All lights of the modem are on but there is no internet connection although I reset the modem, turned off everything and unplugged and waited for 6 minutes. Besides, I went to the 192......., put the dsl password and username with no success.
    President:
  • 1,082 Answers
1. Call DSL provider verify service is active. They should be able to ping their DSL modem.
2. If good service, plug your pc directly into dsl modem. If youre able to connect, then the router is bad. Youll need a new one.
3. If I read this wrong, and its the dsl modem that is not connecting, AND the service says its working, then it maybe the dsl network port has failed. In which case report it to your service provider and they should replace the unit for you.
4. You can try to unplug and replug the network cables, all of them. Or try different ones. Its just possible you are getting a poor connection at the wire terminator.
Posted on May 24, 2011
Are you using Verizon DSL? If so the PPP Staus usually goes down for some reason. Go to the router configuration by entering the IP address usually its 192.168.1.1 log on the default username and password usually is "admin" and check if the PPP status is down if so enable it.
RESET USERNAM AND PASSWORD
Resetting the linksys router in just six easy steps..
1. Turn on the router.
2. Reset the router, wait until the power light is blinking and then press and hold the reset button for 10 second.
3. Turn off the router and turn on again.
4. Wait for the power light to stop blinking, if the power light does not stop blinking, turn the router off, wait approx 30 second , and then turn it on again.
5. Connect the router to your computer, when it is connected to a computer with an ethernet cable, the ethernet port light will light up.
6. Connect the router to your modem, the modem is connected to the internet port is your computer. The router is connected to the modem.
If you are not able to reset the linksys router password then call linksys router support phone number 1-888-494-1155 (Toll-free) USA.
Apr 18, 2014 | Linksys Wireless-G WRT54G Router
I just reset my dell computer back to factory setting. How do I now reset up for internet connection. My provider is verizon and I am using internet explorer
You want to reset your internet connection???
If yes then follow the given steps....
Step 1
Turn the modem so that the back of it is facing you. Locate the power supply cord connected to the back of the device.
Step 2
Gently unplug the power supply cord and leave it unplugged for about 10 seconds. If you also have a router connected to the modem, disconnect the power cord of the router as well.
Step 3
After about 10 seconds reconnect the DSL modem power cord. Wait for the status lights on the front of the unit to come on. They may blink at first before turning solid green, or they may first illuminate as orange, then turn green, depending on the modem model. The "Internet" and "Incoming" lights may continue to flicker, this is normal operation for modems.
Step 4
After the modem is reset, reconnect the router power supply if you have a router. Wait a few minutes before resuming normal Internet use.
If you need any kind of technical assistance you can contact support cell
Jan 19, 2013 | Computers & Internet
Belkin n300 has a red light and willl not connect to the internet
Unplug the router and ISP modem. Connect and cycle the modem if there is a reset. If not wait a few minutes and reconnect everything.
The Belkin also has a reset, but holding it clears all custom settings. While a quick push is a restart.
Oct 26, 2012 | Belkin Surf N300 Wireless N Router
My cable light dont blink
Turn off your modem (unplug it from the wall or surge protector).
Once you have done this, wait for at least ten seconds, if not one full minute. (This allows the modem to reset itself)
Plug the modem back into the wall or surge protector.
The modem will begin its start-up sequence and finally it should respond with a "blinking" connectivity light.
If you have a wireless or wired router connected to your modem you must make certain that you follow the next steps, or the router may not work to provide you with an Internet connection.
1. Unplug the Modem.
2. Unplug the Router.
3. Wait for one full minute.
4. Plug the Modem back in to the wall or surge protector.
5 Wait for the modem to complete its start-up sequence.
6. Plug in the router. (if you plugged in the router the same time you plugged in your modem, start at step #1 and try again...)
7. Wait for the router to finish its start-up sequence.
8. Test the connectivity to the Internet.
If this does not work, please add some clarification as to what service provider you are using, the type of modem/brand, and if you have a router...
Oct 22, 2012 | Televison & Video
Windows vista crashed. changed bios to load xp. worked. old files on hidden drive. problem is cant connect to internet. driver files on hidden drive. Now what? Try to find driver and load it?
your explanation is very confusing. your internet connection must come from a modem either directly or remotely thru router. your mentioning of hidden drive does not make sense. drivers are not part of internet connection. you need to reset the modem and router if you are connecting through it. turn everything off. unplug router and modem. after 15 seconds unplugged, plug only modem in, wait until lights stablize; now plug router power back in, wait for lights to come on;,next turn PC on. Wait until completely booted up. go to control panel click on Network Internet, when opens try to find the local connect to network. if none, then your modem is not receiving signal or IP Address from your internet provider(comcast,centurylink, whoever). check status, if active fine. if active but icon says no internet access then your router is not set correctly. you may have lost its set up and you will have to reset up your router. you should have the step or instructions for doing that. after resetting and network active, restart computer so that is receives fresh settings from router.
if no network is found after restart you may have to reconfigure your internet connect by using the internet connection wizard(control panel).
Sep 27, 2012 | Dell Dimension B110 PC Desktop
The internet connection in my area went down yesterday, but i didn't know this and thought the reason i couldn't access internet was a problem with my linksys wrt54g router. So i unplugged and...
The first thing you should do is a proper 'powercycle' for all of your internet equipment.
To do this:
1) Unplug the power to your modem and your router, and power off your computer.
2) Wait a full minute.
3) Plug the power back in to JUST the modem.
4) Wait some more - for the modem to fully connect to your ISP, and the lights to indicate. If you're not sure, just wait about 2-3 minutes.
5) Plug the power back into the router.
6) Wait another minute or two for the router to finish connecting.
7) Then turn the computer back on.
You can bypass the computer turning on and off if you can repair your wireless connection.
If this doesn't work, there is a pinhole sized reset button on the router itself that you will need a toothpick or somesuch to press - press and hold the button for 5 seconds, and then try the steps above again. If you do this, the network id and password will be reset to the default, just like it was when you bought it.
Jul 20, 2011 | Linksys Wireless-G WRT54G Router
Computer cabled to Dynex enhanced G wireless will not connect
Unplug the router for ten seconds and plug it back in, it needs to reset. Some routers have a reset button. I often wait longer than ten seconds, I find a beer is usually the right amount of time. Sometimes the modem needs a reset also; unplug everything, then plug back in sequence, with the modem first, the wait, then the router, wait, then turn on your computer. That system works for any brand modem and router.
Jun 09, 2009 | Dynex Enhanced-G Wireless Broadband Router
Router cannot connect to the internet.
Turn everything off:
Cable modem unplug the power to the modem if it has a battery remove it.
Router unplug the power to the router
Shutdown any and all computers connected to the router
Turn everything on in this order:
Cable modem wait until all the lights are on but the internet act light
Router wait until the lights goes through it's test cycle and the internet light (wan) is on.
Boot up the computers one at a time after the first computer is fully loaded go to the next computer
Hope this helps
Terry
Feb 27, 2009 | Arris Touchstone 450a (CM450) Modem
Wrt54g V8 Suddenly stopped working
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
May 07, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
