Require new drive belt and stylus for an AWA sp/07 turntable. Regards tony.
  • 5 Answers
SOURCE: Stylus for a Kenwood Belt Drive Turn table
I suggest try 'Lpgear@yahoo.com' There is a long list of Kenwoob turntable cartridges & needels. I hope you find your needel.
Posted on Sep 18, 2008
SOURCE: Stylus Needle
Do a search for Crosby turntable cd recorder.... they are the same as the AWA.... and then you can find the make of needle etc.
Sadie
Posted on Jan 29, 2009
hondo73162
  • 132 Answers
SOURCE: Technics SL-J1 turntable drive belt
Hello Cliff,
You will need 2 belts, if the turntable belt is gone the other is not far behind . One for the turntable size 23.6 inch by .188 and one for the tracking motor that is in the top cover part, is a 3.0 inch by .046 belt. best place to get them is at kenselectronics.com part numbers 1407-201 and AV-SBS3.0 if you have been checking around you will see other sizes, I have a SL-J1 and have used these and they work perfectly.
Tony
Posted on Nov 13, 2009
Grubhead
  • 5151 Answers
SOURCE: Sony Belt Drive Turntable Platen speed
Check for grease on the platter or anywhere in the mechanism. Sometimes somebody has messed around with the speed preset, there might be two. You could try adjusting them. Sometimes they are found on the underside of the turntable, covered up, or they will be on the PC board of the deck.
Posted on Jan 26, 2010
  • 256 Answers
SOURCE: model PS-LX300USB Turntable Drive Belt
Hi Norman
Normally the belt does not go through any special tensioners or anything of that nature,The belt should go directly from the spindle motor onto the inside of the platter. Hook the belt on the motor section and lay the belt open wide inside the turntable. Next, replace the platter and manouvre the belt onto the platterinside through the two large holes
Posted on Jun 08, 2010
My awa turntable with cassette, cd player and recorder (e 6906) has a problem. At the end of the tone arm, the part that holds the stylus is on an angle of about 10 to 20 degrees. The stylus is not...
This model uses a ceramic cartridge. Sometimes the stylus holding part can become damaged. It should be possible to get a new cartridge and stylus for the unit. It looks as it will either screw or just clip into the headshell. Either way look around for a replacement cartridge. If it has a number on the cartridge quote that. Remember it's a ceramic type - not magnetic.
Jan 02, 2015 | Audio Players & Recorders
Turntable won't rotate
Most likely the belt has come off. Remove the platter and check. May require new belt. Cheers John. stylus City.
Dec 20, 2013 | Audio Players & Recorders
Need to replace the belt on my JVC AL-A95 turntable
To replacea turntable drive belt.Copyright.. Styluscity.com, JohnHarrison. Nov 2011Before starting any work on yourturntable disconnect it from the mains power supply.Remove the stylus or completeheadshell to prevent any accidental stylus damage.1. Remove the rubber platter mat toexpose the platter.
2. Put your thumb and forefinger through the two round holes either side of thecentre spindle and lift the platter off. You may need to give the centrespindle a light tap (whilst applying upward pressure) with a screwdriver handleor some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter and motor pulleys with an alcoholswab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure it is sitting flatwithout any twists.
5. Flip platter over the right way up. Acorrect fitting belt will stay put and an over belt will fall off.
6. You will see 1 or 2 largerectangle or square shaped cut outs in the platter near to the outer edge. Throughone pinch up the belt and slip a finger or belt hook between the platter pulleyand the belt gripping the belt ready to fit over the motor pulley.
7. Align the centre hole of the platter with the spindle and place platter backinto position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotationto ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correctoperation.
MUSIC IS LIFE, LIVE IT LOUD.Styluscity.com cansupply replacement drive belts for all turntables
Oct 08, 2011 | JVC AL A158BK Turntable
I require a drive belt for a NEC P325E turntable. What size and type do I require, and where can I purchase one.
Hi, I will be able to supply aa new drive belt for your turntable. To determine the length remove platter and on the underside is the platter pulley where the belt runs. If you tell me the diameter of the pulley I can work it out from there. Cheers John. Styluscity@gmail.com
Jul 29, 2011 | Audio Players & Recorders
The drive belt off my AWA turntable has come off and I cannot re-configure it
undo clip on centre of deck circlip normally (round clip) remove deck platter round plastic that records sit on...when removed turn over replace drive belt if brokern . if just come of place belt around the inner circle so there are no twists etc on the belt ....look at near outer edge of platter there is a clip you can stretch belt to to hold so you can put over drive motor...(belt stretch from centre to clip creating v with the bely as you veiw from above ..locate motor on the deck noe alifn top of v with positin above motor .. when done drop down platter onto centre shaft again.gently turn the platter clock wise until belt locates correctly with deck ..replace clip and test ..if ok done ..if not repeat until you get it right....sometimes over time belts stretch so a new belt may be required ..ebay can supply most belts . type in turntable drive belt ..measur size of belt by cutting is it..(if strectched and no use) measure lenght of belt find replacement belt that is smaller than measurment .i.e nearest size ...hope this helps yammandan
Aug 19, 2010 | Audio Players & Recorders
Stylus Needle
Sadie
Jan 11, 2009 | Audio Players & Recorders
Hello Cliff,
Tony
Nov 15, 2008 | Technics SL-1210 Turntable
Belt replacement
http://www.archive.org/details/Turntable_Belt_Installation
above is a generic video that applies to almost all turntables including yours that will show how to install the belt an a few other things.
Nov 08, 2008 | Aiwa PX-E860 Turntable
Sep 18, 2008 | Kenwood KD-291RC Turntable
102 people viewed this question
 Grubhead
Grubhead
