Question about Craftsman Garden
How to change a belt on a craftsman riding lawnmower 22 v twin automatic 46" model # 944.600810
5 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: Trying to find replacement belts for a Craftsman
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=craftsman+rider+belts&_sacat=See-All-Categories
They do have some for your rider here on ebay.
You can also Go to http://www3.sears.com/ Enter your correct model number (the one under the seat; starts with 917) then continue to the diagrams list
Posted on May 13, 2009
mickey813
  • 472 Answers
SOURCE: need diagram for 46 inch belt craftsman riding
CAN YOU SEND ME THE MODEL FROME UNDER THE SEAT
Posted on Oct 13, 2009
EarthJam
  • 23 Answers
SOURCE: Craftsman 22 HP automatic/46 How to install drive belt
Hey jim the drive belt connects to the fron of the machine Just above the PTO clutch. connected to the vertical crank on the engine. It slips through a series of pullies to the back side od the mower. One pully will be on a tention spring. that is your golden ticket to getting the tention you need.
Looking at the pullys. for routing your new belt. V pullies for the inside portion of the belt and flat pullies for the outside.
You can usualyl take the chassis and pedals off as needed. the pebals have pins holding them on.
the seat has a safty switch that gets unplugged.
There are bolts hidden under the foot map as well which snaps up and down careful with these as that mat will never be the same if you break the clips.
THe back of the mower near and above the gastank you will see a pull thats ontop of a hydrostatic pump thats the last pully.
I have done these before without removing the body. However its not easy and you had better be limber.
Ohh and of course remove any decking under the mower for mowing lawns. =) i hhope this helps if i see a diagram i will try to link you. GL buddy -Jeff in alaska
Posted on Feb 03, 2009
  • 512 Answers
SOURCE: Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Posted on Aug 22, 2009
Craftsman riding lawnmower, model #917 259012 hydrostat stopped working
Check belts. Check transmission fluid level if possible. Check linkage between shifter and transmission. Check belt tensioners under unit above deck.
Jun 15, 2014 | Peg Perego My First Craftsman Tractor...
Why won'y my 20hp Craftsman Yard Machine riding mower start?
when changing the belt you might have knocked off a wire to a safety switch
Apr 17, 2012 | Yard Machines Garden
I need the routing for my craftsman 19.5 hp 42" 6 speed riding lawnmower belt.....model no#917259561
Hi and welcome to FixYa, I am Kelly. From the model number this is an EZ3 riding mower.
The steps are in the manaul here ander service and adjustments: (Page 22)
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0408255.pdf
The routing is the same in this manual on page 23 and has a much better diagram.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0308079.pdf
Also look on this page: (2nd set of pictures for 42 in decks)
Electrolux Home Products (EHP / AYP / Craftsman)
http://opebycrigby.tripod.com/decks/ehpdeck.html
There are many more decks at the top of the page. You have to click the links
Hopefully this is what you needed, Thanks for choosing FixYa,
Kelly
Jul 17, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do you replace drive belt on a hydrostatic transmission craftsman riding lawnmower that has slipped off or my be broken.
Its not a hard job just push in clutch and lock it, remove mower belt then replace drive belt and then put mower belt back on and release clutch.
Jul 17, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
My craftmans 46 in cut (22 hp) tractor goes backward after I changed drive belt
If you notice how the belt leaves the motor pully and goes to the transmission, it makes a 1/2 twist? Well reverse that twist and the tractor will go in the correct direction.
Jul 03, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
How to change the deck belt on Craftsman Lawnmower 42'' Model L1000 16 Horsepower-Manual available?
sears has manuals available for all their units give them the model number as to the belt route look on the deck there is usually a diagram sticker sometimes they get scrapped or damaged
Sep 24, 2009 | Craftsman Garden
Have a power kraft 18.5hp with 46'' deck, need a
first you'll need a model number. look on the underside of the seat, or on the metal plate between the rear wheels for the model no. sticker. wards tractors were made by MTD. there will be two numbers plus the serial number, write 'em both down. then log on to www.milacalawn.com. in most cases, you'll be able to pull up an owner's manual for your tractor with one or the other model numbers
Aug 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need diagram to replace blade belt for 19hp twin turbo cool mower
You have to post the model number from under seat. Not all Craftsman decks are the same. There are 38", 42", 46" w/3 blades, 46" w/ 2 blades, 52", etc.. Better yet, Get the model number under the seat (starts with 917) and go to... http://www.searspartsdirect.com/partsdirect/index.action Then enter the model #, hit search, then scroll down to Browse Subcomponent List and click on Mower Deck. There's your diagram.
Jun 28, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Trying to find replacement belts for a Craftsman Riding Lawnmower. 6 speed 46'' cut EZ 3 Mulching Family SKH 624U1G2RB Model #CV207 Serial # 2811705321
May 13, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
167 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
