Question about Cisco 7940 IP Phone
Can i make calls with a Hide ID? cisco ip phone 7960 series
    Sergeant:
    Champion:
  • 218 Answers
You will need to configure this through whatever SIP gateway you are using, it is not configured through the handset.
Posted on May 23, 2011
Cisco 7960 turns it self off
Do you have a power block for the phone or are you getting power from a POE switch via cat5 cable?
How do you know you purchased a working phone? When was the last time the phone worked properly?
Any other information you can supply about your VoIp setup would help us troubleshoot the power issue with your phone.
Jul 17, 2012 | Cisco 7960 IP Phone
How can I clear / reset a Cisco IP Phone 7910
How to set a Cisco IP phone to factory default Reset configuration of Cisco IP Phone (7910, 1911, 7940, 7941, 7960, 7961)
To set the Cisco IP phone to factory default completes the following steps: should be completed:
For 7940, 7941, 7960, 7961 phones:
1. Power up the phone (unplug power cable and plug in again and hold the # key.
2. Release # when lights start flashing.
3. Press 123456789*0#.
4. Press 1 to keep network configuration or 2 to lose the network configuration.
For 7906G and 7911G phones:
2. Release # when MWI starts flashing.
3. Press 3491672850*#.
Oct 28, 2010 | Cisco 7910 IP Phone
How can I upgrade my frimware on the Cisco 7960, it is a 3 and needs to be 7?
Best and easiest way is to plug it into a newer callmanager. The firmware will be upgraded regardless of wether or not it is able to register.
Sep 02, 2010 | Cisco 7960 IP Phone
I have tried repeatedly and I can not get my phone to set up. Not even sure what the phone # is. I need it from the start to the finish. I also need my work # to forward to my cell phone 817-713-1767.
What service are you using to provide your SIP? The 7960 requires a call manager, or other network bootable server to make the phone function. It will not function on its own.
Aug 25, 2010 | Cisco 7960 IP Phone
Cisco 7960 is not registering, says 'Requesting line status'.
Then contact your service provider, this issue is from there end, thanks!
Jul 29, 2010 | Cisco 7960 IP Phone
Want to migrate fom sccp to sip protocol for cisco IP Phone 7912
Here's a great little document from Cisco directly, called "Converting a Cisco 7940/7960 CallManager Phone to a SIP Phone and the Reverse Process"
Easy to do, just follow the step-by-step directions.
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a0080094584.shtml
Jan 21, 2010 | Cisco 7912G IP Phone
Is there an easy solution to repair noisy handsets on cisco 7900 series ip phones ie: a rattle in the handset itself. Do they come apart for tightening ????
The Cisco handsets will not come apart easily, and chances are you will snap the plastic on the first few you try. Replacement handsets are however reasonably priced, and then you've got a brand new one. We have these available for purchase at Idacom.
1-800-903-9190
Apr 25, 2009 | Cisco 7960 IP Phone
Trouble forwading a call on a cisco 7960
If your primary database is not up on Cisco Call Manager (CCM) then the phone doesn't accept any changes in configuration, all call functions work.
Feb 16, 2009 | Cisco 7960 IP Phone
7906G Home VOIP installation Problem
Then you need power adapter for Cisco 7960 IP phone ( -40V DC).
Cisco phones work best with Cisco, and sometimes ONLY Cisco switches.
One question which voice gateway you will use for your 7960 VoIP phone calls to go through ?
(AT&T probably supports only their IP Phones with special and usually hidden settings from end user)
Jan 17, 2009 | Cisco 7906G IP Phone
Calls ringing in on a line already in use
You need to change the 'number of call before engaged' value in the phone configuration to 1 for each of the lines... that way the line will be engaged and the next line will be used.
Dec 15, 2008 | Cisco 7960 IP Phone
Open Questions:
See all Cisco 7940 IP Phone Questions
Cisco 7940 IP Phone Logo
201 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
