Question about Garden
G110 smokes on startup replaced valve seals blows valve seal off valve seal perch
3 Suggested Answers
lester482529
  • 226 Answers
SOURCE: briggs and stratton engine smoking
if your oil level is to high it will do this. i would drain and refill the oil to oem specs slowly as not to overfill so it doesn't blow over the top of the piston.hope this helps
Posted on Jun 25, 2009
huffman49
  • 235 Answers
SOURCE: replace valve guide seals toro zero turn
i don't think those are replacable i may be wrong but i have never replaced valve guides in a small engine about the only thing that can be done is grounding the valve seats and lap the valves into the new seats..good luck
Posted on Apr 14, 2010
1997 Toyota Avalon blows out white smoke on startup once it's going it will stop
Smoke at start up could be several things and they all involve a mechanic to fix. Because it's white, this could be moisture (water) so lets see if it gets worse otherwise it may be a head gasket. Because it's at startup, it could be the valve seals. These seals get hard and allow oil to seep down into the piston which just burns off after a bit.
It's very important that you figure out if this is water or oil that's burning. Also assuming you don't have a gasoline smell? If so, it could be an injector(s) in which case just replace them.
Sep 25, 2013 | Cars & Trucks
Engines idle goes up and down after warming up and blows blue smoke
If the engine idles for a while then blows blue smoke this is an indication of oil passing the valve stem seals and being burnt in the combustion process. ( When you are at lights and they change and you accelerate away leacing a cloud of blue smoke this is worn valve guides and failed valve stem seals) As for the idle it could be the oxygen sensor is coated with oil and soot and is malfunctioning henace the cpu cannot regulate the fuel setting correctly. Have the valve seals replaced and clean the Oxygen sensor and check for other fault codes
Feb 17, 2013 | Cars & Trucks
Stem seals replaced. still smoke from exhaust after sitting all night ok after warm up
Could be left over residue burning itself out. Could be the seal is not properly seated and it starts to smoke then after it warms up the seal heats up and forms a better seat by seating itself. Give it a few days and if problems consists reapply the seal and tighten all bolts evenly at a little at a time
Nov 09, 2012 | Cars & Trucks
2002 Honda VT 750 CD Shadow A.C.E. Deluxe blowing smoke
Hi, Maria your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
1. COLORLESS OR SLIGHTLY BLUE SMOKE on start-up means your air/fuel mixture is the right composition and everything is well burnt in your combustion chamber.
2. BLUE SMOKE on startup is usually caused by failed valve seals dripping oil into the combustion chamber when the engine is not running.
3. YELLOW OR BROWNISH SMOKE at start-up means your air/fuel mixture is too lean. Too lean means that there is low fuel but high air mixture in your combustion chamber.
4. WHITE SMOKE on startup may be caused by a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers. Smoke while riding is usually caused by worn out or damaged valves, seals, guides, pistons, rings, or cylinder walls.
5. BLACK SMOKE on startup is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke or not in the off position, air filter dirty and clogged, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large or a damaged carburetor.
It should be noted that aggressive or abnormal throttle operation will cause these conditions to manifest themselves exponentially.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the links below. Good luck and have a nice day.
02 750 ACE is now smoking
Identifying Smoke
Honda 1998 VT750C Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 23, 2012 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
Uses far too much oil. Blows smoke at startup
This is typically valve guides, and piston rings. The valve guides are also a seal and when they wear it allows oil to get into the combustion chamber and it burns giving off smoke. Also when the piston rings wear it allows oil to get burnt as well. Only a mechanic can tell you which it is after he inspects the car. I can only assume this car has high milage on it. There are some product on the market that help seal thesea little better and cut down on the smoke, check you auto parts store.
Nov 14, 2010 | Toyota Camry Cars & Trucks
Blue smoke on startup warm engine
If you have a turbo, a shaft seal may be leaking some oil. Otherwise, the valve seals may be hard or worn enough to pass some oil during 'off' time. As long as it smokes only at startup, there is probably little to worry about until it begins smoking all of the time--then it will be time to replace the leaking seals which can be done without removing the heads. You might try a seal-softener additive in the oil or use 'high mileage' oil which contains seal softener. It also helps loosen sticking rings as well. Hope this helps.
Dec 23, 2009 | 1996 Volvo 850
My 1996 EL Falcon blows smoke only on startup after sitting for at least 8hrs .does not smoke at all after 1-2 mins driving
sounds like valve stem seals...if it is white smoke that is antifreeze , blue smoke is oil....hope that helps
Aug 24, 2009 | Ford Futura Cars & Trucks
Blue smoke in morning start up
if it constantly is blowing out smoke trhen it sounds like you rhead is cracked. head gaskets or something in that area. it will run but ****. alos try an oil change if u havnt already..
Jun 02, 2009 | 1995 Honda Odyssey
Blue smoke on startup when removing intake manifold it was full of oil 2005 XL7 2.7 engineI was going to replace valve seals but found alot of oil in intake
You have worn out piston rings. Excessive blow-by gases goes to the valve train compartment where the PCV valve sucks it into the intake manifold.
Apr 21, 2009 | 1999 Suzuki Vitara
2004 GMC Sierra 1500 blows a cloud of smoke only at startup
If it's the org. engine it will has over 60,000 miles on it.
It's normal to has the valve stem seal/oil seal on the head to leak oil into the cyclinder.
The smoke you see is the motor oil drop from the valve stem seals.
It land on the top of the cyclinders and it create black smoke at start up.
The inexpensive fix is to start using high mileage oil with seal conditioner.
This will help soften the rubber seals and help reduce internal oil leak.
The correct fix is to wait until it's time for a head gasket replacement and let the professional service the head.
Complete head service is the only method to stop this internal oil drip problem.
Feb 10, 2009 | 2004 GMC Sierra 2500
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
