SOURCE: I don't have an owners manual. What kind of oil does this car?
The oil light goes on when the oil pressure is low. Check the level, and if you need to add any, use 10w40. The light blinking indicates one of 3 possibilities: 1. Oil level is dangerously low 2. oil sending unit is malfunctioning , or 3. Oil pump needs to be replaced. Don't overfill, too much oil is as bad as too little. If overfilled, the oil will foam, reducing lubrication to the engine./
SOURCE: WHAT KIND OF OIL AND WHAT WEIGHT SHOULD I USE?
Use 10w40 motor oil in the gear box. Don't use any synthetic oils, oil marked "EC", or oil with "special" additives. Stick with the major brands; Pennzoil, Quaker State, Mobil or Shell.
A “very helpful” rating for this answer? Thanks!
