Question about Campbell Hausfeld Air Tools & Compressors
Model VT623101AJ motor hums and trips house breaker. With protection cover off you can turn big pulley by hand and it will run. It works intermittently. Sometimes it will cycle by itself but most of the time it will trip breaker.Water has been drained and a different place of power makes no difference.Motor is a DOERR LR22132. With power off unit turns freely by hand, no binding at all.
SOURCE: Air compressor trips motor breaker
PLEASE CHECK THE CAPACTORS ON THE MTR, THE MTR WILL BE HARDER TO START AFTER IT HAS AIR IN THE TANK
Posted on Nov 26, 2008
  • 67 Answers
SOURCE: Electric Air compressor just hums then trips breaker.
usally there is a releaf valve that takes the pressure off the compressor while it is resting. If that pressure is not off when the drive piston starts the motor will overload and blow the the breaker or reset. Check for a releaf valve for when the unit has reached full pressure
Posted on Jun 16, 2009
  • 1218 Answers
SOURCE: washer starts to spin up then trips breaker
Good day,
Not the transmission. The motor could be stalled by a defective transmission, but the motor would trip off on it's own internal long before the home breaker.
Sounds like a short in the motor itself. But ......
There is Murphy's law.
Your home breaker might have become so weak, it IS the problem.
You really need an amp probe to check the washers draw, at the circuit breaker panel.
If you cannot do that and are comfortable dealing with electrical, you can swap equal value breakers, to be sure.
Posted on Jan 03, 2010
Testimonial: "Thank you jackfrost555, you confirmed what I figured. This is a great sight and is now in my bookmarks"
john224
  • 1378 Answers
SOURCE: when I turn the pump on it buzzes the motor doesnt turn and the
Thank you for posting your question here on Fixya.com.
The motor is likely failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage even though the shaft turns freely.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 02, 2010
blueextc3221
  • 15935 Answers
SOURCE: Sears Model 110.26964503 washer -No Spin and drain
It appears your motor or motor controller board has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
The motor runs fine with the belt off but when the compressor is on line the motor hums and trips the house breaker.
Turn the compressor pump pulley by hand (with belt off) and air pressure in the tank. It should be very easy to turn. If it is hard to turn, evaluate the check valve for leak. If no leak examine crank bearings for damage. Repair as needed. If easy to turn fault is with motor. Check amp draw with belt removed. When the motor comes on, it should draw about 15 amps and drop lower. The motor should start and reach full rpm in a split second. It should start with a bang and run smoothly with-out getting hot and only pull low amount of amps. If slow start and high amp draw, check capacitor/s and or start winding switch inside of motor. Sometimes the start switch will burn the contacts and give trouble. If both capacitors test within 95% of value and start switch appears to be good, look for damaged copper windings. Windings will be discolored or burned and the tie strings binding the windings will be melted. Replace as needed. Good holidays
Dec 15, 2010 | Dewalt d55170 Electric powered air...
WHEN PRESSING START UNIT JUST HUMS
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor.If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Nov 26, 2010 | Amana Dryers
LG DLE5977W electric dryer hums when attempting to restart
This is usually the motor but not always. Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers, pulley, rear bearing, then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. You can also enter your model # for diagrams and illustrations at www.appliancehelponline.com
Mar 31, 2010 | LG DLE5977 Electric Dryer
Need a point setting for ao smith air compressor ac motor model number opa-0297 s# c56b72b2316508j2 work on air machine with motor installed motor will hum and trip breaker can we set points to stop trip...
try running up this motor when its not installed on the compressor,, if it still blows the trips the motor is faulty,, if it runs ok, but hums when reconted to the compressor the compressor if far to tight for the motor to turn the compressor,,,you can not reset the points in a breaker trip they trip at a set curent if the motor is pulling more amps than the trip is set for it will trip the trip to turn off the curent, the motor will pull far more amps than it should if its over loaded thats why its humming its trying to spin up it but cant so it just keeps pulling more and more amps till the trip cuts out
Mar 25, 2010 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Our model 180 stopped after hitting a knot in pine(PowerMatic)
If the motor is humming, the overload isn't tripped. This may be obvious, but have you checked to make sure the motor and cutter head turn freely by hand? The other possibilities would be: a bad motor, burnt connections, or a defective/wrong size new capacitor. There isn't a whole lot to these to go wrong.
Dec 06, 2009 | Tools & Hardware - Others
Dryer drum will not spin. motor hums when button
either the belt is broken that turns the motor or thr idler tension pulley is bad, if it were a motor problem the breaker most likely will trip
Nov 01, 2009 | Dryers
Compressor makes noise, but fans won't run
I'm guessing the hum you hear is the fan motor. After sitting for a time, I've had many that develop like a dead spot in the fan motor. Here's what to try. Shut power off to AC. Get someone up on the roof with about a 2 ft.,long fairly strong stick, or rod , about 1/4 inch or so in diameter. Have them carefully poke it through the openings in the cover and spin the fan blades at the back end of it. May be a little stiff at first, so don't break blades on fan, but get stick under one & lift to spin it, or over it & push it downward. Spin it 2 or 3 times all the way around. Turn power back on. Now stand back & try fan mode again. 99% of the time that will do it, but if not, take screws off around cover on roof & remove cover & give fan a bunch of good spins by hand, then turn power back on & try it. Keep me posted on results please ?
Jul 12, 2009 | Dometic Rooftop RV Air Conditioner
A/C TRIPPED BREAKER
Try the FAN ONLY position and start it.
Could be a stuck fan motor or a bad capacitor..
Remove the cover. Have someone turn it on. Once they turn it on spin the fan by hand. If it starts and runs replace the capacitor.
Mar 26, 2009 | Dometic Rooftop RV Air Conditioner
Dryer flips the breaker ran 4 1 year and nothing changed started this 2 days ago any idea about the
If its tripping your breaker either the motor is seized for some reason (easily tested by trying to turn the motor pulley by hand), or something in it is shorted out, most likely thing to short out and trip a house breaker is the heating element.
You can easily test the heating element as the possible cause by taking the 2 wires off the element connector, tape up these wires so it doesn't short out, plug the dryer in and try to run it. If its the heating element shorted out then the dryer will now run without tripping your breaker but of course not heat. If so replace the element.
Mar 09, 2009 | Kenmore 62602 Electric Dryer
Air Tools & Compressors Logo
220 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
