51 Error I am getting an error message 51 and I don't know what that is
  • 1,800 Answers
Have you tried repairing disk permissions? Go to the Utility folder in Applications and start up Disk Utility. Click on the second icon at the top left, then click on Repair Permissions. Repair Disk at the bottom far right will be grayed out.
If that does not correct the problem:
Quit AppleWorks.
Go to your user/Documents folder, and remove the AppleWorks User Data folder, put it in the trash, and empty the trash.
Do the same to your user/Library/Preferences/Appleworks folder
Do the same to the com.apple.appleworks.plist
logout and log back in as the same user. (not really necessary but I like an almost fresh start)
Open Appleworks, and make a NEW document and try to save it.
Open an existing document and try to save it.
If either of these will not work, let me know.
Posted on Aug 16, 2008
I have an error message on my Brother MFC-665CW--unable to print 51- how do I fix it
Unplug the unit and then plug it back in, check to see if the error message reappears, if it does go to the Brother web-site and check the error message information
Oct 19, 2014 | Office Equipment & Supplies
I haved an error message on my Brother MFC-665CW--unable to print 51
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
Apr 07, 2013 | Brother Multi-Function Center MFC-665CW...
I keep getting error 50 or error 51 and the screen says unable to print. I have followed the instructions of customer service and cleaned the coding band and checked for paper specs to no avail. I...
normally you will need to let the printer know that you have preformed any maintenance on it by clearing the error count after such an error occurs and is fixed it is normally listed under general or service options on the printer menu but you may need to look through the users manual
hope this helps
Robb
Sep 24, 2010 | Brother MFC 490cw Color Inkjet...
What does error 5100 mean
51.XY ERROR Control Panel Message 51.XY ERROR For help press c00244025.gifalternates with To continue turn off then on DescriptionA temporary printing error occurred. Action Turn the printer power off and then on. If the message persists, contact an HP-authorized service or support provider. Click here to locate an HP-authorized service or support provider via the HP Web site at http://welcome.hp.com/country/us/en/wwcontact.html.
Aug 06, 2010 | Office Equipment & Supplies
How to fix unable 51 error message
The problem with the error 51 means that something is in the paper system, but not always is true. I Had the same error but no paper jam was in the printer, I had to desasemble the printer and I found that it was a problem with the end gear of the roller charge paper. Some times when the paper gets jam, the first reaction is to pull over the paper, it causes the end gear gets out from its position and the printer can`t load the paper. It causes the error 51 in the printer. To solve this problem you need to attach the gear to its position, to do this is necesary to desasemble the printer. I hope it can help to solve this problem.
Nov 08, 2009 | Brother Multi-Function Center MFC-240C...
Brother MFC-5860CN print unable 51 error message
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | Brother Multi-Function Center MFC-240C...
Error 51
One or more ink cartridges may be empty. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} See page 143 of the manual for instructions on replacing the print cartridge. http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Sep 01, 2008 | Brother MFC 210C All-In-One InkJet Printer
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
