Question about Mongoose Cycling
I bought a Mongoose Sabrosa 3x8 few weeks ago, and even thoungh I like it a lot, I've been having a few issues with the derailleurs and the rear wheel. First time I wast riding it uphill and the rear wheel just came out of place all the way to the left side of the frame, I took it to the shop and the guy supposedly fixed it, but after that I had the chain sliping out and skipping gears all the time, so, I took it back to them and now another guy told me that the two derailleurs were too close and that was the problem. Now the wheel comes out of place more often and even if I try to fix it, It just last for a few kilometers and slips to the front again. I think the screws that hold the rear derailleur and the disc brakes are not strong enough and they are scratching the frame already. Any suggestions? I just got the bike two weeks ago and I have took it three times to the shop, Is that the way it is supposed to be?
    Brigadier General:
  • 8,546 Answers
Quick releases skewers will hold the wheel just fine if tightened properly. They're SUPPOSED TO dig into the paint.
http://www.nashbar.com/images/nashbar/web/PDFs/QUICKREL.PDF
Deralleur and brake cables will stretch or break-in with initial use and always require some tweaking early on. Some shops build that expected tune-up into their sales offering.
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
http://www.parktool.com/blog/repair-help/categories/brake-service-and-repair
Posted on May 24, 2011
What is a decent replacement rear derailleur for a Mongoose 26" Ledge 2.1 Mountain Bike?
Get the kind that has a lever shift instead of the grip shifter. The plastic part that holds the spring breaks easily. The lever shifter has been going strong on my bike for 6 years without a problem
Aug 31, 2016 | Mongoose 26" Ledge 2.1 Mens Mountain Bike
I want to replace the derailleur what should i get
Any Shimano rear derailleur that is specific to the amount of cogs you have in the rear will work. Alivio is the entry into the nicer derailleurs. The more money you spend, the nicer they get: lighter, more machining, a more precise fit of parts.
Apr 02, 2014 | Mongoose 26" Ledge 2.1 Mens Mountain Bike
Rear brake lights and turning signals not working. One tail light has been out for very long time, but brake lights and signals just stopped working few weeks ago.
I'm checking into that same problem for a early 90's buick ( it's a GM also ) , I've checked the obvious ( bulbs, flasher,fuses,etc) all where fine. I assume your front turn signals work if you manually operate the turn signal switch or put on the hazard switch? The Buick's rear lights won't come on even with the hazard switch on. When you say one tail light has been out for some time, do you mean the brake/signal light or park/running lights? The Buick was like that with one side out for a while ( brake/signal light) but both the rear park/running lights work. Now, I've narrowed the problem down to the turn signal switch. I'd bet money on it. I just have to dig out my steering wheel puller, bite the bullet and get 'er done. You should be carefull if you're attempting that repair yourself ( AIRBAG ), use a manual. ( You could do a quick test by trying the turn signal while you pull the bottom of the arm toward you,move some of the wiring in the column near the arm,etc. I did and the signals started working. Could be the switch,dirt or a broken/loose wire. there's a lot of wiring going through the column and a lot of movement ( turn signal,high beam,cruise, then add tilt) Hope this helped.
Sep 20, 2011 | 2001 Chevrolet Cavalier
Mongoose Maxim 26" mens bike-
If it's "broken" or even bent it will have to be replaced. Your frame or derailleiur hanger may also have taken a fatal hit.
You should consult a Bike Shop.
If you still want to DIY you'll need to obtain some specialized tools and skills.
http://www.parktool.com/blog/repair-help/rear-derailleur-hanger-alignment
http://www.parktool.com/blog/repair-help/chain-installation-derailleur-bikes
Jul 09, 2011 | Cycling
Mongoose 21speed spear derailer is bent. bought at yard sale 60.00 dont want to put much money into. what is the best way to fix this. how much? Want to use as spare bike. it is rideable but how long....
A new Rear Derailleur may cost more than you paid for the bike. But is IT bent or is it the derailleur hanger?
Search the web for "fix bent derailleur"
Steel frames can be re-formed but not most other materials.
Someone in your club should know how to deal with it and maybe even have an old derailleur hanging around.
Jun 30, 2011 | Cycling
SRAM Rival Rear Derailleur stays on the large rear gear when shifting from low to high gears. Sometimes the gears doesn't seem to change at all. I've already taken the bike to Performance bike shop...
adjust barrel on rear mech clockwise till gear shifts click brake lrver for next gear repeat same as before with barrel. If this fails stat from bottom og cassette but adjust barrel anti-clockwise to obtain gears.
Jun 05, 2011 | Sram Rival Rear Derailleur
I have been having issues with my real wheel on my bicycle. I have Mavic Ksyrium Equipe wheels, and the rear wheel seems to be flexing too much under loads (i.e. sprinting, climbing, descending, and...
It's hard to believe a shop can't deal with what sounds like loosening spokes. OTOH, we Clydesdales are tougher on wheels than the lil guys. I used to break a lot of spokes under high torque demands, especially on several sets of Spinergy Spox wheels, then I bought a Park spoke tension gauge and meticulously trued and tensioned all the wheels on all my bikes. Haven't had a spoke issue since then.
Or you could get an old set of Spinergy Rev-X like I did a long time ago before I figured out the tension thing. If you can break or bend them you are not human.
May 21, 2011 | Mavic Cycling
Have a mongoose with single rear derailleur - how does the shift work?
You have a 21 spd and you have two derailleurs, one front and one rear. To shift you must always be pedalling forward, not backwards or you can chip teeth on your chainrings and cog. To shift, remember left hand controls front, brake and derailleur, the front derailleur is what gives you the ranges, gears closest to the bike are the easiest, so, small ring it the front are your easiest range, middle, mid range, large hardest but fastest. It is best to remember that it is the number of teeth that are hitting the chain to give you the speed you want. Rear Derailleur is your fine tuner the largest is the easiest, same as above. NOW DO NOT KITTY CORNER YOUR CHAIN, SUCH AS LARGE COG IN REAR TO LARGE IN FRONT CHAIN WHEEL, AND DO NOT USE SMALL IN REAR TO SMALL IN FRONT CHAINWHEEL. The reason you do not do that is: you can stretch your chain, yes you can stretch your chain and it serves no purpose, if you are pedalling to easy change your range(front). I hope this helps you understand how to shift now. You may contact me for any further questions, I have been in business for 38+ years
Sep 25, 2010 | Mongoose Exile 26 Men's Full-Suspension...
Where can I find a drawing of a 21 speed 26" mongoose duel supp rear deralier so I can see how the cable runs?
http://www.amazon.com/gp/product/images/B000B8IDS2/ref=dp_image_text_0?ie=UTF8&n=3375251&s=sporting-goods If it has a Shimano Altus rear derailleur, you can look here:http://bicycletutor.com/adjust-rear-derailleur/comment-page-3/ or here:http://www.parktool.com/repair/readhowto.asp?id=76
Oct 16, 2009 | Mongoose Sector 26 Men's Full Suspension...
CHAIN REPLACEMENT
I think I can help. Place one end of the chain over the rear gear (doesn't matter which one, the biggest) and adjust the lever or twist ring on the handlebar so the derailleur lines up in a straight line with it. Pull the chain from the rear sprocket down and over the pivot wheel and back over the bottom wheel so it looks just like this S and the end comes forward. Join the chain links. Place the chain over a couple front teeth and turn the pedal carefully until the chain seats on the front sprocket.
May 05, 2009 | Mongoose Exile 26 Men's Full-Suspension...
Cycling Logo
114 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
