Question about KitchenAid Refrigerators
How do you lock the wheels on a KitchenAid refridgerator so it will not slide across the floor when you open the door? This is Model #K2TREFFWWHOO Seial # EY4412439 I was told you could lock the back wheels, but how do you do this?
  • 57 Answers
SOURCE: The whole frige moves when I open the doors. I
you can put shims under the front of the fridge so the wheels are off the ground
Posted on Nov 27, 2010
SOURCE: kitchenaid model KHHS179LSS Microwave oven handle replacement
There is a pin holding the door on upper right hand corner of the door. Holding the door in the open position, lift up on the door a little and remove the pin. The door will come off. There are two screws on the edges of the door on the end where the handle is located. Remove the screws. Now, Take a slim screw driver, and carefully pry between the inside door panel and the ourside door panel starting at the end where the door handle is. Lift the inside of the door out. The opposite end of the inside door panel will come out last. Believe me, this works. Getting it back together is a little bit different, but it snaps back together without using tools. Just put the inside of the door back by laying it down with the handle side down after you have replaced the handle of course. Now, pushing in on the inside of the door panel starting on the handle side, start with lining up the panel and push gently. It will go back into place much much easier than it comes out.
Posted on Feb 06, 2008
SOURCE: power sliding door lock
I had the power sliding side door locks recalled on my 2003 Venture at Dealers expense.
Posted on Aug 31, 2008
  • 65 Answers
SOURCE: 2004 toyota sienna sliding door locking trouble
Sounds like something isn't right.Try to disconnect the battery for a few minutes and see if that helps.Some times the ecu gets haywired and disconnecting the battery might reset it.And if it is the original battery you might want to get it tested.
Posted on Dec 04, 2008
SOURCE: 2005 Toyota Sienna Sliding Door Won't Open
Have 2005 Sienna and its Driver side door was not openning. Cheap dealer fixed it himself in front of me. After opening the doors plastic assembly while sitting inside with a screw driver. Then he bent the clip towards left where the metal wire is connected. If you guys want to see what he did i would record a video and upload for you guys. Let me know at xahid2000@yahoo.com
Posted on Mar 13, 2009
How can I lock the wheels?
ever heard of a rubber door stop . small wedge shaped piece used to keep door open . FIND one or two and put in front of you refridgerator on the floor and push it under just a bit .
Mar 06, 2016 | Whirlpool Refrigerators
What are the dimensions?
You are missing a digit in the model number. KitchenAid Dishwashers have a number (0-6) after the SS.
The KUDI01FLSS0 installation guide gives the dimensions of the dishwasher opening and the unit itself on various pages. See http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208524480.pdf . The top vent and the front vent KUDI01FLSS model washers are slightly different. The front vent dishwasher dimensions are 33 7/8" H (with the wheels removed) x 23 7/8" W x 24 7/8" D (including the handle). The top vent model is only 24 1/2" deep. With the wheels in their lowest position, the opening for the dishwasher must be 34 1/2" high (from floor to the bottom of the counter top).
I hope this helps. Other KitchenAid appliance manuals are available here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . Use the search box to enter the model number and use the drop down menu to select Consumer.
Aug 14, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
My amana refrigertor rolls foward when you open the door does it have a wheel lock just purchased model sad2522wrb06 serial #s04326068 email...
Sounds like a very clean kitchen! I would almost like to eat off the floor!
Most refridgerators don't have a wheel lock. Ours didn't. I took a small chunk of play doh and made a small wedge in front of the front wheel.
When we pull it out for cleaning, I pull the hardened play doh off and replace it when I wheel it back in place.
Hope this helps,
Mark
Apr 01, 2011 | Refrigerators
Door doesn't self close on Kitchenaid Superba frig
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Jul 11, 2010 | KitchenAid Superba Architect KSCS25INSS...
We put this unit on self clean and now it wont turn on nor open.
I had the same problem with a Superba wall oven. In my case, the bracket mount for the door lock warped due to the heat of the self clean cycle. We were able to open the door by inserting a coat hanger into the slight opening at the top of the door and sliding the lock lever to the left. It was a pretty easy self-repair - 1) turn off breaker 2) slide oven out 2-3" 3) remove oven front trim pieces 4) remove screws that mount control panel 5) this should give you access to the door lock mechanism.
good luck
Feb 01, 2010 | KitchenAid Ovens
Freezer has frost building and the refridgerator is too warm.
make sure the evaporator fan is working, open door and push switch in if fan works make sure opening from freezer to fridge is not blocked. if door was removed make sure light in fridge is shuting off if temp in fridge is in the 50 degree range your light switch is not being deactivated check spacers between door and hinge . sometimes when door is removed a spacer will fall on floor and light switch is not hitting door
Jan 26, 2009 | KitchenAid KTRC22EL Top Freezer...
Interior Range Window cracked - How to Replace
It is simple enough not to need a manual.
1- open the door, then pull outwards. The door mounts slide right out.
2- lay flat on a towel on the floor. Remove screws on the inside of the door.
3- remove each piece and layer of the door and glass panels. Set them aside in order so you know how it goes back together
4- replace broken inner glass panel
5- put each piece back together, install screws
6- slide door (mounts) back into their homes on the front of the range
It is surprisingly simple. All you need is a #2 Phillips screwdriver and a bit of patience.
Tip: make sure to clean each glass panel while you have the door apart. Use a razor blade for those stubborn burnt on stains.
Apr 06, 2008 | KitchenAid KGRT607 Gas Kitchen Range
Fridge
Clean the door seal and ensure that there are no gaps between the sealing surfaces of the door seal and the refrigerator, if there is, relatively warm moist air will continually feed condensible moisture to the cold gap in the seal and the condensed water will drip on the floor. If the door seal its self is broken or torn it will have to be replaced to stop the drip.
Hope this helps.
Mar 16, 2008 | Refrigerators
UNLOCK STOVE DOOR
no code for unlockin door, were you self cleaning unit prior to door locking? if so themal fuse problably tripped off for percieved saftey reasons( thought it got too hot), you might be able to jimmy door open witha wire hanger bent a 90 degree angle maybe 2 in long slide it between console and door latch should release to the left. good luck fishin!!!
Feb 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
638 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
