Question about Dometic 57915531 Air Conditioner
My ac compressor comes on even when the thermostat is on off. It starts and stops every ten/ fifteen mins when plugged in to electric. Not the fan just the compressor comes on. The unit works well other wise. It is A dOMETIC dUO/THERM ac MODEL # 57915.531
  • augie_linda May 25, 2011
    Well we finally were able to test your theory and you were right it is a faulty thermostat. Thank You for your knowledge. It seems with RVs I am learning something new all the time. I will pick up a new thermostat and have my son install it for me. Thank You again.
  • 5,370 Answers
There are 6 wires to the thermostat. That are :--- 1) Red -+7.5; 2) Yellow - cool; 3) White-furnace; 4) Blue-hi fan; 5) Brown - fan and , 6) Green - ground. ------------ When this problem of compressor starts, at that time try moving the white wire or loose the screw for yellow wire and then see, is the compressor running or does it stops. ----------- If the compressor stops running, that means the thermostat is faulty .But if still the compressor is running with yellow wire unplugged from its screw, then there is wiring issue.The short is triggering the compressor to turn on.----------or its faulty relay in the lower control box.------- Most probably its faulty thermostat or loose wire .Remove the wires clean them properly and re-connect then check, before going to replace thermostat.--------- This should help.Thanks.Helpmech.
Posted on May 24, 2011
  • raj somaiya May 25, 2011
    Thanks for the update.Helpmech.
At 100 deg.it does not shutoff automatically
If your talking about a refrigerator, it never will as its goal is to try and cool, and its trying. It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load itself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your frig is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
Oct 11, 2013 | Kitchen Appliances - Others
Ac unit runs, inside blower shuts off after 2 mins, compressor continues to run, t-stat still calling for cool
My central AC unit decided to stop on the hottest day of the year. It would start and run normally for a few minutes and then the blower would shut off. After checking the breakers, thermostat and overflow shut off (did not have one) I saw something about a blower motor capacitor. This was easy to get to and replace and my last hope before waiting for someone to come fix it. The capacitor cost $4.04 with tax and had my AC working again. Needless to say I was beyond happy. I hope this can help others with a similar problem.
May 20, 2012 | Heating & Cooling
Mystery message "wait" appears above "following schedule" display line on our Th8000. Ac does not come on even when temperature is in range. Fan operates ok. Is "wait" setting one I can reset? Maybe a...
Mystery message "wait" appears above "following schedule" display line on our Th8000. Ac does not come on even when temperature is in range. Fan operates ok. Is "wait" setting one I can reset? Maybe a compressor issue rather than thermostat? Thanks
Jun 21, 2010 | Honeywell Electronic Programmable...
How to increase the mileage of the two wheeler bajaj xcd 125 problem
i have a byke bajaj discover 150 cc if it is drived min 12 km & stucked min of 500 meters it will stop it wont start if it start also the movement is not goo in the sense of control if you are still in traffic it will get off several untill you come out of traffic later if you reduce your @ humps again it will off then we have to stop it for min of ten to fifteen min
Jun 21, 2010 | 2007 Bajaj Pulsar 150
Duro Therm. AC fan comes on but compressor takes 5 min. before
Compressor may have five minute time delay for compressor protection. Russ
Jul 19, 2009 | Dometic Rooftop RV Air Conditioner
Thermostat slow to turn AC compressor on. fan comes on but takes 5 min. before compressor comes on
Most a/c's have a 5 minute delay before the compressor turns on and they will do the same when changing from cooling or heating to cooling.
When the car is cold the air works for 10 min. then there is warm air. the compresser is ok but it stops after 10 min.
check the cooling fan might not be working and building to much pressure in the ac causing it to cut off
Jul 01, 2009 | Hyundai Motor 2002 Elantra
Fan cutting on and off every 5 mins
The only thing that is going to but the fan off is the thermostat. When the fan stops, immediately check the thermostat on the wall. See is there is power between the B terminal and the GH terminal. If none, then replace the thermostat. If there is, then replace the control board in the AC. That means that the fan relay on the printed circuit board is weak.
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
My pinguino super switches on, runs, compressor starts, supplies cold air for plus minus ten to fifteen minutes the cuts out.
IF YOUR COMPRESSOR IS WORKING FINE & THE UNIT IS GETTING COLD I WOULD HAVE TO SAY YOU HAVE A THERMOSTAT PROBLEM.
Nov 10, 2008 | DeLonghi Heating & Cooling
Dometic 57915531 Air Conditioner Logo
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
