Question about Jensen VM9424 Car Video Player
I have a Jensen VM9424 that was installed in my 2010 Subaru Impreza a little over a month ago. This morning when I turned the car on, the unit beeped rapidly and only a white screen would come up. I tried the reset button, but still only get the white screen.
  • 2 more comments
  • tburton485 May 24, 2011
    I purchased the unit from amazon on 3/31, and it was installed at my local Best Buy on 4/18.
    Yes, that is correct. When I push the reset button, the screen goes to black, and then comes back to white. The usual "Jensen" welcome screen does not appear.
    I see nothing but a white screen. When I press the reset, the screen goes black momentarily and then returns to white.
    I get nothing but a white screen, and rapid beeping that seems to stop after a few minutes, but starts up again randomly. Pressing the reset turns the screen black momentarily, but then it returns to white.
    Top Expert:
  • Jensen Master
  • 75,417 Answers
Hello
Its video output IC has damaged. It is composed of an IC [SMD]; Surface Mount Device; and cannot be replaced by normal desoldering and soldering methods. It needs automatic desoldering resoldering machine. Moreover, the circuit board inside it will be very compact, and need special care and attention to disassembe and reassemble it. This is not a user repairable trouble. OK.
Posted on May 24, 2011
  • The Knight
    The Knight May 24, 2011
    Also check these:- Check wiring and correct. Stop vehicle in safe place and apply
    parking brake. Incorrect connection to the parking brake wire or parking brake is not engaged, this type of fault may alos occur. The most common is Video processor IC failure itelf.
  • The Knight
    Hello -- The Fixya site informs me that you have send a comment to me. But I can't see none.
  • 10,515 Answers
How old is the unit?
As soon as you turn it on you get nothing but a white screen and no matter what you do it has a white screen correct?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    taran_2005 May 24, 2011
    Thanks for your response!!
    Kindly provide the answer to the other question i asked :-
    Hope i helped you.
Changed light bulb on 1993 subaru impreza now car won't start, everything lit up on the dashboard
1993 Subaru Impreza Won't Start! - NASIOC
forums.nasioc.com > ... > NASIOC Technical > Service & Maintenance
Sep 12, 2004 - 3 posts - ‎3 authors The car has been running fine, but recently in the morning especially, it won't turn over. I crank it and its trying to start, but there is no spark. Car won't start, cranks but no start. - NASIOC - North ...
Aug 26, 2013
car wont start, getting fuel and spark - NASIOC - North ...
May 22, 2012
HELP: Car won't start after timing belt change - NASIOC ...
Sep 23, 2008
Weird starting problem--1993 Impreza - NASIOC ...
Mar 4, 2003
More results from forums.nasioc.com
my 1993 impreza wrx wont start please help - ClubWRX.net
www.clubwrx.net/.../134323378-my-1993-impreza-wrx-wont-start-pleas...
Dec 5, 2009 - 7 posts - ‎2 authors can anyone help me, my 1993 impreza wrx wont start, 2 days ago i went to ...ClubWRX Forum - Subaru Impreza WRX and STi Community and ...
Oct 24, 2015 | 1993 Subaru Impreza
Lines on screen
The screen has a connection for each line on the display and the soldier on some of these connections has gone intermittent. When the unit becomes warm enough, the soldier expands and the connections become more consistent.
If you're skilled, this can be repaired. If not, either replace the unit or take it to a reputable technician.
Nov 01, 2017 | Jensen VM9424 Car Video Player
Vm9424 unit will not power on pressed reset button and it beeps and lights around function buttons come on and go back off fan comes on for about 10 seconds and turns off checked power ground fuses.is...
Hello lumberjack623,
When the jensen starts acting this way, it is simply a power problem. The device is not receiving power from the main source. The battery is weak and need to be charged before the unit can turn on once again. The battery power is too low to turn the unit on.
Try to check the power source or the connection to the power source. It is not charging the players battery. You need to have the connection port replaced. Also the power connection needs be checked.
The battery is simply weak that is why it goes right off when it comes on.
Hope this was helpful to you. All the best Elect_Comp
Sep 06, 2011 | Jensen VM9424 Car Video Player
My Jensen VW9424 Navi unit doesn't keep the correct time. The unit displayed a time 30 minutes ahead of the correct time after installation. Several attempts have been made to set the correct time;...
you have to turn off the gps time there is a setting in the menu that you turn off navigation sync or something like that. Go to setup and nav time. It is whatever setting has to do with navigation time
May 25, 2011 | Jensen VM9424 Car Video Player
Problems with lights and steering in '97 Subaru Impreza Wagon
there ie a switch for parking lights on top of steering column ..i bump it all the time!
Sep 28, 2009 | 2007 Subaru Impreza Outback Sport Wagon
The Subaru impreza will start but will not go into gear. has
sounds like internal trans leak ,fluid pressure bleeding down in trans,loss of fluid pressure means no go,check valve for torque convertor may also be bad,hopefully fluid has been checked ,does trans control unit store any codes?
Jul 17, 2009 | 2005 Subaru Impreza
'93 subaru impreza wont start
If it's quiet enough, turn the key to the "on" position without cranking it, then stop and listen for a humming or buzzing sound. If you don't hear it, your fuel pump may be having issues.
Jan 04, 2018 | 1993 Subaru Impreza
Jensen VM9424 Car Video Player Logo
287 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
