Question about Sylvania LC225SSX LCD TV
Sylvania lc225ssx tv volume turns itself up and down
5 Suggested Answers
  • 10 Answers
SOURCE: Comcast remote cannot operate Funai/Sylvania
Currently there are no remotes nor any codes for them that will operate virtually any sylvania tv's. sorry, it's like the only model we have no resource for as of yet. -Comcast Tech
Posted on Oct 19, 2009
  • 286 Answers
SOURCE: ViewSonic N2750w 27 in Volume turns down by itself
Could be a problem with the down volume button on the tv. the board it's on ir its harness. Check them all. Make sure the volume buttons plastic actuator moves freely and is not stuck.
If these parts are all good, you have a problem on the main board. You may have to trace the control lines as far as you can and check any capacitors along the way. If you have an oscilliscope you can test the lines to see if the up volume is working correctly. If there is noise on it, you might find a bad capacitor if you can trace it back far enough. Schematic helps here.
Of course, make sure nothing is shining on the sensor window on the TV. You might want to scope that line as well (IR sensor line).
If none of that helps, get hold of Viewsonic and find your closest service provider. You can order a main board from them.
Of course, you could try just using the audio out jacks to an amplifier or a surround sound amplifer. Then you would use the remotecontrol for the surround sound system to control your volume.
Bet you were going to buy one anyway right?
Posted on Feb 14, 2008
SOURCE: Volume n my tv keeps going down
same
Posted on Apr 15, 2008
  • 34 Answers
SOURCE: My Sylvania LC225SSX tv won't accept a code for my UVerse remote
Try codes for both Emerson & Funi
Posted on Nov 08, 2009
LCD TV won't stay on when turned on.
Please provide more details. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 12, 2014 | Sylvania LC225SSX LCD TV
Code for sylvania LC225SSX
Explain please which code for what purpose are you looking for.
Jun 15, 2012 | Sylvania Televison & Video
Tv will not turn on
well i have the same the proble with my sylvania plaza t.v however when i plugg it in into the socket the red light blinks then the green light comes on but then it just turns off completley...and the red light is still on ? is there a way to fix this problem or is the t.v permently broken??
Jan 13, 2012 | Sylvania LC225SSX LCD TV
My tv turn off by itself all time, sometimes Its just turning on when it turn off,sometimes happens after 10 minutes
Hmmmmm.......My ratings are slipping so this will require a serious answer! The solution I will give you will be of most accuracy. Your power supply startup resistors are are bad. These are located on the inverter board. Replace the inverter board or if you are up to it replace R603,604, and 605 with 390K quarter watt resistors. If the values are different or the same as mentioned, use the values I just told you! If they look fine or test fine...replace them with the value just mentioned!!!!!! Anyway!!!!!! Take this info to a TV tech and show him your answer. Thanks for asking me!
Aug 08, 2010 | Sylvania LC225SSX LCD TV
The tv isnt turning on at all what is the problem
Targa 32" LCT TV, No picture/ sound only can hear clicking sound from Kisan KP-301R Power supply board. Have checked output voltages and they are a little out i.e. 16v instead of 17.5v and 10.5v instead of 12v.
Has SAMWHA capacitors but cannot see any bulging or leakage anywhere like other users have suffered so dont know if changing all the caps will solve the issue.
Before it finally went dead LCD TV would switch itself off after some time and just a few days before it dies it started the clicking sound but would then start up okay.
Jun 18, 2010 | Sylvania LC225SSX LCD TV
Describe your sylvania lc225ssx green screen Problem Screen goes green occasionally. Switching to an HD channel then back usually corrects for a while. Sometimes power-cycle also temp fix.
Whenever I hear "green screen" it is a loose or faulty HD cable(s).
Check your HD connections to make sure they are inserted fully and if there is no change, try an alternate cable.
Jun 17, 2010 | Sylvania LC225SSX LCD TV
My comcast cable remote doesnt have a code to work my sylvania tv.
hi! i have here a couple of codes for your tv! just try them 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483,1046, 1465,1150, 2092, 1464, 2408, 1465, 2260, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095, hope this helps!!! goodluck!!!
Feb 09, 2010 | Sylvania LC225SSX LCD TV
Need code to make Echostar dish network dvr remote 6.3 to work with tv modle number LC225SSX
We would be happy to help you with getting your DISH Networkremote to control your Sylvania TV. We're going to start by pressing and holding the TVbutton located on the top of your remote until all mode button back lights comeon, and then release. Use the number buttons to enter the codes for your Sylvania TV; here are some of the codes we currently have: 733, 672, 777, and 569. Press the pound (#) button. To check if the code works try severaldifferent functions on the remote to make sure it will properly operate your TV.Remember that some codes may not be compatible with your equipment. If this isthe case, try the other codes listed for your Sylvania TV until you findone that is compatible with it.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Feb 08, 2010 | Sylvania LC225SSX LCD TV
Sylvania lc225ssx pc imput from inspiron e1405
You have to set the resolution of your laptop to that of the TV can support. Trun off the laptop and the TV, then hook up the TV to the VGA prot of the laptop, then tun the TV on first then the laptop, hopefully the laptop will recognize the TV and allow you to set up the correct resolution on the laptop.
Nov 11, 2009 | Televison & Video
Sylvania LC225SSX LCD TV Logo
265 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
