Question about Gateway NV5470u Notebook
I would like to know if the multi card reader in my gateway nv 54 will accept a memory stick pro duo
  • Gateway Master
  • 4,806 Answers
Hi.
Yes that laptop model certainly does accept a memory stick pro duo. Click on the link that I have provided below and scroll down to Media Card Reader.
http://support.gateway.com/s/notebook/2009/gateway/nv/nv54/NV54sp2.shtml
Regards.
Posted on May 24, 2011
Won t recognize sd card
It seems that the card reader if the computer is not detecting the card. Make sure that the memory card you use is supported.
The multi-in-one card reader on the Aspire One can read and write to Secure Digital card (SD), Secure Digital High Capacity card (SDHC), MultiMediaCard (MMC), Memory Stick (MS), Memory Stick PRO (MS PRO), and xD-Picture Card (xD). Specific models of the Aspire One are also equipped with an SD Expansion slot that can read and write to Secure Digital (SD) and Secure Digital High Capacity card (SDHC) cards.
The multi-in-one card reader on the Aspire One can read and write to miniSD, microSD, Memory Stick Duo,and Memory Stick PRO Duo cards but require the use an adapter. Acer does not provide or support any memory card adapters.
You can try removing the card reader using the device manager and the reinstall it and check the operation. You may also try using the card is different computer and check. Also try using another card in the computer with the issue and check. If the issue is not resolved please revert back with the model number.
Click on the link for the information to Reinstall a Device
http://technet.microsoft.com/en-us/library/cc725782.aspx
Nov 14, 2013 | Acer Aspire Computers & Internet
When i put the memory card in the computer nothing comes up what do i need to do?
Try going to MY COMPUTER, Then click on REMOVEABLE DISK. That should bring up the memory card. Then just clink through the folders till you find your pic, etc
Nov 02, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Not able to view pictures from sandisk memory stick pro duo on my laptop when connected using card reader or by using the USB cable of the digi cam directly.
Don't know about cam (was there a software disk to install?).
As far as the reader goes you reader must be compatible with both devices.
Hope this helps
Oct 26, 2010 | SanDisk 4GB Memory Stick PRO Duo Memory...
1GB Memory Stick PRO Duo Memory Card: i have a memory stick pro duo card .... but now we...
Hi sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 17, 2010 | SanDisk 1GB Memory Stick PRO Duo Memory...
    My memory stick pro duo won't fit into either of the two computers I have available to me, because it's too small. When I try to put it in, it just seems to be way too small.
    I advise buying an inexpensive card reader, that accepts different forms of USB flash drives, including yours.
    You just plug the USB cable of this card reader into your computer, and insert your Sony memory stick.
    How about this one for an example?
    http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1187796&CatId=942
    (Scroll down the page a little, and view the animation)
    Jul 14, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
    MY PROBLEM IS THAT MY LAPTOP HAS WINDOW VISTA SYSTEM AND I CANNOT LOAD MY PHOTOS FROM MY SONY CYBERSHOT DSC P73. I NEED THE PROGRAM OR WHAT I NEED TO DO?
    To make things easier, you should buy a card reader. There are different types.
    MS Pro Card Reader - Is ONLY for the sony memory cards
    Multi Card Reader - Will read sD, xD, Ms Pro Duo, Ms Pro, Compact Flash, Smart Media, etc.
    Sony has a new memory stick out called the memory stick pro duo. Your P73 does not take this. The P73 takes the Memory Stick Pro. Which is a longer stick. You can go out to best buy or ritz camera and buy a card reader (Memory Stick Pro) and stick your memory card into the card reader and stick that into your USB port on your computer. Since it is USB, this will require NO SOFTWARE.
    Your camera came out in 2004. Vista did not come out until early 2007. A lot of software does not work with vista.
    Mar 29, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
    I have a memory Stick PRO Duo 4GB
    YEAH, YOU MAY NEED A MEMORY CARD READER to read your memory stick. because some compters have not all type of card slots. the card reader will solve your problem.
    Feb 10, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
    Stick Micro M2 Memory Card
    Don't know the size of the micro with its adapter, but if it is the size of a duo card you should be able to put your micro with adapter into a Pro adapter and this is the memory stick that most card readers accept. Sony has been pretty much backward compatible so I feel this should work. A Pro adapter runs about $10 @ Best Buy.
    Jan 12, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
    Maximum Memory Stick size I can put into my Sony DSC-N1
    Unfortunately, there is no way to change the internal card reader in the camera to accept higher density memory cards. You can find the memory stick compatibility list here: https://esupport.sony.com/perl/support-info.pl?&info_id=12 . Scroll down to the Cybershot N Series camera list. The maximum capacity memory stick is 4 GB memory stick pro or M2 Memory stick Pro. For the Memory Stick Duo, it looks like those have a maximum capacity of 2 GB.
    I hope this helps.
    Apr 14, 2017 | Sony Cyber-shot DSC-N1 Digital Camera
    Just got an ACER Aspire AS5720Z notebook. It has a 5-in-1 card reader. I have a memory Stick Pro Duo card that is extremely small. The manual says the card reader will read it. There is NO eject button...
    Hi, the memory Stick Pro Duo card is (micro), half size as you have noticed you need to buy an SD adapter card. You put your Pro Duo card into the SD card & than put it into your card reader.
    Once you see the SD adapter card on the web site you'll understand. You can buy this at a local BestBuy. Most web sites sell the adapter as a combo, you'll get a micro card & adapter.
    Click the link below.
    http://www.google.com/products?hl=en&q=Stick+Pro+Duo+adapter+only&um=1&ie=UTF-8
    Look at SanDisk 2GB Ultra II Memory Stick PRO Duo w/Adapter
    & you will understand.
    Have more questions? Just ask.
    Good Luck & Have a Great Day!
    Mar 21, 2008 | Computers & Internet
    Gateway NV5470u Notebook Logo
    244 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Matthew Spark
    Matthew Spark
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
