Question about Pioneer DEH-1500 CD Player
Installing Pioneer DEH 1500. Power wires Yellow to Constant battery power. Red to Ignition Voltage Blk to Grd. Steareo doesnt turn on. When I connect the Grn and Blk wires together with Red, Stereo powers up. What does the Grn/Blk wire for. Were the solid grn for and what it connects to. Confused on hook up. Thank you!
  • geezatec May 23, 2011
    Honda Civic 2003. Model of stereo said on top of email.
  • 8,195 Answers
Hi, are you talking about the colors of the head unit wires or the car wires? Please tell me your car model and year.
Posted on May 23, 2011
  • Jeff Turcotte
    Jeff Turcotte May 24, 2011
    Here are the colors I have for your car pasted below--do these match what you see?
    And you should be connecting the stereo red wire to the car's yellow wire with red stripe--yes?
    Also connect the black to black
    Also connect the stereo's yellow wire to the car's blue wire with a white stripe. Does this make sense?
    2003 Civic wire colors:
    Car Radio Constant 12v+ Wire: Blue/White
    Car Radio Switched 12v+ Wire: Yellow/Red
    Car Radio Ground Wire: Black
    Car Radio Illumination Wire: Red/Black
    Left Front Speaker Positive Wire (+): Blue/Green
    Left Front Speaker Negative Wire (-): Gray/Black
    Right Front Speaker Positive Wire (+): Red/Green
    Right Front Speaker Negative Wire (-): Brown/Black
    Left Rear Speaker Positive Wire (+): Blue/Yellow
    Left Rear Speaker Negative Wire (-): Gray/White
    Right Rear Speaker Positive Wire (+): Red/Yellow
    Right Rear Speaker Negative Wire (-): Brown/White
Do you need to connect the yellow and red wires together if not used in a car on a pioneer DEH-X1950UB
Yellow - Connect to the constant 12 V supply terminal.
Red - Connect to terminal controlled by the ignition switch (12 V DC).
Jan 11, 2017 | Pioneer Car Audio & Video
I need the pinout looking at the back of the cd player
Most use:
BLK=Ground (-12V),
YEL=Constant (+12V)
RED=Ignition Switched (+12V)
ORG=Illumination (likely 0 to +12V)
Jan 10, 2015 | Pioneer DEH-P8000R
My Pioneer DEH-P4200UB Won't power up in my 97 mustang gt. The car recently had a kenwood deck that we took out. we are still using the kenwoods wires. Help us lol
Hi
Please verify voltage at the constant (Yellow) wire With the ignition OFF
Then Turn the Key to ACC and verify voltage on the RED wire.
Double check the ground to chassis metal.
The radio should power on at this point if both power wires show 10-14.4VDC
If not - your radio needs repair.
Thanks!
Nov 02, 2011 | Pioneer DEH-P4200UB Car CD / USB/ MP3...
The radio will not hold memory
If your radio will not hold memory then you are lacking a constant 12 volt power source. Check the yellow and red wires at the radio. The yellow wire should be connected to a constant 12 volt power source (battery) and the red wire should be connected to a switch 12 volt power source (accessory or ignition).
Nov 23, 2010 | Pioneer DEH-2800MP CD Player
Have a pioneer car radio model deh-p3100ub has power and good grd. it will not turn on is there a reset. fuse is good
do you have power going to both the red and yellow wires??? yellow is constant power (to retain memory) and red is switched (ignition). both wires need to see power before the unit will turn on.
Jun 11, 2010 | Car Audio & Video
I have a 98 ford winstar I'm installing a pioneer
You'll need to check that you have the yellow wire connected to constant battery, power from battery, not thru the ignition switch. The yellow wire is the power wire for the clock and radio presets.
May 13, 2010 | Car Audio & Video
I need wiring color coding 4 pioneer deh 2050mpg? i know red is constant power.
Not to question you about the red being constant power but I have a pioneer deh-1600 car stereo and red is hooked to electric terminal controlled by ignition switch (on/off) and if your unit has a yellow wire that goes to constant power. The only problem with hooking up the red wire to constant would be if you happened to accidentally leave your player on it could drain the battery. Hope this helped a little. Good luck.
Oct 10, 2009 | Pioneer DEH-P2000 CD Player
Need wiring diagram for harness
1) Black Ground
2) Red 12V Ignition
3) Yellow 12V Constant
4) Orange Illumination
(Sometimes there's an extra orange for cell phone mute)
5) Blue Remote
6) Blue/White Power Antenna
7) White Front Left
8) White/Blk Front Left
9) Gray Rear Left
10) Gray/Blk Rear Left
11) Green Front Right
12) Green/Blk Front Right
13) Purple Rear Right
13) Purple/Blk Rear Right
May 04, 2009 | Car Audio & Video
Red wire Pioneer MP 2050?
yes you can. but you risk battery drain in the long run. the ignition switch provides that feature for you... doesnt the old head unit have the wire for that? (red and yellow)
May 04, 2008 | Pioneer DEH-P2000 CD Player
Wiring schedule for 2002 new beetle volkswagen radio
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Mar 22, 2007 | Pioneer DEH-1500 CD Player
Pioneer DEH-1500 CD Player Logo
117 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
