Liquid spilled on hp laptop and enter key does not work ...i cant start my laptop up
  • 984 Answers
If the liquid was plain water, then no problem. Just dry it out with a hair dryer.
However, if the liquid contained sugar, the solution is a bit more difficult. Sugar crystallizes as it dries and takes on the characteristics of concrete. Let's take the easy one first:
  • Go to AutoZone and buy a spray can of CRC QD Electronic Cleaner.
  • Plug in your vacuum cleaner and be ready to immediately turn it on.
  • Spray the keybord with the cleaner.
  • Turn on the vacuum cleaner and pass it over the keyboard until there is no trace of the cleaner.
  • Repeat this process three (3) times.
If the problem still isn't solved we go the harder solution. Immediately beneath each key there is a latex or rubber prophylactic that protects the innards from liquids. It has to be cleaned off.and that means the key must be removed. Make small hook out of a paper clip. Insert it under the key and gently lift it up and off. Spray cleaner of the latx membrane and remove any remnants of the liquid with a clean cloth.
To reinstall the key just press it back on gently and it will click into place.
That should solve your problem. As a case in point, I'm typing this on a Microsoft keyboard that has been bathed in hot coffee on a couple of occasions.
All the best
Ben
Posted on May 23, 2011
Hp notebook not working?
Scan for Viruses
Sudden, unexplained computer issues are commonly caused by a virus infestation. These sneaky programs secretly install themselves on your system and alter the way the machine functions and responds to commands. Eliminate any hidden malicious programs by running a deep scan to find and destroy unwanted programs. You may need to perform a restore or recovery action on your system afterward to replace corrupted files with the correct versions.
Troubleshooting
To determine whether your non-functioning F5 key is due to a software issue or faulty hardware, connect a separate keyboard to your Pavilion. If the F5 key works on the external keyboard, the problem with your Pavilion's F5 key could be physical, such as a dirty key or spilled liquid. If the F5 key does not work on the external keyboard either, the problem likely lies in the software. Make sure that your operating system files are up-to-date to encourage proper communication between the keyboard and motherboard.
Thorough Cleaning
A keyboard key can become non-functional if it cannot make contact with the proper sensor beneath it, such as from accumulated debris or a spilled liquid. Dust, hair and lint can collect beneath and between your Pavilion's keys, which can interfere with proper contact when the layer becomes too thick. Sticky residue left behind by sugary liquids, such as soda or juice, can cause the key to stick, preventing the computer from registering the press. Thoroughly clean the area beneath the F5 key by gently prying the key off and using a cotton swab and rubbing alcohol to remove any dirt or residue.
Safe Mode
When you start your Pavilion, numerous other programs automatically start with it. Any of these programs could cause the F5 key to become non-responsive. Starting the Pavilion in Safe Mode will load only the essential operating system files and drivers, and if the F5 key works while in this mode, your problem most likely lies with an installed program or hardware device. To enter Safe Mode, restart your laptop and press the F8 key immediately. You'll enter the "Advanced Boot Options" menu, where you can use your arrow keys to select "Safe Mode" and press "Enter." If your F5 key still does not work, you may have a problem with your operating system files.
Jan 10, 2013 | HP Pavilion dv1000 Notebook
Hp cq60 keybord not working it beeping
Myself Srikanth, I am tech support eng at HP. At this point, I recommend you to contact the HP service center if it is under Accidental damage warranty which covers liquid spills. Or if you are computer savy, you can remove the keyboard laptop keyboard connection and check with the external keyboard. This issue will occer when any liquid spilled on keyboard and some of the keys were attached to the circuit. If the external keyboard worked fine then just send me the keyboard part number i will help you to purchase the new keyboard.
Thank you
Srikanth
Oct 09, 2012 | HP Compaq Presario CQ60-249US Notebook
I spilled liquid on my HP Probook 4320S (with spill resistant keyboard). Dried it up straight afterwards. Now it won't power up
Take it to a service shop asp, key board will need to be replaced, and the laptop will need to be assessed for motherboard damage.
May 06, 2012 | HEWLETT-PACKARD ProBook 4320s C Notebook
I spilt alcohol on my laptop and now the keys dont work
replaced ur keypad from the nearest hp service centre.
Apr 25, 2010 | HP CPQ175KB Keyboard
Some keys of HP G60 notebook not working
The membrane in the key matrix breaks, cracks etc, and it will not work. Best work around is a USB Keyboard
Feb 10, 2010 | HP D8597A Keyboard
Spilled liquid on my hp dvd6000 4 keys non
Need a new keyboard, let us know if you would like one ordered
Jan 25, 2010 | HP Pavilion dv6000z Notebook
Laptop keyboard replacement on a hp privilian zv5000
i think the circuit under "G" key is not functioning due to short circuit.
i recommend to bring this to technician for repair or buy a new keyboard since this is cheaper.
Aug 14, 2009 | HP HQRP Replacement Laptop Keyboard for HP...
Spilled liquid on laptop keyboard
Search for a keyboard on eBay. Should be about $5-15. Type in "(model name) keyboard."
Mar 14, 2009 | Fujitsu LifeBook N6100 Notebook
Key board
the ones on my laptop suddenly stopped aswell. i just kept pressing them down and eventually they started to work again. and fine ever sinse then. hope it helps.
Jun 23, 2008 | HP OmniBook XE3 Notebook
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
