Question about Maytag MBF2254H Bottom Freezer Refrigerator
Freezer is frosting up. Defroster must not be working
  • Maytag Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 24, 2011
Freezing up in duct system frig part
Have you checked the heater/defroster element within the freezer? It may be related. When mine failed I was doing the defrosting with a hair blower. Over time (several days) the frost would build up on the freezer coils and the air couldn't flow as it should....so the thermostat wasn't getting cooled enough and it relayed the information to the cooling system, causing the frige to run all the time. Since it was clogged with frost, the frige was constantly trying to cool itself and the frost problem would get so bad that things in the freezer began to melt due to a lack of cold air circulation. After the heater/defroster element was replaced, frost would melt during the defrost cycle (as it should) and airflow/circulation was restored, allowing the thermostat to be cooled properly. Then the freezer coil was able to 'rest' when it should instead of constantly freezing to meet the demand for cold air in the frige. Hope this makes sense...and helps solve your issue.
Apr 11, 2014 | Kenmore Refrigerators
Frost building up at the coil. i think the defroster does not work
Chest freezers are manual defrost. Which mean yall unplug it to defrost it.
May 12, 2011 | Woods Chest Freezer C1501W3
Defrost not working heavy ice build up around coils
Hi
Frost is a natural occurrence on the evaporator coils in the freezer compartment of your refrigerator. To prevent frost buildup, a self-defrosting refrigerator warms the coils using a defrost heater several times each day to melt away the frost. This frost melts into water and flows out of the compartment through the drain. If any part of the defrost system is not working properly, the result can be heavy frost buildup that may affect the cooling capacity of the refrigerator.
The defrost timer is a mechanism that tells the defroster how long to run to melt the frost. The limit switch measures the temperature in the freezer and helps to maintain it, while the heater is the key element that melts the frost. Any one of these components could need replacement at a given time, which will result in this over-frosting.
Also check this bellow link:-
http://www.ehow.com/how_4504020_test-refrigerator-defrost-timer.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 01, 2011 | Samsung RS2530BBP (25 cu ft) Side by Side...
Its working but freezer proper work but refrigerator is not cooling
As struck freezer fan by working due to over frosting behind the freezer where FFan is located. Check defroster cycling is working properly. .Keep temp 5 degree and check thermostat, defrost timer and heater working properly.
Now defrost manually or unplug fridge. And after defrost, plug it again.
Feb 03, 2011 | Refrigerators
Frost is building up in bottom freezer. Amana ABB2224DEW
I have this problem as well, only nobody is leaving anything open. The defroster is defective of these things and the duct between the fridge and freezer gets frozen over and the cold air can't get in the fridge, so the freezer keeps working until it's blue in the face.
Apr 19, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Coils keep frosting over in my freezer draw Amana refrigerator. Defrosted about a month ago and now having the same problem again. Why would this happen in a frost free fridge and how can I fix it?
The defroster thermostat is what usually causes a ref/freezer to act this way. It can be changed by anyone handy with tools. You refrigerator schematic should show you where it is located.
Mar 21, 2010 | Amana ABD2233DES Bottom Freezer...
I have a Whirlpool Princess series Model# ed20akxsn02 the Frige side is not cooling I have it on the highest setting getting 42 degrees and no cooler but the freezer is working fine?...
Check to see if the fan inside the freezer is working... Also check if you have any frost build-up inside the freezer ..Frost buildup is an indication of either a non working defroster and/or a bad fan. Can't diagnose it with limited information.
Regards'
Dectech
Feb 14, 2010 | Whirlpool Refrigerators
AMANA BC20JL FROST/ICE BUILD-UP IN FREEZER, REFRIGERATOR WILL NOT COOL BELOW @46. COILS ARE VACUUMED REGULARLY, MANUAL DEFROST OFFERS NO IMPROVEMENT. EVERY SO OFTEN A LARGE PUDDLE APPEARS FROM UNDER THE...
Make sure defroster heater, temperature switch, and defroster timer and/or circuits are working.
Ice buildup will stop airflow from freezer to fridge, so fridge will be too warm.
My guess would be that the defroster is working half the time, allowing ice to build up. When it does work, it's got way too much ice/water to deal with, so it overflows the pan underneath.
Oct 23, 2009 | Refrigerators
GE Fridge not cooling
is the freezer fan running?is there any frost in the freezer?can you pull the frig. out and see how hot it is?is the comp. fan running?is the comp. clicking on and off,let me know what you find-mike
Nov 07, 2008 | GE Refrigerators
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Maytag MBF2254H Bottom Freezer Refrigerator Logo
62 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
