Question about Philips Televison & Video
I have a new Phillips 32PFL3605/98 tv. I have scanned all the avbailable channels with no problems. When I change channels in TV mode, none of the channels are what was scanned in. for example, channel 8 set HBO. Channel 8 in watch mode something else. Is this a frequency issue ofr something else?
SOURCE: UK TV History Freeview Channel
UKTV History now finishes at 18:00, when it is replaced by a new 'cheap-tacky-repeats' channel called 'DAVE'.  Worst thing Free-view has ever done in my mind.
Posted on Oct 17, 2007
Danmart
  • 291 Answers
SOURCE: can't get the channels to enter into the channel list
A lot of the " auto channel scan " etc. need a certain signal strength. you could have too meny tvs,equipment or anything connected to the "signal giver" that is sucking the signal strength.Not just turn off ALL connections to signal but disconnect the antenna 'input' to any equipment (sometimes people connect cable wires to radio receivers for stronger & better signals.)
You could have a open circuit to the input of the equipment in trouble.If you know how to get inside (with out killing yourself) connect an antenna directly to the end of the line of the intanna input INSIDE of the TV. if the signal comes in and the tv 'autoscans' and locks channels, then you have a open wire leading into the circuit.
p.s. BE CAREFUL!!, IF YOU don't know how or what you are doing.........DON'T DO DAT !! [that]
Posted on Nov 30, 2008
  • 16 Answers
SOURCE: TV freezes when switching to a digital channel
The problem your describing can be contributed to your cable box. Depending on your cable company there are times when the box has trouble translating the signal to the tv. You tv is operating normally. Suggest to the cable company to switch your box.
Posted on Dec 07, 2008
  • 45 Answers
SOURCE: no tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Posted on Jul 28, 2009
emissionwiz
  • 78267 Answers
SOURCE: How do i manually add a digital channel to my tv? model: ILO-26HD
do u have the user manual for the TV? if you do the solution will be in there, if not (I suspect you don't) please give the make an model so I can try to look this up, but off the top of head there is no way to "assign channels" to a paticular remote setting.
How do i channel scan on a phillips tv without remote control
change your remote control so that you can auto scan
Jun 30, 2015 | Televison & Video
Feb 18, 2015 | Philips 32PFL3403D/27 32 in. LCD TV
No remote need tv in av mode
While ur TV is connected to d AV device which must also be on, run a frequency scan and all available channels including ur AV channel will be detected and saved. After d scan, u can manually change channels to ur AV choice.
Jun 06, 2013 | Televison & Video
Finally bought anRCA antenna for my new Dynex TV.Nothing no signal,no way to scan for channels I can see.AGGH.Is it a lemon?
Which Dynex TV do you have? The manuals for most Dynex TVs are available from the product page. Start at http://www.dynexproducts.com/products/televisions.html . If you have an older Dynex that isn't on the main list, check under Discontinued Products. Alternatively search for your model. Then click on the Support tab to find the manual for that model.
For at least one Dynex TV (DX-32L152A11), the procedure to scan for channels is below.
To scan for channels, first make sure that the current input is set to TV. (Press the input button on the TV or the remote). Then press Menu and use the left/right arrows to select TV. Then press Enter or down arrow (the manual says the right arrow). Use the up/down arrows to select the entry to change. First, make sure that the Tuner Mode (first item) is set to Air (use the left/right arrows to change this). Press Menu to go back to the TV menu. Then go down to Channel Scan and press Enter. You may need to confirm the channel scan and press Enter again. Wait for the scan to be completed.
On a discontinued model (DX-32L151A11), the procedure is slightly different. With the input set to TV, press Menu. Select the Channel submenu and press Enter or down arrow. Set the TV mode to Antenna (use the left/right arrows to change the value). Then press the up/down arrows to reach AutoScan. Press Enter. Move cursor to highlight Yes and press Enter again. Wait for the scan to be completed.
I hope this helps.
(There were some Dynex monitors built. They usually do not have a coaxial antenna in port since they didn't have tuners.)
Jul 29, 2011 | Olevia LT32HVE 32 in. LCD Television
Phillips tv 32pf77320A/37
problem was with the FIOS Box not the phillips TV. The box appeared to be working but would not respond to channel changes and is being replaced.
Jul 12, 2008 | Philips TV Tuner Video Capture PCI Card -...
Channels are not available on phillips tv
HI
CHANGE YOUR TV TUNER CHIP.
ALSO PUT REMOTE CONROL CHIP AND NEW REMOTE .
Mar 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
Phillips TV/VCR combi 14PV400/07
To solve this problem, cancel the wake up alarm !
Dec 23, 2007 | Philips 14PV225 14 in. TV/VCR Combo
Auto Scanning
Try unplugging it for 2 minutes then se what happens. Make sure that none of the buttons on the TV or remote contol are stuck (especialy if remote is near TV).
Feb 06, 2007 | Audiovox FP1510 15 in. LCD Television
Channel selection
What you need to do is take the remote, go into the menu, find channel scan and do a channel scan to find all the available stations available on this system. Make sure the TV set is in the cable mode and not antenna mode or you wont get any stations above channel 13.
Sep 18, 2006 | RCA F27628 27" TV
Televison & Video Logo
96 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
