Question about Nordic Track NordicTrack Treadmill, A2550
The belt on my exp1000 does two things: 1) it stops in the middle of a workout; 2) it makes a high pitched squealing sound. Are these issues related? and how do I fix them? Thanks
  • kimogorman3 May 24, 2011
    I just bought the treadmill (used). I'm not sure about the last time it was lubed. I looked online at the manual and it doesn't say anything about lubing the belt...but I will certainly look into it.
    Also, since it was just moved, the part about the magnet for the speed sensor assembly might make sense too. Where do I look for this?
    Thank you!
    Kim
  • Anonymous Mar 20, 2014
    I have a proform520X. The belt seems to make a squealing high pitch wine when you walk on it.
  • 10,515 Answers
Hi
When was the last time you lubed the belt?
First not all the treadmill belts require lubrication some are self lubricating and some need external lubrication.
Check with the manufacturer or the manual as to what type of lubricant is needed for your treadmill.
The lubricants that you will find in the market are generally made up of one of two materials- wax or silicon. They should be made from a non-petroleum base. It is very important to use the most suitable lubricant as any wrong pick can degrade the working of the belt, and over all machine. Similarly, excessive lubrication is also not good.
Maintenance kits for your treadmills are easily available on any good online store and retail sports outlets. For walkers, lubrication is required once every year and for the serious runners twice a year.
Spray the underside of the treadmill belt. On some models this can be down by just lifting the side of the mat and spraying underneath from each side. Go down the entire length of the belt that is available when the machine is off.
It could be that you have a faulty speed sensor or one of the magnets has fallen off the speed sensor assembly. That certainly would make it behave erratically... The other thing to check are all cable connections, both to the console and the speed sensor and motor.
It could be a collapsed bearing in the motor but this is very rare, usually the motors have a lifetime guarantee..
I do not know of any "recycle" program though most places will take a faulty unit as a tradein on a new one.
It shouldn't be too expensive to repair your treadmill, a handyman armed with the information I just gave should be able to repair this unit...
If you don't want the treadmill anymore and don't want to repair it then put it up for sale on ebay carefully detailing the fault symptom, you will be surprised what you will get for it...
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 24, 2011
  • taran_2005
    taran_2005 May 24, 2011
    Thanks for your response!!
    I would be able to tell you, however the major problem seems to belt. Kindly lube the treadmill and see, if that helps. This is a major problem and might be a possibility that the last owner might not have lubed the treadmill as it could be in store for few months.
    Let me know,once done.
    Hope i helped you.
Dryer is making a high pitched squealing sound when started,this stops after it runs for about 5-10mins
The belt tension adjustment is allowing too much slack so the belt slips on the motor pulley.
Aug 13, 2016 | Dryers
Blower fan makes a high pitch squeal.Replaced fan but squeal is still there.
'high pitched squeal' sounds like the serpentine belt on the water pump, not the heater fan.
Dec 17, 2015 | 2011 Hyundai Tucson
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
High pitch grinding noise coming from motor when starting idling or driving
Seven ways to pinpoint that high-pitched, whining noise
www.losaltosonline.com/special-sections2/sections/on-the-road/45742-
Oct 2, 2013 - I recently had new fan belts installed after hearing a high-pitched, ... Do you hear the noise when the engine is running and the vehicle ... Just replaced water pump (and timing belt) yesterday and squeal ... When driving it make a noise but change out and caught speed the noise is coming from driver side.Missing: 1999 ‎plymouth ‎breeze
What is causing that irritating noise? ' DSMtuners
Troubleshooting Strange Sounds Coming from Your ...
www.dummies.com/.../troubleshooting-strange-sounds-coming-from-yo...
You hear a high-pitched squeal that stops when you shut off your engine: Readjust or replace the belt. These belts should have about half an inch of play and ...Missing: 1999 ‎plymouth ‎breeze
Nov 25, 2015 | 1999 Plymouth Breeze
I have a high pitch squeal from 1998 buick 3.8, told it was water pump, changed, still same, changed belt due to squeal, but still have same sound. Turned on n off a/c comp but did not change anything....
i have the same problem, changed the alternator, pulley and all that, it happened after i had the intake changed out due to the egr problem, if yours hasn't been changed id look into it before it goes, better sooner than later sorta things...
Feb 15, 2011 | 1998 Buick Park Avenue
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
My car is making a whisling sound when started.
hi ,,two things 1- water pump. but most likely check your pulleys they will make that high pitch noise one of them fixing to go bad and what will happen the belt will jam and jump lose and will lose all power ,,cause you have one belt for alt and the water pump mostly its the pulley right under the alt ,,hope this will help ....Joe
Aug 04, 2009 | 1996 BMW 318
High pitch squeal
sounds like the tensioner for the belts is worn
Apr 08, 2009 | 1996 Geo Tracker 2 Door
RCA HD52W59 makes a high pitch internal squeal sound
coil LL0037 resolder then with a glue gun glue top of coil and down.OR replace coil.
Feb 17, 2009 | RCA HD52W59 HDTV Projection Television
Black screen, high pitched squeal
A set that has only a 1/2 inch bright line through the middle of the picture, from left to right, has a vertical output IC that is not working correctly. If the 1/2 inch line is in the middle but going up and down, then the horizontal yoke circuit has stopped working. These are problems which should be looked at by a qualified tech, but if the set was purchased 6 months ago then it should still be under the manufacturer's warranty.
Aug 29, 2007 | Philips Magnavox 20MT4405 20" TV
Nordic Track NordicTrack Treadmill, A2550 Logo
57 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
