Question about OfficeMax OM96124 Basic Calculator
How do i change or set new tax rates on OM96124 calculator
OM96124 - Calculator - how do I set the tax rate?
setting the Tax rate to 9%. first move the dial over to TAX then press the number 9 -SET -Tax+
Feb 01, 2011 | OfficeMax OM96124 Basic Calculator
How change percentage (tax) rate on Casio-1100TV?
FINALLY figured out how to change the tax rate! Press AC. Press and hold the Rate Set (%) button UNTIL THE CURRENT TAX RATE IS DISPLAYED. Enter the new rate you want (such as 7.5). Press the Rate Set (%) button again.
Mar 05, 2010 | Casio Office Equipment & Supplies
How to change the currency and tax rate values on
Press the red "ON" button and hold it. Press and hold the "% (SET)" button and hold it. Release the red "ON" button. Continue to hold the "% (SET)" After a few seconds, "SET" will appear at the top of the screen. Press the "TAX (TAX RATE)" button. "M TAX SET %" will appear at the top of the screen. Your current tax rate will now be shown in the display. Enter new tax rate and press the "% (SET)" button. Your new tax rate is now set.
Jan 16, 2010 | Casio Office Equipment & Supplies
Manual for Casio MS-120TE Calculator or how to program exchange rates
press AC
press RATE SET, hold for approx5 secs till you see "tax" "%" displayed
type in new rate (say 20)
press RATE SET (to confirm 20% as new tax rate)
Done
Oct 19, 2009 | Casio Office Equipment & Supplies
Casio fr-2650 plus calculator
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes:
hold set% button
hit tax+ button
change the desired %
hit set done
Do rate the solution.
Apr 05, 2009 | Casio FR-2650Plus Calculator
Change the tax rate on calculator on MS-8TV
cliff notes:
hold set% button
hit tax+ button
hit set done
Mar 23, 2009 | Casio Office Equipment & Supplies
How to change tax rate on Casio MS120TV
I found the solution listed against a different CAsio Calculator.
It was .. Press AC, then hold 'set' for a few seconds then press 'Tax+' , input new tax rate then press 'set'. Job Done
Jan 06, 2009 | Casio FR-2650Plus Calculator
Casio MS-120TE tax rate
How do I program tax rate into my calculator?
Non-printing models (also applies to HR-8TE printing calculator):
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Nov 26, 2008 | Office Equipment & Supplies
Need to change tax function on Sharp EL-334A
I had the same problem and finally figured it out. Here's what you do:
Press C-CE twice
Press +TAX (Rate set)
Key in your new tax rate as an integer (e.g. 5)
Press +Tax (Rate set) again
Press C-CE
Then you're ready to calculate with the new rate!
Now what's the GT button for?
Nov 19, 2007 | Sharp EL-334AB Calculator
How do you set a tax rate?!?!?
1. Switch off the calculator
2. Switch it on again
3. Press and hold the tax button (set %) until the display changes
4. Enter the new tax rate
5. Press the tax button (tax +)
Any problems contact dave@techsoft.uk.com - he emailed the solution to me and it has worked.
Pam
Oct 10, 2007 | Casio HR-100TMPlus Calculator
OfficeMax OM96124 Basic Calculator Logo
57 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
ROCKIT957
Randy Schumann
Randy Schumann
Colin Stickland
Colin Stickland
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
