Question about Panamax Televison & Video
I have an older panamax max dbs allpath surge protector which I believe has done it's thing and now needs to be reset (5 of the 6 outlets have no power). I found the reset switch on the side but am unable to move it, or switch it, or anything. It appears to be a rocker switch, but I don't want to force it. Help please. Thanks, Joe Braucher
SOURCE: HD TV flat screen
there is a timer that you can set to turn the tv off automatically. The timer settings is between 30 min. and 3 hours, maybe she has hit the timer button by mistake.
Posted on Jun 17, 2008
bestdarngood
  • 3037 Answers
SOURCE: screen went black/won't power on
This is a common problem
The first step is to check the fuse on the power supply board. Next, disconnect the inverter board to eliminate the possibility of it shorting down the main and or power boards. Be careful as the inverter board supplies high voltage to the cold cathode tubes (backlights) and it bites HARD. If you disconnect the inverter and the power led comes up then replace the inverter board. (The screen will appear blank because you have no backlighting). If the power indicator still fails to light you need to suspect the main board first before the powwer supply board. The main board tells the power supply board to come on. You need to check the trigger from the main board to the relays on the power supply board. Also check the power connector to the main board because you should see +12V and/or +5V on at least some of the pins. If no power on the relay triggers then replace logic board. Then replace Power supply board last. Or buy a new monitor!!
Posted on Oct 26, 2008
JULIANFIX
  • 975 Answers
SOURCE: my sony won't turn on after an electrical storm.
NEED TO CHECK POWER SUPPLY of your TV , Look for blown fuse , or replace power supply , AJ
Posted on Jul 08, 2009
budmrtn
  • 11361 Answers
SOURCE: power surge hit my surge protector with my 'sony tv hooked to it.
Well, the power supply may be still damaged by the surge, what may happen is that when first surge happens the surge protector protect your TV by sacrifing itself but then the second surge comes along, since the protector already blown up then the surge will just come right through to the TV on the second surge. That is bad problem for the surge protector that sacrify itself but can only do it for ONE time.
Posted on Oct 31, 2009
  • 117 Answers
SOURCE: Samsung LN52A650 lcd will not turn on after power
open it up / there should be a glass fuse replace it/ull find it were the mains lead goes on the board/also try new lead just incase
Posted on Dec 26, 2009
We had a power surge in our living room while the TV was on. It was also plugged into a surge protector, however, everything else turned back on but the TV. There is no power going into it at all, as if...
Sounds like it might have blew a fuse on the AC input to the power supply, have to remove the back and look for a fuse near where the AC wires go from the plug on the tv. If the fuse is good
the power supply board will have to be checked or replaced..Next time consider buying a surge
protector that starts clamping at a lower voltage. Panamax brands usually start going to work
at 150v rms, where most others start at 330v rms..
Oct 21, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
I had a power surge about a month ago and now my wii will not turn on. My wii is pluged into a surge protector.
I posted this elsewhere on here too, but I'll post it here too so it helps you.
This is a common problem with the Wii. You wouldn't believe how often I read about this. I'm very surpised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself.
There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Dec 09, 2009 | Nintendo Wii Console
Wii will not turn on even though it has power and everything is connected. Help?
This is a common problem with the Wii. Even if it's hooked up to a surge protector. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 5 or 10 minutes, the red led on the front should be lit up.
Can't turn wii back on
Did you unplug it from the Wii, or from the Wall Outlet? You need to unplug it from the wall outlet, not the Wii. If you haven't unplugged it from the wall outlet and left it unplugged for 5 to 10 minutes, then unplug it from the wall outlet and leave unplugged for a good 5 to 10 minutes.
This is a common problem with the Wii. Even if it's hooked up to a surge protector. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself, so power to the AC adapter needs to be cut off.
Dec 08, 2009 | Nintendo Wii Console
My nintendo has no power going to it even tho the a/c adapter is hooked up
You'll need to unplug the AC adapter from the wall outlet and leave in unplugged for 5- or 10 minutes or so. Unplugging it from the Wii does no good.
This is a common problem with the Wii. As I said, I'm very surpised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked upto a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
There is no need to buy a new one or a AC adapter. Resetting it should work. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Dec 04, 2009 | Nintendo Wii Console
The game has no power but before we bring it back we would like to get the game out
It's likely not the Wii, it's the most likely the AC adapter. It needs to be reset. This is a COMMON issue after a power blip, surge, or outage (or it is way unplugged abruptly, or countless other things). If the below works, there no need to reutn the Wii. It's a common issue, the AC adapter just needs to be reset.
Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii.
This is a common problem with the Wii. As I mentioned above, I'm very surprised Nintendo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc. Even if it's hooked up to a surge protector, this happens. The power comes back on, but the Wii appears dead.
You need to reset the AC adapter to get the Wii to work again. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Nov 25, 2009 | Nintendo Wii Console
Everything is plugged in, and it wont turn on
It seems even 5th or 6th problem is this. The AC adapter needs to be reset. Unplug it from the wall outlet for 5 to 10 minutes (NOT from the Wii, it HAS to be from the wall outlet).
This is a common problem with the Wii. As I said, I'm very surprised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
Nov 22, 2009 | Nintendo Wii Console
When plugged, it shorts the surge protector and outlets.
I noticed that my refrigerator, kenmore freezer2_bing.gif, and stove were all not on. This has not ever been a problem before, so I unplugged the surge protector and reset the outlet. I then plugged the refrigerator2_bing.gif and the kenmore freezer to the surge protector and I noticed when I plugged the kenmore freezer it just shorted the surge protector. I then just plugged in the refrigerator and oven to the surge protector with no problems. I tried to plug kenmore freezer to other outlet and same result "a short
Nov 30, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Humming
If you live in an high altitude area it can cause a plasma to hum.
Another thing you can try if you don't live in an area like that is using a surge protector. The thing is your power outlet could be sending what's called "Dirty Electricity" to your tv that could be causing it to hum. I would recommend something that does "power filtering" like a Panamax surge or a Monster surge.
So that you get clean power to the tv
Hope my info is useful....
Thanx for using fixya......
Oct 16, 2008 | Toshiba 52HM95 52" HDTV Projection...
Help -Motorola DSR922 Clicking After Power Goes On And Off
I had same problem - found clicking stopped when I disconnected the Ku LNB - probably shorted. But, I have other problems in that both receiver and unit i.d. numbers have changed. So far, the only option seems to be to send it back to ATS (828 465 9968) for repair. I also had unit on UPS power.
Aug 03, 2008 | Arris DSR922
Televison & Video Logo
56 people viewed this question
Top Panamax Televison & Video Experts
Electro Med Services...
Are you a Panamax Televison and Video Expert? Answer questions, earn points and help others
