Question about Amana Refrigerators
Hi, i have an Amana side by side fridge, model no. XRSS267BB. I noticed late last night that the element in the bottom of the freezer section was glowing red, is this normal? I have never noticed this before and was worried it could be dangerous. The fridge is working well but i was concerned about how hot the element was. I'm hoping it is just the way the freezer defrosts, but am a little concerned. Thanks.
3 Suggested Answers
woodchuck789
  • 4066 Answers
SOURCE: bottom freezer section iced up solid.-- Fan inside
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Posted on Feb 19, 2010
aborcass
  • 2651 Answers
SOURCE: Is the Defrost Heating Element Defective?
no not at all, it it was bad wouldnt glow at all. and the fact its glowing tells me yes timer and thermo are good.doesnt sound like your having a defrost problem at all
Posted on Mar 04, 2008
I have an Amana side by side refrigerator. Last night I noticed water running from underneath and the ice cream in the freezer melting. I found dog hair clogging a vent and cleaned it. This morning the...
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come up.open the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
Jan 30, 2011 | Amana ARSE66MB Side by Side Refrigerator
Ice build up
check that both cyclic defrost elements are working i dont think they are
Apr 21, 2010 | LG LBN22515 Bottom Freezer Refrigerator
Refrigerator part not cooling, freezer is fine Amana TXI18JW (top freezer model) I noticed in the last week or so that my refrigerator was slowly starting to warm up, so I started to turn the dial up on...
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 27, 2009 | Amana ARSE66MB Side by Side Refrigerator
Freezer and fridge not cooling properly
Clean it up. Check under it and behind, clean ,vacume and or blow out all dust and check the fins on the bottom, a soft brush and portable air compressor work really well but very dusty, take out side if possible, or just vacume really well.
Jan 26, 2009 | Amana 22.6 cu. ft. Side-By-Side...
GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
French door refrig..right door pops open when left door is closed
i would check the door closure, uderthe refrig door , sort of a "cam" style washer the wants to have the door close.. part number 67003638. $5 for the part
Nov 28, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
49 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
