Question about Microwave Ovens
Need a wiring diagram for Whirlpool Velos Microwave (Model # GH7208XRS1).
  • Microwave Ovens Master
  • 9,098 Answers
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Let me know if I can help further.
Posted on May 26, 2011
I have to slam the door very hard for it to close correctly what would cause this problem?
Incorrectly adjusted door catch. They have movement on them to allow a tight seal due to the microwave capability.
I just found the specs and instructions on it.
Whirlpool Gold 2 0 cu ft Velos SpeedCook Oven
Mar 09, 2016 | Whirlpool Gold 2.0 cu. ft. Velos SpeedCook...
Whirlpool Velos GH7208XR Convection works fine but microwave says door open and will not work on microwave. could it be door latch but then why does convection work?
I'd check the primary and secondary door switches for proper operation. Could be a failed switch, or adjustment issue on the switch assembly or door latching mechanism.
You also might have a failed thermal protector on the magnetron.
Feb 16, 2016 | Whirlpool Microwave Ovens
Got a whirlpool model wmh32517aw and I need a diagram on the wiring and components
Look on the back, contact manufacturing or go to the web site they have.
Jul 07, 2015 | Whirlpool WMH32517AW 1.7 cu. ft....
Velos Microwave turntable works, product heats but does not vent
can you give me more information what is it not doing
come back to me
Aug 18, 2009 | Whirlpool GH5176XPS Microwave Oven
Have a whirlpool MH3184XPS-3 and need a shematic wiring diagram
Found a "schematic " diagram of electrical lay out and repaired the associated problem of being mis wired.
May 01, 2009 | Whirlpool MH3184XP Microwave Oven
Whirlpool velos model gh7208xrs-1 will start but it does not make
Check contacts to control board first.
If control board is OK then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode and capacitors can br tested. The capacitor must bealloweddischarge before testing, or you risk to get electrocuted, evenifpower is off. Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Jan 19, 2009 | Whirlpool GH5176XPS Microwave Oven
I just bought a Whirlpool Velos Microwave Convection over the range microwave. We are in the process of installing it; had to change the vent, electrical hookup, etc. My question is, as large as this thing...
The installation manual will specify the requirements.
If not, I would contact Whirlpool customer service.
Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc..
Jan 15, 2009 | Microwave Ovens
Velos doesn't microwave
If you've had it for less than a year, it would still be under warranty and Whirlpool will fix it free.
You can contact them here: http://www.whirlpool.com/custserv/index.jsp
We're happy to help and we appreciate your thoughtful rating of our answer.
May 10, 2008 | Microwave Ovens
Microwave Ovens Logo
122 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
