispensers and both of them overflow. After setting the bottle in the ''no spill receptacle'' after awhile they will overflow around the...
I would say that the dispenser is at fault. These water dispensers use gravity to release the water and won't allow overflow. The air pressure in the bottle comes up through the dispenser as water flows out. Your dispenser is not seating against the bottle correctly. Look inside at the gasket material that the top of the bottle rests on when it is in the inverted position. That's where the problem lies. The leak is happening right there where the bottle rests down in the reservoir. Look at that seal, it's damaged. Leaking...
Sep 22, 2009 | Kitchen Appliances - Others
Water come out from Water line when Engine Shutdown.
Does it show signs of over heating at all? When cool, take off rad cap & check level in rad & top it up. If down a lot, start engine, turn on heat & let run until you hear rad fan come on & check temperature gauge to see if normal operating temperature. Let it come on a couple of times, and top up rad an inch or so from top, then put rad cap back on. Top up bottle to proper level & try it. If it spits back into return bottle, try replacing rad cap.
Jun 06, 2009 | 2003 Ford Taurus
OASIS drinking fountain , no water
Pull the water jug and open the top of the unit. Look for frozen water. May need repaired or adjusted to keep water from freezing.
Apr 01, 2009 | Oasis P1AQ
Oasis P1AQ Logo
Top Oasis Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Oasis Refrigerator Expert? Answer questions, earn points and help others
