Question about Midland Amateur&Consumer Radio Replacement Batteries: 70B-75.....1400 mAh 7.2V NiCD
Need Kenwood Part # E30-1709-05 DC power cord for TR-9130 or source for femal 2-pin connector
  • 10,594 Answers
I know THIS link only and its not in-stock but you can call and ask its availibility.
Posted on Aug 15, 2008
  • Shahid Electronics
    Shahid Electronics Aug 15, 2008
    Phone number is......toll-free at 1-866-925-PART (7278)
    Shahid Electronics Aug 16, 2008
    Your comments are still awaited on solution provided. Thanks
    Guru:
  • 1,894 Answers
Contact any nearest repair shop for the female 2 pin connector.
they will provide it at a very cheap rate.
thank you
  • dewan nafees ahmed Aug 16, 2008
    Genius:
  • 3,422 Answers
HI,
You can try these two websites for the parts:
www.pacparts.com
www.radioshack.com
  • Priya darshan Aug 15, 2008
    Here is another one:
    www.pronto.com
Kenwood tr 9130
http://myradio.piczo.com/microphoneplugandsocketpinouts?c
states that the pinout is as follows.
I believe this is a semi standard connector that you can find at "some" radio shacks. If not you can take any Kenwood mic and soldier the wires to the old plug.
If you want a new connector try Mouser or Allied.
KENWOOD-TR9000-9030-9130-9300-9500-7700-7730-7750-7800-7850-7930-7950-8400
PIN1 MIC
PIN2 PTT
PIN3 DOWN
PIN6/CENTER EARTH
PIN4 UP
PIN5 NC + 8VOLT SOME MODELS
Jul 01, 2014 | Radio Communications
Will power cord for ld3255vx work for ld4655vx wide screen tv?
Dear Cheryl,
The power cords are pretty standard from all theses TVs.
Please remember that these power cords have 3 pins (male side), being 2 flats and 1 round that connects to the wall. On the other side it also has 3 flat pins cast into the plastic/rubberized female side. These are standard power cables for the majority of the sound/video equipment you will find in the market.
If the connector at the TV (male) is of the same type in power cord you have (female), in other words, if it fits and completely locks in, then, YES! Go ahead and use it. There is no problem whatsoever.
IMPORTANT - BEFORE CONNECTING THE CORD TO THE WALL ("live" power), please test if your connector fits the TV set completely.
I hope I have helped you.
Dec 30, 2013 | Westinghouse " 46"" Class - LED - 1080p -...
Power connector pinout for CT-13R50 television
Directly from the user manual, Page 5 under "AC/DC Power Sources":
DC Models ONLY
"This TV model operates on both standard household current (120 volt, 60 Hz AC) and car battery (12 volt negative ground DC) through the cigarette lighter. An AC power cord and a car cigarette lighter adapter cord are supplied.
Household Installation
Insert the AC power cord into the connection on the rear of the TV. Connect the two pronged plug into an AC outlet (120 volt, 60Hz). If you are unable to insert the plug fully into the wall outlet, try reversing it. If the plug does not fit, contact an electrician. Do not force the plug or defeat the safety purpose of the polarized plug."
The manual goes on to describe the vehicle installation which is identical to the household, with the only difference being the car plug goes into the DC side of the power connections at the back.
There are several kinds of power cord available for older TV models. Unfortunately, after an exhaustive search, I was not able to locate a photo of the back of that model television.
However, I have included three of the typical US power connectors found on a great many devices and in the majority of cases, one of these cords will likely be the one you need. They can be found at most local stores such as Wal-Mart, or can be ordered online from Amazon. Also, the cored generally only fit in one direction, especially if the cord happens to be polarized (thin blade and wide blade).
I hope this helps!
Panasonic CT 13R50 Manuals and User Guides
Apr 18, 2017 | Televison & Video
Sony walkman NWZ-S754 Recharge is through computer - but can I recharge it via mains or in car.
Yes you can charge your player through main. All you need is a converter which connects to the usb cable to the plug. They are available in the market so you will need to look for it. Or you may find it at any electronic store.
Jan 20, 2011 | Sony Walkman Video NWZA818 MP3 Player
Hello my laptop t41 power is not even flash but the adapter is working,am technician and i have troubleshoot allot.
I concur with what Diegotech stated.
To iterate further;
1) The DC Power Jack (DC IN), may have cracked solder joint/s on the motherboard connector, (Female), where the DC Power Jack plugs in.
Resolder
2) The DC Power Jack may be broken.
Center Pin mount, and/or body of DC Power Jack, and/or Outer Shell mount.
Replace DC Power Jack.
3) Wires from the DC Power jack plug to the female connector on the motherboard, may be bad.
Two examples, of a place to buy an IBM ThinkPad T41 DC Power Jack,
1) http://www.buy.com/prod/dc-power-jack-connector-socket-for-ibm-thinkpad-t40-t41-t42-r50-r51-r52/q/sellerid/23962916/loc/101/215782035.html
2) http://www.machinaelectronics.com/store/buypart/IBM_Thinkpad_T41/DC-P001
Past this point it's a bad DC sensor on the motherboard.
Replace motherboard.
IBM ThinkPad T41 Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-ibmlenovo
On this page go down to the 8th line.
The one that starts with > ThinkPad T20.
Go across, and click on > T41
Takes approximately 2 seconds to see the first page, and additional time to fully download.
Page 142 for 14.1 inch LCD screen
Page 151 for 15 inch LCD screen
(PDF file page number box at top)
Dec 01, 2010 | IBM ThinkPad T41 Notebook
Battery does not charge, but remains on with power supply connected. Female to male connection "touchy." Can turn off if cord is barely touched. Main concern being how to fix female part of power supply.
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Oct 09, 2010 | Computers & Internet
Ok here's my problem i have a toshiba a75 s211 when i put the power cord in then i turn it on the power cord indicator is on and is green but the charging indicator dosent come on and when i turn my laptop...
Sep 21, 2010 | Toshiba Satellite A75-S211 Notebook
Casiotone MT-220 keyboard power cord
I would inspect the unit for corrosion on battery terminals AND the power connector. The connector has a switch when a cord is plugged in, and if this switch doesn't work (they get bent) the unit will not work on batteries.
Best source of power adapters is often your local thrift store.
MATCH the voltage and whether it is AC or DC required AND the polarity if the pin is + or -.
Get one with enough current.
Apr 28, 2010 | Music
Vga cable and power cord for monitor
The vga cable is a DB15, 3 ranks with male connector at each end,
(you can use a vga extention and add a little male to male adaptor at the female end to get finaly 2 males connectors)
And, the power cord is in fact an ac/dc adaptor, the replacement part is: 12b27-0428 (12v 5A 60w 4 pins) ...
just type de number 12b27-0428 on internet and you're on ...
Mar 12, 2009 | ViewSonic VG900b 19" LCD Monitor
Power supply cord
Any power supply providing 19V DC at 3 Amp with a positive tip connector will do.
Hope that helps.
Jun 13, 2008 | Balance CM2017 17" Monitor
Radio Communications Logo
124 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
