Getting init message. tray will not open or spin. all buttons when pushed on machine give same message (init,please wait then close).select button on remote also does not work.
  • saharabravo3 May 24, 2011
    Panasonic Model# SA-PT750
  • 794 Answers
Hi saharabravo3,
May I have the specific brand and model of your machine? I'll wait for your reply.
Thank you for using FixYa.
Posted on May 23, 2011
  • Jemalyn Labaguis May 24, 2011
    Hi saharabravo3,
    Thank yu for your reply. You may try to reset the unit by following these steps:
    1. Unplug the power cable.
    2. Wait for 2-3 minutes then, plug it back again.
    3. Turn the unit on.
    4. If after turning the machine on and still the INIT/Please Wait message appeared you have to:
    Press and hold the Tune Mode (STOP) button at the same time the # 10 from your remote control, simultaneously for 10 seconds. Wait until the error message disappears.
    5. After clearing the message, restart the machine through the on/off button.
    6. If the message was not cleared try to the whole process for several times.
    In any case that resetting does not work for your machine it can be caused by a jammed disc. To remove the jammed disc, remove the top by removing the screws and then you can remove the stuck/jammed discs. And in any instance that there's no jammed disc any inside the machine you will need to contact a local technician who can look inside the machine to check the mechanism or better if you call Panasonic's support at 1800-211-7262.
    Hope it helps.
How do i open water resovor on krups oblo coffee maker
See page 8
8
8
FIRST USE
Rinse water tank before first use.
Fill water tank with fresh, drinking water. insert
water tank to machine.
Switch machine on. Power button starts
blinking red while machine is heating up for
approx. 40 seconds. Afterwards power button
lights steady green and machine is ready.
40 sec
ON
Push selection lever to the "HOT" position.
Machine starts rinsing.
Open locking handle and insert empty capsule
holder. Close locking handle.
Place jug under outlet.
Push selection lever to the "COLD" position.
After approx. 60 seconds push selection lever
to the "STOP" position. Empty jug and refill
Make sure that the selection lever is in "STOP"
position. Then plug the power plug into a
mains power socket.
to the "STOP" position. Machine stops rinsing
and power button blinks red for about 5
seconds.
8
Place drip grid on drip tray. Then insert drip
tray at desired position of drip tray.
Then insert drip tray at desired position of machine.
Jul 02, 2017 | Krups Coffee Makers & Espresso Machines
Dvd tray will not open
Sounds like it's jammed it self up, if you got finger nails try pulling the front on the dvd drive as you push the open button, otherwise look for a little tool of some sort to wedge in the front of the dvd drive to give it alittle movement as you press the open button, it may need a bit, just be careful not to break it lol , if still no luck unscrew the sides and back if it has screws at the back , lift the top off , and push the dvd drive from in there , that will atleast get the disk out, and lets hope solve future problems ,
Nov 25, 2007 | Panasonic 600W DVD+VCR Home Theater System...
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
Hi - the CD tray cannot open. It is empty - no CDs in there. I hear a buzz, but an "error" message comes on. I tried pushing on the tray while turning on; I unplgged the CD player, I put it on...
The loading tray belt has more than likely stretched or snapped.
The buzzing you hear will be the motor spinning freely.
The 'ERROR' message will show up because the tray isn't opening
and activating the 'tray open' switch, therefore the 'tray closed' switch
is permanently activated after the 'open/close button is pressed.
Aug 20, 2011 | Marantz CC-4300 5-Disc CD Changer
Does not play when disc entered nor when play is selected. (XD-E500KB)
Hello
Push in the plug connected to the "Video Out" jack on the rear of the Dvd to ensure it is connected firmly. Check the connection at the back of the TV as well.
Press the "Source" or "Input" button on the TV remote to verify the television's input is set to the DVD connection.
Press the "open/close" button on the front of the DVD to open the disc tray. Insert and test different DVDs to determine if the problem is with a specific disc, or if the player will not operate.
Eject the DVD tray and insert the DVD laser lens cleaner. Close the tray and wait a few seconds for the cleaning disc to load. Press "Play" on the front control panel to spin the disc through the cleaning cycle.
Remove the cleaning disc, insert a DVD and test playback operation. If the machine still will not play discs, the main receiver unit may require internal repairs best left to an experienced technician.
THANK YOU FOR VISITING FIXYA
Feb 02, 2011 | Toshiba Televison & Video
Print Qualityfor DC12
I am not 100 percent what you are asking but I will answer the best I can with your question.
  1. Press the [Administration] button located above the numeric keypad on the Control Panel. The Administration button has a wrench symbol located above it. The Access screen will be displayed.
  2. Select [Tools] on the Touch Screen. The Tools Access Number screen will be displayed.
  3. Enter your numeric password using the keypad.
    NOTE: If you do not know the password, contact your administrator. The initial password at machine install is 11111.
    If the administrator encounters a problem with changing or forgetting the machine password, a service call must be placed:
  4. Select [Enter] on the Touch Screen. The Tools screen will be displayed.
  5. Select [System Image Quality]. The System Image Quality screen will be displayed.
  6. Select [Image Recognition]. The Image Recognition screen will be displayed.
  7. Select 'Screening Adjustment' by selecting the [Up] or [Down] arrow buttons.
  8. Select [Change Settings]. The Screening Adjustment screen will be displayed.
  9. Select [Apply to Copies Only] then select [Save]. The Screening Adjustment screen will be displayed.
  10. Select [Close]. The System Image Quality screen will be displayed.
  11. Select [Auto Screening Adjust]. The Auto Screening Adjust screen will be displayed.
  12. Select [Halftone Screen]. The Halftone Screen will be displayed.
  13. Select either [Halftone 200 line screen] or [Photograph 200 dpi].
    NOTE: Do not select 'Printer use' as this will effect print calibration; which will be handled directly by the color server set up to print to the copier / printer.
  14. Select [Save]. The Auto Screening Adjust screen will be displayed.
  15. Insert at least 2 sheets of white, 216 mm x 279 mm (Letter, 8.5 x 11 inch) paper in Paper Tray 5 (Bypass Tray).
  16. Select [Print Test Original] to print a sample of the settings. The message 'Please wait…Printing test original' will be displayed and the test original will print.
    NOTE: If selecting [Print Test Original] displays the message ‘System Disabled' then Screening Adjustment is disabled. Select [Close] and repeat steps 5 to 16.
  17. Open the Document Glass Cover.
  18. Place the test original face-down on the Document Glass with the two magenta squares against the left edge of the glass.
  19. Place 5 sheets of blank white paper directly on top of the test original.
  20. Close the Document Glass Cover.
  21. Select [Start Adjustment] from the Touch Screen. The message 'Please wait….Adjustment in progress' will be displayed, then the Auto Screening Adjust screen will be displayed.
  22. Select [Adjustment Complete]. The message 'Please wait…Printing current settings' will be displayed and the adjusted original will be printed.
  23. Examine the adjusted original to make sure the image quality is satisfactory and continue to the next step. If the image quality is not satisfactory repeat steps 12 through 22.
  24. Select [Close]. The System Image Quality screen will be displayed.
  25. Select [Close]. The Tools screen will be displayed.
  26. Select [Close]. The default copy screen will be displayed
Dec 27, 2007 | Xerox DocuColor 12 Printer
Playstation 2 problem
I wonder have you dropped your machine..??=) or has the tray been pulled on when its out.. because there is a plastic strip with teeth that it runs on try pushing the open/close button and pushing in on the tray. it might try to open back up on ya but just press the button again and push in on the tray...if the tray is pulled out past that point you will have to lift up on the tray and push it in at the same time with a little force to get it back on track..
Dec 13, 2007 | Sony PlayStation 2 (PS2) Console
Disc tray won't close!
i know this sounds carzy but mine just did that and i pushed it in hard but not too hard and then tried opened it and when i hit the close button it worked
Oct 27, 2007 | Microsoft Xbox 360 Console
Washer Stuck
depending on model, it sounds like a control module fault. Regards Engineer
Jul 26, 2007 | Kenmore 24032\24036 Top Load Washer
37 people viewed this question
 Grubhead
Grubhead
