Question about Magellan RoadMate 1210 Car GPS Receiver
Stuck on acquiring signal - Magellan RoadMate 1210 Car GPS Receiver
    Problem Solver:
  • 6 Answers
Go outside, get a clear view of the sky to acquire a signal. Then try rebooting/reset the unit.
Posted on Jan 18, 2012
I was driving along and I got a message "lost satellite reception.
Put it on the dashboard when it is acquiring signal, that helps it faster. If it locks up like that, disconnected the power for 20 seconds and then power it back on.
Oct 15, 2015 | Garmin nuvi 350 GPS Receiver
Magellan 4700 stuck at acquiring signal. nothing else happens. is there a fix?
on some units this may take awhile to load depending on the area you are in. mine does the same thing. if it really never finds the signal and it does this continually then try to reset it
Aug 16, 2011 | Magellan Maestro 4700 Car GPS Receiver
The navigation display is stuck on one route
  • Try to check if there is a signal if there is non try to acquire signal.
  • Or you can try to download a new firmware for your GPS.
Feb 08, 2010 | Tomtom GO 700 GPS Receiver
GPS wont aquire a satellite
    Hello there and happy new year
    If Your Unit Cannot Acquire Satellite Signals
  1. For your Garmin GPS unit to acquire the satellite signals it needs to function properly, the unit must be taken outside, away from mountains, tall buildings and heavy foliage where it can get a clear view of the sky. Keep the unit stationary for several minutes while the GPS unit acquires the necessary satellite signals.It may take several minutes for the unit to locate a good solid signal
  2. OK
  3. Hope this is very helpful please keep me posted on this ok?
    Best regards Michael
Jan 01, 2010 | Garmin MAP76 handheldS GPS Receiver
While driving Garmin Nuvi 250 constantly loses satellite signal. The screen says that it is aquiring a signal. It is also constantly refiguring the route.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
Nov 12, 2009 | Garmin nuvi 250 GPS Receiver
No signal
I have a Tom Tom One and sometimes it behaves as if there are no satellites no matter how long it is switched on for but I now just drive off and within a few seconds (30 seconds at most) is it suddenly acquires the satellites and it's OK. It just seems to be a quirk of the device and it doesn't do it all the time.
If it still does not acquire satellites on the move then it is probably faulty and needs to be repaired.
HTH
Peter
Feb 06, 2009 | Tomtom One Europe v2 GPS Receiver
Wont acquire any satellites
Have you tried an external antenna? The flip antenna's are known to give problems,
May 12, 2008 | Garmin nuvi 350 GPS Receiver
I cannot acquire satellites signal. What to do ?
I experienced the same problem about acquiring satellite signal even when it's a clear sunny day. After 30 mintues, it was still searching! The unit appeared to have "stuck" in this acquiring mode. The following worked for me: 1) open the GPS antenna 2) press the bottom left screen while holding the power button to turn the unit on 3) enter maintenace mode 4) select diagnostics 5) clear error report, do NOT clear any user data 6) restart unit the usual way My GPS 350 was able to acquire satellite signal in less than 1 minute after the above steps were taken.
Jul 21, 2007 | Garmin nuvi 350 GPS Receiver
Magellan RoadMate 1210 Car GPS Receiver Logo
257 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
