Question about Mtd Garden Tiller (Mtd)
Engine works but tines do not engage - Mtd Garden Tiller (Mtd)
3 Suggested Answers
harlan301
  • 205 Answers
SOURCE: Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Posted on Oct 13, 2009
  • 221 Answers
SOURCE: mtd rear tines tiller won't engage tines. F and R
It sounds like the shift shaft or something in the gearbox the shift shaft engages. I know you didn't want to hear this but it is not uncommon. Most operators don't use the clutch bail when starting, stopping, and shifting as they should.
I hate to say it but this may require a trip to your service center for repair.
Posted on Apr 30, 2010
Tires and tines will not engage
model number would be VERY helpful here because craftsman made many different styles/models throughout the years
Nov 28, 2013 | Craftsman Garden
I have a Yard Machine rear tine tiller that has sat unused for 4 years. I replaced the engine and while in goes forward and backward, when I engage the tines they won't rotate and the engine bogs
Transmission/differential.
Perhaps the unit sat for 4 years because the tines would not turn and your replacement engine has not solved the real problem.
I'd say disassemble the chain case to discover what's locking the tine drive.
Apr 12, 2013 | Garden
Tines continue to work with out touching safety or throttle. they engage as soon as I start the engine.
remove H (high) L (low) plastic caps to allow you to further adjust the flow and you will be going. H (red) further out about 11 threads exposed and L (low) about 8 exposed; adjusting the low side will stop the tines, but remove tines before making any adjustments, thanks
Apr 20, 2011 | Mantis 2-Cycle Tiller
The tiller won't stay in gear for the tines to turn. It jumps into forward without turning the tines.
Check the wire to make sure that when you engage the tines it is actually engaging the lever. This seems like your are either low on the fluid for the trans or it is stuck in place and will need some good lubrication and turned by hand. You can also with the engine off, engage the tines, and try to turn it by hand. if it turns by hand then the tarns is no good.
Nov 09, 2010 | Yard Machines 21A240M000 Garden Tiller
Have a sears craftsman 6.0 rear tine tiller.
Hi little,
The 7.0 hp version does the same thing.
I found that it was caused by the transmission not being fully engaged to a particular setting. when it tries to engage the tines in both forward and reverse, the engine stalls immediately.
After taking to neutral and back a few dozen times I got a 'feel' for it. Has happened in over a year.
Try it. It did take patience.
Best regards
Jul 16, 2010 | Craftsman Rear Mount Tiller
Mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Apr 23, 2010 | Mtd Products Yard Machines 158CC Tiller
Engine stalls when engaging cultivator tines
im 99 percent sure all you have to do is get the carburator cleaned out.
Jun 28, 2009 | Troy-Bilt Garden
Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Mar 22, 2009 | Craftsman 8.50 Torque Rating Dual...
Mtd Garden Tiller (Mtd) Logo
144 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
