Question about Hampton Bay 24750 Huntington III Ceiling Fan
Remote works (tested on another fan in the house) neither the light or the fan activates with the remote. Took the bottom part off and tested successfully for power. Help!!! (the light switch is on!)
  • saliforth54 May 24, 2011
    Thanks for your help! I will take the fan apart from the ceiling this time instead of just the base of the lamp and give that a try. Appreciate you taking the time to respond, will report results!
  • 6,674 Answers
Sounds like the transponder under the cover at the light is defective. Try pointing remote at transponder when cover at ceiling is off and lowered . Check all connections at transponder as well. Power off to check connections.
Posted on May 23, 2011
    Thanks for taking the time to help. Will take apart the entire fan from the ceilling this time and give it a try. Will report results.
Casa Endeavor fan works, light does not. Installed new receiver and tested remote both are good. Took the light to a repair shop, light works there, just not once attached to fan in the ceiling.
If your fixture has pull chains in addition to remote control operation can get the remote control confused. Try experimenting to find a procedure that works and follow it consistently. Also, a power outage can disrupt the whole routine.
Mar 13, 2017 | Dryers
The hand held remote no longer activates the ceiling fan or the light. I know I have power to the unit and know that the battery in the remote is ok. When I press the remote for the fan or lite the red...
If you only change the battery in the hand-held remote, there should be another one in the fan housing that also needs changing. Always change all the batteries at the same time.
Apr 04, 2011 | Hampton Bay Heating & Cooling
Fan remote does not work. thought it might be the battery. not !
By the sound of it, it could be a wiring issue. Im assuming its hardwired to the house. If you feel comfortable enough, i would suggest checking the connection to the fan motor a long with the connections to the lights.(The bulbs might just be burned out too) If that looks okay. You said the remote wasnt working. Im assuming you have an alternate method of operating the fan, perhaps a typical "light" switch. Once again if you feel comfortable you could test that switch, it may be bad.
Bottom line, if you dont feel comfortable messing with electricity as many do, Call an electrician out. The fans can get expensive and it seems pretty new still. They can diaginose it for you relatively cheap.
Aug 09, 2009 | Hampton Bay 04345 Cruiser Ceiling Fan
Ceiling fan with lights on the remote works and have multiple fans in the house with the same remote but when u turn the lights off to this fan the fan wont run
on the back of the remote, by the battery there are little numbers 1-4 and the fan hast the same just change the numbers to each fan and remote
Jun 28, 2009 | Hampton Bay 52 In.Carriage House II in...
Unable to get fan to respond to remote Hampton Bay 54
these fans must be reset as follows remove the battery from the remote manually turn off the wall power switch put the batteries back in the remote turn on the wall power switch press the remote buttons...if this doesn't work let me know
Jun 01, 2009 | Universal Remote Control Hampton Bay...
Remote not controling fan
You either have a bad receiver or the receiver isn't wired correctly,
On the receiver house wire side are black, white, and green.
On the receiver fan side are white, black, blue, and green. The black is hot for the fan, the blue is hot for the light. They can be wired together from receiver to fan.
At the bottom are a blue and a white wire to go to the lights.
Sometimes when installed the receiver is placed so that a part of the wiring box obstructs the signal from the remote and it doesn't work properly, or misses some commands.
I recommend buying a new remote and receiver and wiring the receiver in so that it rests on the sheetrock beside the wire in box.
May 25, 2009 | Hunter Ceiling Fan Remote Receiver...
Hunter Fan - Remote
Most likely the fan turns on with a wall switch and then as long as the power is there [ wall switch left in on position], the remote works
Apr 26, 2009 | Universal Remote Control Hampton Bay...
Fan works, light doesn't on Hunter ceiling fan
I would begin by testing each bulb in a different socket somewhere in the house.
Apr 06, 2009 | Hunter 27187 Remote Control
Casa Vieja Intrepid Remote Control Sensing Problem
you need the same sensors in the remote as the one ur using now the old sensors will not work
Jul 05, 2008 | Casa Vieja Probe White Ceiling Fan
Diminished light
When our 2-year-old niece got hold of our Hampton Bay fan remote, we learned from her actions that holding down the button that controls the upper or lower light will, after a pause, either brighten or dim that light. Our fan is older than yours, but perhaps yours works the same way?
Apr 23, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay 24750 Huntington III Ceiling Fan Logo
54 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
