Question about Nikon Action Binocular
My Nikon Action 8 x 40CF binoculars, 6 years old, are not giving me such sharp images. I have never before used the diopter ring (at base or right eyepiece) to try and focus because the central focus ring seemed to do the job and the diopter ring has never seemed to do anything, even when the bins were new. It rrotates a short distance between -, 0 and + but when I turn it there's no visible difference between these settings. Is it not functioning? Am I using it correctly (it seems I am from consulting the rather inadequate Nikon manual).
    Problem Solver:
  • 16 Answers
Possible that the set screws are loose and not turning the eyepiece inside..other than that try cleang the lenses...larry@reichinstruments
Posted on Jun 27, 2011
I have a pair of pentax 10x42 DCF HRc binoculars that will not focus properly througn the right eyepiece. Just wondering if this is a common problem and is it worhtwhile getting repaired
The binos will rack focus both at the same distance, you need to rack focus left side to distant image with left eye only, then turn diopter focus to focus right eyepiece. Diopter focus is thinner wheel behind focus wheel
Aug 15, 2015 | Pentax DCF HRc (10x42) Binocular
By adjusting the diopter on your camera effect the image quality? I guess what I'm trying to say is, will the diopter setting effect how your camera adjusts the focus in auto or manual?
Diopter is for your eye only and does not effect the focus of the camera. By using the 1/2 down method, by pressing the photo taking button half way down, you can set the cameras focus. on some cameras this is shown where it will focus by a red square. If you change the diopter this is like adding by focal lenses for reading a book. and setting the distance your particular eye needs for eye relief. On binoculars this is done with screwing the eyepiece closer or farther away from the other lens. check out online http://en.wikipedia.org/wiki/Eyeglass_prescription this will give you more details of what a diopter is or does. Always know what setting your shooting at as well. for instance if you are on a flower setting or Macro then this is for up close work. But up close doesn't mean too close. Most cameras on Macro need to be 6 inches to 12 inches away. But if you are say 24 inches away it won't focus right so don't try to zoom in, use your optical instead of digital and simply move closer or change the settings on the camera to a different setting or it may be blurry.
Jul 24, 2011 | Cameras
Cannot focus single focus side of monarck binoculars
First you must focus the left eye on a given object with the center focus wheel. Once the left eye is sharp while looking at the same object adjust the right eye to be as sharp as possible. The right eye diopter is only meant to adjust for the small differences between the eyes.
Thomas E. Kuenzli Eagle Optics (800) 289-1132
Dec 18, 2010 | Nikon Monarch ATB 7345 Binocular
My nikon 10x50 action binoculars have developed the problem of the left and right lenses not viewing the same image. the left side view is much lower than the right. i don't know if the prism was knocked...
Common problem with binoculars after a knock. One of the prisms has shifted, putting them out of collimation (alignment). If they are very high quality or collectible they might be worth fixing. It is likely to be expensive. I have done a few pair myself, but only when it was uneconomic to have it done professionally (I have ruined a few too).
Nov 21, 2010 | Nikon Optics
I bought the 10x25 camera binoculars and only one lens will focus using the center dial. Its almost like the other one needs to be focused at the eye piece itself. The pictures are not clear and are...
It is common for binoculars to have one independently focusable eyepiece.  If one eyepiece can be rotated, then that is the case.
If that is the case, focus through the one that DOES NOT rotate using the center control until you get a sharp image on that side.  Then rotate the eyepiece on the blurry side until the blurry side is sharp.  If you succeed at this, from henceforth the center control will focus both eyes adequately
Aug 11, 2010 | Sharper Image Optics
The diopter setting eyepiece has come out of the body of my Bushnell 10X42 ''Waterproof'' binoculars, model 13-2410. I see keyways inside, but cannot screw it back in more than about 1/4 turn, which is...
The entire diopter setting eyepiece was off.I separated the eye cup from the rest of the diopter setting eyepiece, and aligned the channel guides on the lens piece to slide it into place. Then holding it in place, taking care not to gum up the lens, I experimented with how to screw in the retainer ring so that its white dot registered correctly. Finally reattach the eye cup and focus. It's like new!
Apr 10, 2010 | Bushnell Waterproof Binoculars
Nikon compact binocular 25 years old. The hinge
Does this pair have two parallel tubes with a bridge in between?
If it does, then removing the caps at the eyepiece end of each hinge will reveal a grub screw. Tightening these will add tension to the hinge and give you the proper feel once more.
Feb 28, 2010 | Nikon Optics
The focus between the two lenses is not synchronized; when I zero the eyepiece lenses and try to use the center wheel to focus, I can only get one clear image at a time.
Here's how:
Focus the left side first.
Close your left eye and now rotate the right hand eyepiece (dioptre ring) until the right hand side is clearly focused.
Open both eyes! Surprise! both sides should now be in focus simultaneously!!
Jan 29, 2010 | Nikon Action Binocular
Need right eyecup replacement for Nikon Action 10x50
contact nikon and these parts should be ordable through their customer service.
Feb 03, 2009 | Nikon Team Realtree Binocular
Nikon Action Binocular Logo
154 people viewed this question
Top Nikon Optics Experts
Mark Campeau
Level 1 Expert
Are you a Nikon Optic Expert? Answer questions, earn points and help others
