Question about Samsung Televison & Video
Samsung TV LN-T4061F takes too long to turn on
  • Samsung Master
  • 2,098 Answers
This is an indication of out-of-regulation in the power supply section. This was caused by leaky/dried electrolytic capacitor in that section. It will drop the supply from normal voltage and will disable the unit.It needs a little warm-up to make itself stable but the symptom will get worst until tv will not power up at all. Sometimes it has a bulged/dome at the top but not all, it is better that you have a capacitor checker/tester to determine its condition. Your unit will back to normal again if the leaky capacitor is isolated.
If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
Also check if your unit is under warranty /extended warranty, avail it because the manufacturer of your unit will fix it for free. Don't open the back panel, this will void the warranty.
Let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 23, 2011
Samung LN-T4061F - Dim Picture
Does it look like a dim black swirling cloud with very faint images?
Mar 24, 2012 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung Model 2007 LN-T4061F takes up to 30 min to turn on and there is a clicking sound
Failed capacitors on the main power supply. You will need to open the tv and look for these:
Replace with the same uF value and a higher voltage value.
Thank you!
May 11, 2011 | Samsung Televison & Video
Our 4 year old hit the front of our LN -T4061F Samsung set with a plastic ball. It now has a shattered imprint that is black with white shatter marks and ranbow stripes...any chance the repair is less...
Sadly, the screen is the most expensive part of the TV. The replacement screen would cost more than the TV is worth. Shopjimmy.com is the only affordable place to buy the replacement screen, But, they are out of stock. Usually, the screen cost around $250 to $350. Any other website will cost an arm and a leg. Buying a new TV would be best at this point.
http://www.shopjimmy.com/catalogsearch/result/?q=LN+-T4061F+screen
Nov 16, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
My samsung l n-t4061f/ln 40 inch tv has rainbow dots on the screen and when i turn it on it has vertical pinks stripes on the screen.need your help
The problem was solve my power chip or piece burnout.So iam taking it to the shop to have it fix.Thanks for all your help
Nov 15, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung LN-T4032H
This is the capicator $1.50. You have to take off the back, sauter off the capicator (you'll see it because it is poking out) and sauter on the new one. I found the fix on this web-site.
Oct 01, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Why, is my Samsung LN-T4061F taking longer and longer to turn on?
most likely the lamp or inverter is bad.
Check to make sure each lamp is inserted properly into it's socket and make sure each wire that goes to each lamp is not loose.
The inverter maybe going bad as well.
Aug 14, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
LOUD Volume when turned on, LN-T4061F
You probably have a bad Main bd. It is not remembering the last setting it was set to. Also, there might be a Firmware upgrade for this problem. Contact 1-800-Samsung and ask for tech support to see if they have a Firm ware upgrade for your model. They can send it to you in the form of a Flash drive or you can download it from the Samsung website into a flash drive and then plug it into the USB port on the tv.Follow the indtrustions to a tee.
Jul 10, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
LN-T4061F Goes black after a couple of minutes.
The T-Con bd is probably going bad. Also the Main bd could be bad. Have a trained samsung tech troubleshoot the set.
Jul 07, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Best Picture Quality
Check this link out. I think it should give you all the info you need for optimal picture settings.
http://help.cnet.com/samsung_LN_T4061/9602-12576_39-0.html?messageID=2510125&tag=tip-2510125&kw=samsung+LN-T4061
Nov 13, 2007 | Samsung LN-T4061F 40 in. LCD HDTV
Televison & Video Logo
54 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
