Question about Kenmore 30 in. 33202 / 33204 / 33209 Gas Cooktop
How can I adjust the flame on the simmer burner to be lower? It seems to be too much flame for a simmer. Otherwise cook top is working great.
  • Kenmore Master
  • 43,501 Answers
Where the gas comes into the stove, there is a regulator. Have a service person check the incomeing gas pressure after the regulator with a manometer. Sounds like you are getting too much gas pressure to the range.
heatman101
Posted on May 24, 2011
Does model XFG371LVQ Whirlpool stove have air adjustment for top burners?
Remove the front panel to find where the gas injectors enter the burner tubes you will see they are cut away and have a screw holding an outer ring which is adjustable, open them up more to get more air in .
May 16, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
The flame is too high on my GE Profile gas cooktop
I had the same issue on my jgp975 and sadly I had to purchase a different unit. I use simmer frequently and I made the assumption that low was simmer. Wrong. I believe a true simmer is 450 btu and my unit did not go that low. I had to check the fine print/specs page and on some units the manufacturer had to be called. I did replace with another ge profile that did have the low setting.
Apr 06, 2010 | GE 36 in.JGP970 Gas Cooktop
Simmer is too hot
one way is the orfice that goes inside the burner.some have a little screwin the knob shaft to ajust.if no screw its the orficc.theres a tech sheet that will give you more detail about that on that stove.bottem drawer area or back.also so ranges have orfices on them in the back also.God bless,tom
Jan 01, 2009 | GE 36 in. Profile JGP962 Gas Cooktop
DCS Range Ignition problem
I agree with two of the reviews here. Every so often after a good cleaning, or most recently after some oil spilled over, I had a burner that wouldn't light. All of them clicked, but the one I wanted didn't light. So after reading the above posts, I unscrew the hex nut, removed the shimmer ring, and cleaned it, and mopped up a bunch of oil under where the ring sits. Put everything back together and lit it manually. After 30 secs of flame I shut it down and tried to light it automatically. It worked! Looks like, thanks to some folks here, that I saved myself an annoying phone call and possible repair bill!
Aug 18, 2008 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Extra low burner that won't ignite
Lowly what the potentior does is turn on the burner control system. When you turn on a normal burner you are opening a gas valve and closing a switch to generate a spark. Thus gas flow to the burner and spark. On the extra low simmer burner there is a electric solenoid between the burner head and the gas valve. this has to open as well for gas to flow. What the potentior does is signal the simmer control what level of flame you are requesting and telling the spark module to generate a spark. Once you go to the exlow setting the potentior tells the simmer control what level of heat and will cycle the flame on and off. So when the burner knob was between low and extra low, the flame would cycle on and off. You have to seperate the top section of the cooktop from the burner box to change the potentior for it sits on top of the gas valve for that burner.
Aug 10, 2008 | Thermador SGS36GS Gas Cooktop
Clogged burner on gas cooktop
lowly is it the left burners that won't lite? I only ask as depending on the model some of the Thermador cook tops had simmer control burners. This is a 3 part system on the burners. 1 a simmer control, 2 electric solenoid, 3 potentiors. When you turn on the burner the potentior tells the simmer control to send power to the gas solenoid. At the same time the unit will spark. If your unit has extra low on the left 2 burners then you have this system. The usual problem in the potentior. Hope this helps.
Aug 07, 2008 | Thermador SGS36GS Gas Cooktop
Burner goes out when cabinet door is opened!
i haven't worked on one of these models hands on but on most you can pull the burner **** and look inside you should see a tiny ***** in there hold the outer piece with a pair of pliers and take a tiny screwdriver and after turning the burner on turn the ***** to adjust the flame just enough so the suction doesn't blow the flame out on the lowest setting
Mar 08, 2008 | Cooktops
Kenmore 30 in. 33202 / 33204 / 33209 Gas Cooktop Logo
338 people viewed this question
Top Kenmore Cooktops Experts
Dan Webster
Dan Webster
jdthefixer
mcgsp
Level 1 Expert
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
