Question about ProMariner Advanced Onboard Chargers Model Prosport 8,12/24volts, 8 Amps,2banks
How to hook up a prosport 8 2 bank charger - ProMariner Advanced Onboard Chargers Model Prosport 8,12/24volts, 8 Amps,2banks
    Problem Solver:
  • 12 Answers
Prosport owners manual download page
This should be everything you need
Posted on May 23, 2011
Where can i find wireless power bank charger?
There are many on Amazon. I use one of the RAVPower Qi wireless charger. It very convenient. http://www.amazon.com/RAVPower%C2%AE-Wireless-Qi-Enabled-Incredible-Single-Position/dp/B00DMZPQIG/ref=sr_1_1?ie=UTF8&qid=1388039458&sr=8-1&keywords=ravpower+wireless+charger
Dec 23, 2013 | Kyocera Wireless Rapid Travel Charger
How to fix my Power Bank iPhone5 case charger
  1. OUTLET CONNECTOR SOCKET IS 5 INLET,4COULERED (RED,WHITE,BLACK&BLUE) WIRESS CONNECTED DIRECTLY TO THE FAN
Oct 29, 2013 | Banks 2000 Ford F-350 - SuperCab, 8 long...
I have a Minn Kota MK 460 on board charger that the number 1 red light is on and it is not charging that battery. When you hook up to the other 2 batteries the light still continues to stay on. I had the...
is this a 3 or 4 bank charger I had the same problem but my battery was bad if you don't have the charger on the battery it goes to you will have a red light if your battery are hooked in series to check your charger disconnect the cross over wire and put charger on battery see if red light goes out if so you have charger on wrong battery or you have a bad temp.sencer in charger cord on # 1 feed
Sep 26, 2013 | Boating
I have a Prosport 20 Plus that charged 3 new trolling batts It has worked fine for 2 yrs.I found that one batt was not charging and I replaced 3 burned out fuses.The blue,red and finally the green lites...
check the cables between the batteries, and consider changing the cables that run to and through the uncharged battery. Also make sure that the batteries are not cross connected (positive to a negative) and that there is no corrosion on posts and cable connectors. I had a similar problem.
Jul 27, 2017 | ProMariner Prosport 20 Plus Gen 2 Heavy...
Unit will charge for an hour then all of the lights on the unit blink one at a time in a rapid fashion, this unit is only 6 months old!!!
You either had a lot of exposure to moisture at some time or you did not,. If you did not then get a new unit on your guarantee.
Aug 13, 2010 | ProMariner Prosport 20 Plus Gen 2 Heavy...
My simmons scope cross hairs have turned diagnally is this repairable
it is repaireable but its going to cost more that a new scope,, your one has shook its self apart,, to fix it it needs to be striped right down all the glass will need to be cleaned and after the repair it will need to be refilled with gas,,,,so its not worth the cost of a repair,,sorry
Nov 17, 2009 | Prosport Simmons 510483 3-9x32 ProSport...
I need a user manual
what kind of model you need for your optic what is the name, and make of your optic
Oct 22, 2009 | Prosport Simmons Master Series ProSport...
Boat battery charging issue
Hook up a differant bank and see if it says charged, check volts of battery must read 12.6 volts to be fully charged. If it dont bad battery
Jim OMC Retired Mech
Jul 01, 2009 | Boating
SIMMONS 3X9X32 BLACK RIFLE SCOPE
check to make sure it hasn't turned in the scope rings. I am sure if it is somewhat new simmions will fix as long as it falls within warranty
Dec 10, 2008 | Prosport Simmons 510483 3-9x32 ProSport...
ProMariner Advanced Onboard Chargers Model Prosport 8,12/24volts, 8 Amps,2banks Logo
426 people viewed this question
Top ProMariner Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a ProMariner Boating Expert? Answer questions, earn points and help others
