I have a kenmore elite catalyst washer 20052992 it acts like it has a mind of its own. it beeps all day long. its stuck on pf right now and wont let me do anythings else. when it does work it only wants to work on perminate press. can you help me figure out how toget my washer to worl
  • 3 Answers
SOURCE: Kenmore Sedona Elite 3.8 Cubic Foot HE4t Washer (Front-Loading) 45089
open lower front with a starshaped bit(screwdriver) three small screws, to get to white plastic cleanout (easy to turn by hand)may have someting stuck in it. about a gallon of water is there so have two big towels ready to soak it up.
Posted on Dec 29, 2007
  • 1028 Answers
SOURCE: need diagnostic test for Kenmore
pick any button but power or pause (spin works ok) pres and hold 3 sec release 3 sec hold 3 sec release 3 sec hold 3 sec this will put intio diagnostics usually if a fault code is stored this will show first press same button to step through post fault code if any asap and will try to help may to try several times to get into diagnostics
Posted on Jun 22, 2008
SOURCE: Kenmore Elite Catalyst beeps all the time
I have the same problem. My machine beeps through the whole washing cycle, then at the end of the cycle it stops. All the lights comet on with 10 min on the display.
it does start to beep for no reason. in the middle of day or night.
any suggestions would be appreciated.
Posted on Nov 21, 2008
  • 360 Answers
SOURCE: Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Posted on Mar 10, 2009
jimappliance
  • 42 Answers
SOURCE: Kenmore Elite Catalyst washing machine getting error F4
See if this helps.
http://www.askmehelpdesk.com/appliances/washer-kenmore-elite-catalyst-110-20092993-f3-f4-error-codes-191730.html
Posted on Aug 01, 2009
We have a kenmore elite oasis dryer.one year old.just bought from some people only had it for two days.it was in the middle of a cycle when it suddenly shut off with the code af appearing where the timer...
An "AF" code means there is a low airflow condition and the clothes may not dry properly. To remedy this, check to make sure the lint screen is cleaned off and that there is no blockage in either the vent duct that runs from the dryer to the wall or the vent hood on the exterior of the house.
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2010 | Kenmore Elite Oasis ST 6807 Dryer
Kenmore catalyst elite washer fills but does not
the reset is to unplug the washer for 5 minutes, if that doesn't reset it u may have a defective motor controller circuit board
Aug 02, 2010 | Kenmore Elite HE4 Electric Dryer
Have Kenmore Elite Catalyst Washer showing F3.
I have a top load Kenmore Gold Catalyst Cleaning Action washer that is stuck on permanent press mode. The digital display reads 8 min. and will not turn off or clear.When it is turned on the, the timer goes to 37 minutes and beeps repeatedly through all cycles. It will not clear even when I unplug it. How do I fix this annoying thing!!? Thoughts please.
Bill
May 22, 2010 | Kenmore Washing Machines
Kenmore Elite Catalyst Washer Keeps beeping and displays 10
I'm not sure if you've solved this already but our Kenmore Elite washer had a similar problem that got worse. It ended up being the whole touch panel had to be replaced. I was able to diagnose and replaced it myself with help from the Tech sheet that is underneath the touch panel. Our Kenmore Elite dryer also had to have this paenl replaced several years ago when it was fairly new. Hope this helps.
Sep 08, 2009 | Kenmore 3.2 cu. ft. Top Load Washer
See if this helps.
Aug 01, 2009 | Kenmore Washing Machines
Kenmore elite top loader washer won't start. Power is ok at the outlet Unit is 9 years old, model #110-20096993. Unit worked yesterday. It is a sensor smart three speed automatic washer with catalyst
Actually I didn't need a solution. The unit would not start. It was like no power was coming in. The outlet was good and usually if there is a power failute the unit flashes PF. Well I walked by in a couple hours later and and touched the start button and it worked. Got two loads of wash in. It must
have a loose connection or a dirty connector, but I'll wait until it happens again
Thanks
Jun 23, 2009 | Kenmore Elite 45986 Front Load Washer
When I plug the machine in it either does nothing or flashes PF then acts as if there is no power. It is the machine not the outlet.
PF just means your house has experienced a power failure since you last used the machine.
Unplug it for 40 minutes to reset.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Catalyst's control panel is flashing "PF"
PF means power failure
the power must have went out in your home some time during the day or night
Jun 21, 2006 | Kenmore 23822 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
