Question about Kenmore Progressive Upright Vacuum with InteliClean System Slate Blue
I vacumned up a cat toy and now there's no suction and i don't have manual. do i need to unscrew all those screws on the bottom to find toy?
    Brigadier General:
  • 3,301 Answers
Yes you need to remove the bottom to get access to the flow of the air section, while doing this be sure to clear any debris collected in the roller brush section , if you can't find a manual,, an easy method is just check the sections of the unit where the debris travels and unclog any clogs, be sure and clean the hose section too as the item may be lodged in the hose too
Posted on May 24, 2011
I thought I was buying a manual. I put a new belt on my vacumn but it makes a funny noise and does not leave vacumn lines on the carpet like it used. I don't know if it takes two belts or one.Wish I...
Hi Frrank: The Owner's Manual for the Euro-Pro Infinity NV31N Vacuum can be downloaded in PDF from the following site:
http://dl.owneriq.net/d/df6c4a72-cf05-7934-2963-ee752eb0e124.pdf
See pages 15 and 16 of the PDF for instruction on replacing the single belt.
If this is not the manual for your model, please reply and will try again.
Thank you for using FixYa!
Feb 17, 2012 | Euro-Pro NV31 Infinity Vacuum
Vacuum smells and is not picking up well. Took the pole apart and I don't know hao to open the bottom.
To get into to the bottom of the vacuum, flip it to where you can see the bottom of the baseplate. Only unscrew the recessed screws...4 to 5 screws. Once you have removed those, the basepalte will pop off. It is probably just clogged at the bottom.
Sep 05, 2011 | Oreck XL Ultra Bagged Upright Vacuum
I bought a Kenmore 30012 Quick Clean Vacuum on 7/5/2011 it was working fine till just recently. Its not picking up anything off my rug, I've cleaned the filters, the belt is fine. It was blowing dust...
A clogged inlet. Something is likely clogging the opening where the dirt goes in. Paper, cellophane, or anything else light enough to get sucked in but too large to pass through.
Aug 18, 2011 | Kenmore Quick Clean 30012 Vacuum
Why does my filter collect so much dog hair and decreases the suction of the machine. I clean and change (alternate) filters everytime I vacumn, that isn't normal, is it? It seems like I have a seal or...
You obviously have a pet and it's good to see your machine is doing it's job. The only reason you could lose suction while collecting pet hair is due to the pet hair being a solid mass and air not been able to flow through the filters.( must be a lot of hair). Suction loss is only when the particles passing through your machine are dense therefore it will reduce suction and airflow . Very common on vacuum cleaners. Do not worry too much . Also check to see if you have Amy cracks in the seal between the drum and the vacuum cleaner itself
Jul 15, 2011 | Dyson Vacuums
We have a Miele Silver Moon vacuum that isn't
Hi dear.There are two type of attachments for this vacuum cleaners to pick up the pets hair,fluff & so on.They call it"Turbo & Power Brush".Turbo brush operates with machines suction & Power one operates with small electric motor which is built in the unit.They work with the same prenciple.There is a belt drives the rotary brush.OK.there are two small yellow screw underneath the unit.Please undo them,take of the cover & clean the rotary brush,check for the belts tension.It should be enough tight to drive the brush.If not ask for spare part from Miele in your country.After cleaning please put it back in order.To test it,attached to the vacuum.Turn the power on for Turbo brush,as long as suction starts,brush should start turning too.For the Power one,there should be power button on the handle to turn it on & off.Press it.It should work.On both of the unit,brush should spin good & strong enough to do the job when it's attached the surface you are vacuuming.Check the brush after each use,cleaned if neccesary. I hope that helps.Thanks.
Aug 01, 2010 | Miele s558 Silver Moon Vacuum
Vacuum is whistling and there is no suction through the hose.
Sometimes mine "wand" has no suction too. . . Make sure the vacumn column is clicked into the "standing" position, don't have it at an angle. Also you may have to play with the settings on the bottom part AND the power button together. I think this vacumn sucks (pardon the pun) mine turns off after 10 minutes of use, then I let it sit for an hour and then it'll start again. POS!
Apr 22, 2009 | Fantom Vacums XT450K Upright Vacuum
No suction or very little
Make sure you have a good bag installed in the vacuum and the door is properly in place. Remove the attachment hose from the bag chamber and turn the machine on. You should have good suction coming from the hose inlet. If you don't you have a problem in the bag chamber. Bad bag, door is not on correct, door is defective, dirty secondary filter.
Connect the hose back to the machine and pull the other end out from the bottom, and turn the machine on. You should have good suction there. If you don't you have a clog or hole in the attachment hose and it needs to be unclogged or relplaced.
Reconnect the to the bottom. Flip the mahine upside down. Take the screws out of the bottom plate and remove. Remove the brushroller and belt. Turn the machine on and you should have suction at the inlet coming off the brushhousing. It you don't, then you have a clog in the nozzle hose and it needs to be removed. It will probably be more accessable from the bottom side since that is the way that it entered.
Sometimes a suction problem can be confused with an brush problem. The belts on that machine should be replaced every 6 to 8 months because they will strentch and wear. This is an inexpensive maitainance that will dramatically improve its function. Part Numbers are 38528-035 and 38528-034
Nov 21, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
No wand suction
  1. i cleaned out my fanton and no suction in wand and still whistles
Aug 17, 2008 | Fantom Vacums XT450K Upright Vacuum
Hoover Agility, No Suction!!!
I had the same problem. Lower the handle to the floor and check the black spiral suction hose at the neck of the machine. The lower hose in my Hoover split. Check and see if yours has done the same thing. If so, the lower suction hose will have to be replaced. Hope this helps.
Oct 04, 2007 | Hoover F6212-900 / F6215-900 SteamVac...
Kenmore Progressive Upright Vacuum with InteliClean System Slate Blue Logo
94 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
