Question about Linksys Wireless-G Broadband Router
If I plug the USB cable into my printer, then I my usb network adapter stops working, as well as my usb hard drive. If I unplug the printer, then all the rest work. The printer used to work just fine without any problems. Is this a virus?
    Scholar:
  • 94 Answers
MOst likely you have a bad driver or more likely a bad cable to the printer that is shoring the usb hub inside the pc.Try ot replace it if the problem still exists printer will need to be replaced.
Posted on May 24, 2011
I was just curious if there was a way to adapt this hard drive to be plugged into a usb port. Or how to connect it to a laptop as a second hard drive.
USB 2 or 3, yes, many shops sell adapters and enclousures. You can also buy a NAS enclousure and connect the drive to your network.
Sep 12, 2011 | Agi Western Digital Cavier Blue WD5000AAKX...
My WD external hard drive has suddenly stopped being recognised by my computer
Unplug the power supply from the hard drive, leave for 15 seconds.
Plug power supply back in.
Try another USB cable if that does not work.
Aug 08, 2011 | Western Digital Elements powered by WD 320...
Hi i have the canon mp490 all in one printer and i was just wondering how to i get things to print from my lap top
1) Install the network adapter on the printer, if necessary. Many wireless printers have the adapter pre-installed, but if this isn't the case, turn off and unplug the printer. Then, remove the back cover on the adapter slot and place the adapter into the slot.
2) Plug in and turn on the printer. Then, insert the drivers CD that came with the printer into the CD drive of the computer. If you've misplaced the CD, the drivers can be downloaded from the website of the printer's manufacturer.
3) Configure the network adapter. Once the drivers installation has loaded, select "Using a wireless network" and then select "Next". Usually, there is a User Agreement at this point, to which you will agree and press "Next".
4) Connect the laptop to the printer using a USB cable. Connect one end into the USB port on the back of the printer and the other end to a free USB port on the computer.
5) Finish configuring the network adapter. After connecting the laptop and printer with the USB cable, select "Create or modify the printer's wireless settings" and then click "Next".
6) Connect the printer to a wireless network. The wireless setup utility will automatically open after the adapter has been configured. Find your wireless network in the "Wireless networks found in your area" and select "Next". Then verify this information on the next screen.
7) Connect the laptop to the printer through the wireless network. Now, disconnect the USB cable. Make sure that both the laptop and printer are connected to your network. If they are, you're now set up.
Aug 05, 2011 | Computers & Internet
It is a Seagate GoFlex 2 terrabyte external connected through usb. I have dropped it several times and plugged it back in and it has worked. This last time it did not work when I plugged it back in. It...
I don't think so you have described properly your problem.
1. USB cable to Casing its completely a USB Device/Drive so where you plugged it?
2. "The Laptop does not see the drive or the USB adapter when its plugged in" you mean BIOS?
3. Windows 7 Pop Up Autoplay window what opens when you try to open it?
May 15, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
I have an external hard drive, Toshiba 160gb, model# HDDR160E03X, S/N 48UPF7OZSXS5..It was working fine but suddenly stop working. I change cable but still the same. When I connect it to the computer it...
Buy yourself a USB to IDE & SATA disk adapter from eBay fro a few $$$. Then open the Tosh case and unplug the drive and power supply connectors and remove it from the case - carefully. Plug it into the USB to IDE /SATA adapter and lay it flat on a non conductive surface and connect the USB to your PC should see it as a new drive. This will allow you to get the data off the drive, check for errors and reformat it. If you can’t see the drive from the PC then it is likely that the drive is fatally faulty.
Oct 13, 2009 | Toshiba 120GB USB 2.0 Portable External...
Drive is a blinking brick of garbage.
Is the hard drive a USB external device?
Does the hard drive spin up at all or does it make clicking sounds?
If the hard drive spins it may not be faulty, it may be a faulty USB hard drive adapter case.
Put the hard drive in another USB hard drive adapter and connect it to a computer, if it still doesn't work then the hard drive has died.
Jul 24, 2009 | Seagate Free Agent Go Small 12 GB USB...
Hp paviilion will not power up
try removing the battery and switch on your notebook using the ac adapter only if it works then i think you need a replacement for the battery or you can try to power cycle your notebook i hope it applies to hp notebooks coz it works all the time with dell vostro. to power cycle: unplug/remove ac adapter, battery, usb devices (mp3, ipod, printers, etc) optical drive, network cable then press and hold the power button not less than 10 seconds then put everything back except for the usb devices and network cable if it works then you can plug everything back again.
Jul 11, 2009 | HP VECTRA VLI8 P3 Motherboard (KZM6120)
Installed HP C6380 and lost 2 of my hard drives
Try the drives in another usb port set, for example at the back or the front of the computer in a diffrent set of plugs than where the printer is.
May 22, 2009 | HP Photosmart C6380 All-In-One InkJet...
How do i have a usb port run a high speed device
The USB port in your computer is not the new high-speed USB 2.0 version, and when you plug a USB 2.0 device in you will get that message. Most USB devices will still work but not give best performance. Just close the message window.
The network cable unplugged message can be disabled through the network settings. Normally Windows is set to display that message when there is no network cable connected. You can just ignore the message.
Dec 09, 2008 | Compaq Presario 700 470024-192 Notebook
Linksys Wireless-G Broadband Router Logo
32 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
