Question about HP Office Equipment & Supplies
HP DRAFTMASTER MX PLUS HP/GL2 LANGUAGE PLOTTER PLOTTING IS MISALIGNED.CIRCLES ARE NOT ROUND. CORNERS ARE NOT CONNECTED.LETTERING IS NOT STRAIGHT
SOURCE: HP designjet 1050 C plotter system error 04c3000 25c0000
when installing a network card i am getting this error cod 04c00 00002a0a
Posted on Sep 10, 2008
  • 24 Answers
SOURCE: HP DesignJet 1050c InkJet plotting issue
Friends,
You doesn't say what application and OS versions you have, or if the printer is shared from a server or connected locally to a workstation. This is signifcant to solve the problem. Please clarify.
To make this work properly, all machines should have the HPGL driver and all drivers should have both the "Autorotate" "Inked Area" boxes ticked - both under General > Printing Preferences > Advanced AND under Advanced > Printing Defaults > Advanced.
Then you should create a paper size that is as wide as the media is wide, and longer than the longest/widest paper size you're ever going to print (6-10 feet long is OK!) - BOTH under Printing Preferences AND under Printing Defaults. This will ensure that every "odd" paper size (within media width limits) is printed without problems.
If the printer is installed on a server and shared, these settings should be done on the server - and the driver should be reinstalled on the workstations. If not, these chanvges should be done on each workstation that has access to the printer over the network.
When using older versions of AutoCAD you might have to reinstall the printer there as well for the changes to take effect.
Note: This solution has worked successfully over several years while working at HP support. The suggestion about the looong paper size may sound strange but it works!
//Al
Posted on Mar 08, 2009
SOURCE: Network Connection (LAN) for HP 650C
I have a HP 650C, I just bought a Parallel to USB adapter on Ebay. It can plug straight into a computer and then be shared. I also have network card on a HP 750C+ and have it connected straight to my router through an Ethernet connection and it works fine.
Posted on May 18, 2009
  • 99 Answers
SOURCE: hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Posted on Aug 01, 2009
  • 5603 Answers
SOURCE: max file size 450c can plot ?
You should have no trouble with the unit as additional buffering will be done in your PC if necessary. These units are a one pass rather than a whole page at a time.
Posted on Feb 18, 2010
HP 1050C Plus shuts down prior to plotting
09Bxxx is an internal error. Probably a bad Hard Drive or Main PCA board. Hopefully it's that Hard Drive because the main PCA board is EXPENSIVE.
Try replacing the Hard Drive, check to see if that fixes your problem. If not, then try replacing the Main PCA.
Sorry, and Good Luck
Sep 22, 2009 | HP DesignJet 1050c plus InkJet Printer
Hp design jet 750c plus. while plotting auto cad drawing,i command it to plot black/white (mono) but it plots all in color instead.I selected mono button on the printer as well.
Your plotter driver needs to be set to either black or greyscale. The driver will overide the settings on the plotter unless you set up the plotter in manual. ie the pen thicknesses, colour etc are set in the control panel to manual. The driver takes priority always.
Feb 20, 2009 | HP DesignJet 750c plus InkJet Printer
Incomplete Plot of PDF file
This is a common problem on the 500 range, not so common on the 1050. A quick way around the problem (using the parallel port only) is to load the HP Designjet 750c drivers. Send the drawing to the 750 using memory in computer option and it WILL print.
Jan 12, 2009 | HP DesignJet 1050c plus InkJet Printer
Incomplete plot from .pdf file - Hp DesignJet 1050C Plus
Was the plot originally done on a size D or E plotter.. A .pdf is generally not a good way to send a plot that has to be done to scale.. Can they re-send the plot in a hpgl format, or a format that you can use in another program, liks ACAD, and then print it through that program? This would provide you with some control, that a pdf document will not allow.
This is just a stab in the dark for me, but I am familiar with plotters in general, just not the many formats to print from..
Nov 19, 2008 | HP DesignJet 1050c plus InkJet Printer
1050C plotter
Here is the drivers page if you need a new set:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=33712&locale=en_US&taskId=135&prodTypeId=18972&prodSeriesId=24023
Aug 27, 2008 | HP DesignJet 1050c plus InkJet Printer
Partial plot
if connected via ethernet cable then i believe you have a bad network card, if connected via parrallel, then check to make sure the cable is not over 15 feet in length. also try to uninstall and reinstall the drivers on your computer as they sometimes become corrupt. Good luck!
Aug 17, 2008 | HP DesignJet 750c plus InkJet Printer
HP 755CM
**you need a good driver:
whilst ordinary printer drivers may treat plotters like very large, slow, desktop printers, our driver uses the native vector graphics capabilities of your large format plotter to render CAD and line drawings at maximum speed.
Go here
www.plotterdriver.it
Third Party Product;
and they are those recommended from HP, Autodesk and work great with Corel Draw, Power Point, Micrografx Designer, EXCELL, Lotus, Word and all vectorial-oriented Windows applications, under W95, W98, WME, NT 4.0, W2000, WinXP, Win VISTA.
You'll find all informations
Aug 08, 2008 | HP DesignJet 750c plus InkJet Printer
'Cartridges Missing' error. I have just replaced the belt on my 750c plus and reassembled. However when I restarted the plotter, the plotter does not recognise the print cartridges promoting 'Cartridges...
HP 750C Black cartridge quit in the middle of plotting chart. Replaced black cartridge & does not make contact with something. Cleaned contacts, turned off plotter, disconneted cables, reconnected & turned back on. Still says that black cartridge is missing. HELP!
Dec 11, 2007 | HP DesignJet 750c plus InkJet Printer
Plug it directly into the router and set the printer up on your Win2k/Xp as a network printer via the new printer wizard. The router will allow it to pull an IP number and you will find it on the network that way. It does not have USB because it was meant as an office printer and the option was network adaptor when purchased. If you look at the card in it, you can see it can be swapped out for another adaptor.
Apr 26, 2007 | HP DesignJet 750c plus InkJet Printer
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
